    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 9.9k Views 9 Watching
    • evroomE
      evroom @KristjanESPERANTO
      @KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
      I just released version 3.0.1 to fix this 😀
      At this moment I see an entry in the past with +0.5.
      Also saw +0.6.
      When turning on debug, I only see delay values of 0, 60 and null, so I wonder where the current 0.5 comes from.
      The values for when and plannedWhen all have a difference of 0 or 1 minute.
      It seems that it only affects the first entry in the list, which in my case is the first unreachable in the past.
      And it does not really bother me, but it still is odd.
      MagicMirror version: 2.37.0
      • V
        Volkae @KristjanESPERANTO
        @KristjanESPERANTO
        I did the update
        cd ~/MagicMirror/modules/MMM-PublicTransportHafas
        git pull
        npm ci
        but it still does not work.
        Any idea??
        V 1 Reply Last reply
        • V
          Volkae @Volkae
          @Volkae
          pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
          npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
          npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
          KristjanESPERANTOK 1 Reply Last reply
          • KristjanESPERANTOK
            KristjanESPERANTO Module Developer @Volkae
            @Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
            S V 2 Replies Last reply
              sdetweil @KristjanESPERANTO
              I think to be more clear, deleting the module folder
              • V
                @KristjanESPERANTO
                I deleted the modul folder and made a new install. Now it works.
                Thanks a lot!!
                • O
                  othomys
                  @KristjanESPERANTO
                  Thank you for your support. I hope to find some time this weekend to implement your suggestion.
                  O 1 Reply Last reply
                  • O
                    othomys @othomys
                    @KristjanESPERANTO , it works. Thanks a lot. :-)
                      rotorax
                      Hi, thanks for your update.
                      I installed your git version and I had to install undici additionally. Is that correct?
                      The MM works but ended starting up again and agin:
                      0|mm | <— Last few GCs —>
                      0|mm | [17870:0x2a530000] 119266 ms: Mark-Compact (reduce) 126.9 (128.6) -> 126.4 (128.1) MB, pooled: 0 MB, 791.61 / 0.00 ms (+ 0.9 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 816 ms) (average mu = 0.190, current[17870:0x2a530000] 120521 ms: Mark-Compact 126.9 (128.1) -> 126.5 (128.6) MB, pooled: 0 MB, 1201.60 / 0.00 ms (average mu = 0.113, current mu = 0.043) allocation failure; scavenge might not succeed
                      0|mm | <— JS stacktrace —>
                      0|mm | FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                      0|mm | ----- Native stack trace -----
                      0|mm | /home/mirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                      Im using a raspberry pi zero with 512 MB RAM which worked fine in the past.
                      Also some system information:
                      0|mm | [2025-02-03 08:57:53.254] [INFO] System information:
                      0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
                      0|mm | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                      0|mm | ### VERSIONS: electron: 32.2.7; used node: 22.13.1; installed node: 22.13.1; npm: 10.9.2; pm2: 5.4.3
                      0|mm | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                      Anyone have the same problem?
                        sdetweil @rotorax
                        @rotorax how big is the swap space?
                        free -m
                        Will list that
                        R 1 Reply Last reply
                          rotorax @sdetweil
                          while running and short time before crashing:
                          user:~ $ free -m
                          total used free shared buff/cache available
                          Mem: 426 217 99 19 109 132
                          Swap: 871 250 621
                            sdetweil @rotorax
                            @rotorax OK try this
                              export NODE_OPTIONS=--max-old-space-size=4096
                            before the npm start
                            if using pm2 then this goes in the script it launches,
                            using my setup
                            MagicMirror/installers/mm.sh
                            4096 may need to be adjusted
                              rotorax @sdetweil
                              @sdetweil thanks for the idea. I already had this code seen. But never implemented in my pm2 startup file.
                              I tried up to 512 (limit of the raspberry I have).
                              Thats the log I got:
                              0|mm | [22565:0x47124000] 127560 ms: Mark-Compact (reduce) 127.2 (128.1) -> 126.7 (128.3) MB, pooled: 0 MB, 731.03 / 0.01 ms (+ 36.3 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 896 ms) (average mu = 0.169, curren[22565:0x47124000] 128545 ms: Mark-Compact (reduce) 127.2 (128.3) -> 126.4 (127.8) MB, pooled: 0 MB, 832.78 / 0.00 ms (+ 1.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 860 ms) (average mu = 0.162, current
                              I rolled back to the old config before the change of the MMM-PublicTransprtHafas and it run hours (unfortunately I don’t get any live data anymore with the old version)…
                              More ideas? ;) Grateful for every hint :)
                                sdetweil @rotorax
                                @rotorax i am certain you have to have at LEAST 4096, not smaller, maybe 8192
                                Reply Quote -1
