    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 9.3k Views 9 Watching
    • evroomE Offline
      evroom
      Seems that DB made the service, as used by Hafas, unavailable.
      https://reiseauskunft.bahn.de
      503 Service Temporarily Unavailable
      Also other programs using it have this problem.
      Can only hope that there is or there will be an alternative source.
      It is the one of the 3 most used MagicMirror modules in our household.
      MagicMirror version: 2.37.0
      • evroomE Offline
        evroom @evroom
        Possible work-around.
        Needs travelling via Austria :-)
        To check if your station is available:
        $ cd ~/MagicMirror/modules/MMM-PublicTransportHafas
        $ npm run query oebb
        > mmm-publictransporthafas@2.1.13 query
        > node ./convenience/query_stations.mjs oebb
        Using hafas-client profile: oebb
        Enter an address or station name:
        This will give you a station Id.
        Update config.js:
        $ vi ~/MagicMirror/config/config.js
              hafasProfile: "oebb",
              stationID: "<ID>",
              stationName: "<Stop>",
        For me the list appears again, although I do not see the real-time times, meaning it shows the ⚠ symbol (as set in noRealtimeDelayString: "⚠",).
        One can try different hafas-client profiles, listed in:
        https://github.com/public-transport/hafas-client/blob/main/p/readme.md
        When you are lucky there is a good alternative to db.
        • evroomE Offline
          evroom @othomys
          @othomys said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
          Georg-Schwarz-Str./Merseburger-Str.
          For you I found this one:
          $ npm run query insa
          Enter an address or station name: Georg-Schwarz
          Stops found for 'Georg-Schwarz':
           > Stop: Leipzig, Georg-Schwarz-/Merseburger Str.
             Transport product(s): Tram, Bus
          So your config will be:
                hafasProfile: "insa",
                stationID: "12555",
                stationName: "Georg-Schwarz-Str./Merseburger-Str.",
          • evroomE Offline
            evroom @p1lspeda
            @p1lspeda said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
            Höfchen/Listmann
            For you, try this:
            $ npm run query rmv
            Using hafas-client profile: rmv
            Enter an address or station name: Höfchen/Listmann
            Stops found for 'Höfchen/Listmann':
             > Stop: MZ Höfchen/Listmann
               Transport product(s): Bus
            Config:
                 hafasProfile: "rmv",
                 stationID: "3029051",
                 stationName: "Höfchen/Listmann",
              sdetweil @evroom
              @evroom what folder to be in??
              • evroomE Offline
                evroom @sdetweil
                • KristjanESPERANTOK Online
                  KristjanESPERANTO Module Developer @othomys
                  @othomys I have a solution, just need a bit time to implement it properly. I’ll try to bring out a new release at the weekend :-)
                  KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
                    KristjanESPERANTO Module Developer @KristjanESPERANTO
                    New release 3.0.0 is out 👩‍💻. Please update the module and test it 🚊⏰😀
                    MZ-BERM 1 Reply Last reply Reply Quote 2
                    • MZ-BERM Offline
                      MZ-BER @KristjanESPERANTO
                      @KristjanESPERANTO thanks for the update but it is still not working. I haven’t checked the log yet but will let you know later the day.
                        KristjanESPERANTO Module Developer @MZ-BER
                        @MZ-BER How did you do the update?
                        git pull
                        npm ci
                        evroomE MZ-BERM 2 Replies Last reply Reply Quote 1
                        • evroomE Offline
                          evroom @KristjanESPERANTO
                          @KristjanESPERANTO
                          I did the update and it is looking much better now.
                          I reverted back to db (npm run query dbis working again).
                          Only one thing I noticed:
                          On display (last update 11:15)
                          11:08 +1.0333333333333334
                          11:28 +0
                          The 11:08 entry is in the past (maxUnreachableDepartures: 2,).
                          The +1.0333333333333334 is a bit too much :-)
                          • MZ-BERM Offline
                            @KristjanESPERANTO I missed the npm ci. Now it is working as expected. Thank you 😊
                              KristjanESPERANTO Module Developer @evroom
                              @evroom said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                              I just released version 3.0.1 to fix this 😀
                              evroomE V 2 Replies Last reply Reply Quote 0
                              • evroomE Offline
                                @KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                                At this moment I see an entry in the past with +0.5.
                                Also saw +0.6.
                                When turning on debug, I only see delay values of 0, 60 and null, so I wonder where the current 0.5 comes from.
                                The values for when and plannedWhen all have a difference of 0 or 1 minute.
                                It seems that it only affects the first entry in the list, which in my case is the first unreachable in the past.
                                And it does not really bother me, but it still is odd.
                                • V Offline
                                  Volkae @KristjanESPERANTO
                                  @KristjanESPERANTO
                                  I did the update
                                  git pull
                                  npm ci
                                  but it still does not work.
                                  Any idea??
                                  • V Offline
                                    Volkae @Volkae
                                    @Volkae
                                    pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
                                    npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                                    npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                                      KristjanESPERANTO Module Developer @Volkae
                                      @Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
                                      S V 2 Replies Last reply Reply Quote 0
                                        sdetweil @KristjanESPERANTO
                                        I think to be more clear, deleting the module folder
                                        • V Offline
                                          @KristjanESPERANTO
                                          I deleted the modul folder and made a new install. Now it works.
                                          Thanks a lot!!
                                          • O Offline
                                            othomys
                                            @KristjanESPERANTO
                                            Thank you for your support. I hope to find some time this weekend to implement your suggestion.
                                            O 1 Reply Last reply Reply Quote 1
