    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 9.8k Views 9 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @othomys
      @othomys I have a solution, just need a bit time to implement it properly. I’ll try to bring out a new release at the weekend :-)
      KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
        KristjanESPERANTO Module Developer @KristjanESPERANTO
        New release 3.0.0 is out 👩‍💻. Please update the module and test it 🚊⏰😀
        MZ-BERM 1 Reply Last reply Reply Quote 2
        • MZ-BERM
          MZ-BER @KristjanESPERANTO
          @KristjanESPERANTO thanks for the update but it is still not working. I haven’t checked the log yet but will let you know later the day.
            KristjanESPERANTO Module Developer @MZ-BER
            @MZ-BER How did you do the update?
            cd ~/MagicMirror/modules/MMM-PublicTransportHafas
            git pull
            npm ci
            evroomE MZ-BERM 2 Replies Last reply Reply Quote 1
            • evroomE
              evroom @KristjanESPERANTO
              @KristjanESPERANTO
              I did the update and it is looking much better now.
              I reverted back to db (npm run query dbis working again).
              Only one thing I noticed:
              On display (last update 11:15)
              11:08 +1.0333333333333334
              11:28 +0
              The 11:08 entry is in the past (maxUnreachableDepartures: 2,).
              The +1.0333333333333334 is a bit too much :-)
              MagicMirror version: 2.37.0
              • MZ-BERM
                @KristjanESPERANTO I missed the npm ci. Now it is working as expected. Thank you 😊
                  KristjanESPERANTO Module Developer @evroom
                  @evroom said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                  I just released version 3.0.1 to fix this 😀
                  evroomE V 2 Replies Last reply Reply Quote 0
                  • evroomE
                    @KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                    At this moment I see an entry in the past with +0.5.
                    Also saw +0.6.
                    When turning on debug, I only see delay values of 0, 60 and null, so I wonder where the current 0.5 comes from.
                    The values for when and plannedWhen all have a difference of 0 or 1 minute.
                    It seems that it only affects the first entry in the list, which in my case is the first unreachable in the past.
                    And it does not really bother me, but it still is odd.
                    • V
                      Volkae @KristjanESPERANTO
                      @KristjanESPERANTO
                      I did the update
                      git pull
                      npm ci
                      but it still does not work.
                      Any idea??
                      • V
                        Volkae @Volkae
                        @Volkae
                        pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
                        npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                        npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                          KristjanESPERANTO Module Developer @Volkae
                          @Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
                          S V 2 Replies Last reply Reply Quote 0
                            sdetweil @KristjanESPERANTO
                            I think to be more clear, deleting the module folder
                            • V
                              @KristjanESPERANTO
                              I deleted the modul folder and made a new install. Now it works.
                              Thanks a lot!!
                              • O
                                othomys
                                @KristjanESPERANTO
                                Thank you for your support. I hope to find some time this weekend to implement your suggestion.
                                O 1 Reply Last reply Reply Quote 1
                                • O
                                  othomys @othomys
                                  @KristjanESPERANTO , it works. Thanks a lot. :-)
                                    rotorax
                                    Hi, thanks for your update.
                                    I installed your git version and I had to install undici additionally. Is that correct?
                                    The MM works but ended starting up again and agin:
                                    0|mm | <— Last few GCs —>
                                    0|mm | [17870:0x2a530000] 119266 ms: Mark-Compact (reduce) 126.9 (128.6) -> 126.4 (128.1) MB, pooled: 0 MB, 791.61 / 0.00 ms (+ 0.9 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 816 ms) (average mu = 0.190, current[17870:0x2a530000] 120521 ms: Mark-Compact 126.9 (128.1) -> 126.5 (128.6) MB, pooled: 0 MB, 1201.60 / 0.00 ms (average mu = 0.113, current mu = 0.043) allocation failure; scavenge might not succeed
                                    0|mm | <— JS stacktrace —>
                                    0|mm | FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                    0|mm | ----- Native stack trace -----
                                    0|mm | /home/mirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                                    Im using a raspberry pi zero with 512 MB RAM which worked fine in the past.
                                    Also some system information:
                                    0|mm | [2025-02-03 08:57:53.254] [INFO] System information:
                                    0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
                                    0|mm | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                                    0|mm | ### VERSIONS: electron: 32.2.7; used node: 22.13.1; installed node: 22.13.1; npm: 10.9.2; pm2: 5.4.3
                                    0|mm | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                    Anyone have the same problem?
                                      sdetweil @rotorax
                                      @rotorax how big is the swap space?
                                      free -m
                                      Will list that
                                        rotorax @sdetweil
                                        while running and short time before crashing:
                                        user:~ $ free -m
                                        total used free shared buff/cache available
                                        Mem: 426 217 99 19 109 132
                                        Swap: 871 250 621
                                          sdetweil @rotorax
                                          @rotorax OK try this
                                            export NODE_OPTIONS=--max-old-space-size=4096
                                          before the npm start
                                          if using pm2 then this goes in the script it launches,
                                          using my setup
                                          MagicMirror/installers/mm.sh
                                          4096 may need to be adjusted
                                            rotorax @sdetweil
                                            @sdetweil thanks for the idea. I already had this code seen. But never implemented in my pm2 startup file.
                                            I tried up to 512 (limit of the raspberry I have).
                                            Thats the log I got:
                                            0|mm | [22565:0x47124000] 127560 ms: Mark-Compact (reduce) 127.2 (128.1) -> 126.7 (128.3) MB, pooled: 0 MB, 731.03 / 0.01 ms (+ 36.3 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 896 ms) (average mu = 0.169, curren[22565:0x47124000] 128545 ms: Mark-Compact (reduce) 127.2 (128.3) -> 126.4 (127.8) MB, pooled: 0 MB, 832.78 / 0.00 ms (+ 1.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 860 ms) (average mu = 0.162, current
                                            I rolled back to the old config before the change of the MMM-PublicTransprtHafas and it run hours (unfortunately I don’t get any live data anymore with the old version)…
                                            More ideas? ;) Grateful for every hint :)
