    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 10.0k Views 9 Watching
    • evroomE
      evroom @evroom
      Possible work-around.
      Needs travelling via Austria :-)
      To check if your station is available:
      $ cd ~/MagicMirror/modules/MMM-PublicTransportHafas
      $ npm run query oebb
      > mmm-publictransporthafas@2.1.13 query
      > node ./convenience/query_stations.mjs oebb
      Using hafas-client profile: oebb
      Enter an address or station name:
      This will give you a station Id.
      Update config.js:
      $ vi ~/MagicMirror/config/config.js
            hafasProfile: "oebb",
            stationID: "<ID>",
            stationName: "<Stop>",
      For me the list appears again, although I do not see the real-time times, meaning it shows the ⚠ symbol (as set in noRealtimeDelayString: "⚠",).
      One can try different hafas-client profiles, listed in:
      https://github.com/public-transport/hafas-client/blob/main/p/readme.md
      When you are lucky there is a good alternative to db.
      MagicMirror version: 2.37.0
      • evroomE
        evroom @othomys
        @othomys said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
        Georg-Schwarz-Str./Merseburger-Str.
        For you I found this one:
        $ npm run query insa
        Enter an address or station name: Georg-Schwarz
        Stops found for 'Georg-Schwarz':
         > Stop: Leipzig, Georg-Schwarz-/Merseburger Str.
           Transport product(s): Tram, Bus
        So your config will be:
              hafasProfile: "insa",
              stationID: "12555",
              stationName: "Georg-Schwarz-Str./Merseburger-Str.",
        • evroomE
          evroom @p1lspeda
          @p1lspeda said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
          Höfchen/Listmann
          For you, try this:
          $ npm run query rmv
          Using hafas-client profile: rmv
          Enter an address or station name: Höfchen/Listmann
          Stops found for 'Höfchen/Listmann':
           > Stop: MZ Höfchen/Listmann
             Transport product(s): Bus
          Config:
               hafasProfile: "rmv",
               stationID: "3029051",
               stationName: "Höfchen/Listmann",
            sdetweil @evroom
            @evroom what folder to be in??
            evroomE 1 Reply Last reply
            • evroomE
              evroom @sdetweil
              • KristjanESPERANTOK
                KristjanESPERANTO Module Developer @othomys
                @othomys I have a solution, just need a bit time to implement it properly. I’ll try to bring out a new release at the weekend :-)
                KristjanESPERANTOK 1 Reply Last reply
                Reply Quote 2
                  KristjanESPERANTO Module Developer @KristjanESPERANTO
                  New release 3.0.0 is out 👩‍💻. Please update the module and test it 🚊⏰😀
                  MZ-BERM 1 Reply Last reply
                  Reply Quote 2
                  • MZ-BERM
                    MZ-BER @KristjanESPERANTO
                    @KristjanESPERANTO thanks for the update but it is still not working. I haven’t checked the log yet but will let you know later the day.
                      KristjanESPERANTO Module Developer @MZ-BER
                      @MZ-BER How did you do the update?
                      git pull
                      npm ci
                      evroomE MZ-BERM 2 Replies Last reply
                      • evroomE
                        evroom @KristjanESPERANTO
                        @KristjanESPERANTO
                        I did the update and it is looking much better now.
                        I reverted back to db (npm run query dbis working again).
                        Only one thing I noticed:
                        On display (last update 11:15)
                        11:08 +1.0333333333333334
                        11:28 +0
                        The 11:08 entry is in the past (maxUnreachableDepartures: 2,).
                        The +1.0333333333333334 is a bit too much :-)
                        Reply Quote 2
                        • MZ-BERM
                          @KristjanESPERANTO I missed the npm ci. Now it is working as expected. Thank you 😊
                            KristjanESPERANTO Module Developer @evroom
                            @evroom said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                            I just released version 3.0.1 to fix this 😀
                            evroomE V 2 Replies Last reply
                            • evroomE
                              @KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                              At this moment I see an entry in the past with +0.5.
                              Also saw +0.6.
                              When turning on debug, I only see delay values of 0, 60 and null, so I wonder where the current 0.5 comes from.
                              The values for when and plannedWhen all have a difference of 0 or 1 minute.
                              It seems that it only affects the first entry in the list, which in my case is the first unreachable in the past.
                              And it does not really bother me, but it still is odd.
                              • V
                                Volkae @KristjanESPERANTO
                                @KristjanESPERANTO
                                I did the update
                                git pull
                                npm ci
                                but it still does not work.
                                Any idea??
                                V 1 Reply Last reply
                                • V
                                  Volkae @Volkae
                                  @Volkae
                                  pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
                                  npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                                  npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                                    KristjanESPERANTO Module Developer @Volkae
                                    @Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
                                    S V 2 Replies Last reply
                                      sdetweil @KristjanESPERANTO
                                      I think to be more clear, deleting the module folder
                                      • V
                                        @KristjanESPERANTO
                                        I deleted the modul folder and made a new install. Now it works.
                                        Thanks a lot!!
                                        • O
                                          othomys
                                          @KristjanESPERANTO
                                          Thank you for your support. I hope to find some time this weekend to implement your suggestion.
                                          O 1 Reply Last reply
                                          • O
                                            othomys @othomys
                                            @KristjanESPERANTO , it works. Thanks a lot. :-)
