    Touchscreen Family Dashboard
    touchscreentouch
    51 Posts 26 Posters 61.0k Views 44 Watching
    • E
      elwood1982uk @elwood1982uk
      I’m basically going round in circles. Whenever I restart I have to remember everything from before so it’s very slow progress. I’ve just started fresh, using the auto installer (thanks). Took a while to get node/npm to the right version (I’m not sure why the auto installer didn’t?). Now at the point of adding modules but again I’ve run out of time. Could really do with a straightforward walkthrough (I do realise there is lots of info around/on here, but I find it overwhelming to know where to start, or when something goes wrong (long the node version earlier) how to sort it. Just want an editable touch screen Google calendar! 🤪`
      S 2 Replies Last reply
        sdetweil @elwood1982uk
        @elwood1982uk send the ~/install.log to my email…
        same id as here at gmail. I’ll fix whatever caused the wrong node…
        you DID execute install DIRECTLY from the github page, with copy/paste… right?
        you did NOT clone that repo and execute from the copy (cause I update it all the time to keep it current)
        which is why it have copiable lines to paste and execute
        you did start with the FULL image, not the light… light makes things MUCH more complicated
        if you use my backup/restore scripts, then you wouldn’t have to remember the MM setup
        https://github.com/sdetweil/MagicMirror-backup-restore
        you can add one module, backup
        and another backup
        (I save versions, so you can get back to any one of them)
        but other than that there is no ‘straight forward steps’, do this, then this…
        welcome to the learning curve. someone created something new, (touch screen editable calendar)… so there are extra things everywhere…
        and a LOT to know…
        this is NOT plop a TV on the wall and you’re done…
          @elwood1982uk said in Touchscreen Family Dashboard:
          google has that already, open the calendar web page… done…
          don’t need MagicMirror to do that
          E 1 Reply Last reply
          • E
            elwood1982uk @sdetweil
            @sdetweil thanks yes I think that’s what I’ll do but I can’t even get a virtual keyboard working (have tried onboard and another-the name has slipped my mind) -they either don’t pop up or are too big etc. It’s not that I thought it would be easy but I did think I’d at least get it partly done by now 🤪
              @elwood1982uk did you see
              https://forum.magicmirror.builders/topic/12526/mmm-keyboard-a-virtual-touch-keyboard
              • T
                tugamuc @tjat
                @tjat
                I think your project is amazing! Maybe it’s a bit silly of me to ask, but would you be willing to share your project with us? Specifically, the
                • onfig.js
                • custom.css
                and maybe your modules.
                I (and probably others as well) would love to use your project but might not have such great ideas ourselves.
                If you’re kind enough to share it, please make sure to remove any personal data.
                Thanks a lot for your awesome work!
                Best regards,
                  sdetweil @tugamuc
                  @tugamuc he shared the link here
                  https://forum.magicmirror.builders/post/111162
                    sfrangakis @jalow
                    @jalow
                    Hi, I would also like to know what files you modified and how you did so to be able to modify/delete events. I am having the same problem you were where the eventId is ‘undefined’ in the CX3 module. Any help would be appreciated, thank!
                      sdetweil @sfrangakis
                      @sfrangakis he shared his code
                        sfrangakis @sdetweil
                        @sdetweil @jalow
                        Do you mean tjat has shared his code? If so, I have copied his modules from the github page and have implemented them. I was hoping that jalow (or someone who may have solved the same problem) would let me know what changes he made to tjat’s modules to allow for modifying/deleting events.
                          @sfrangakis ah modify/delete
                          • A a7c12a5 referenced this topic on
                          • A
                            a7c12a5
                            Hi @tjat just found your setup and would start working on building this for my family. Thanks for sharing. Hopefuly I can have something running soon to share. 🙏🏾
                              chrishunt392
                              Reviving this thread because I am about to lose my mind… I cannot figure this out. I would LOVE to mimic the OP and my only edits being replacing the traffic with the wifi QR but I cannot figure this out. Is anyone willing to take a look at my coding and help? SOS
                              This is what mine currently looks like:
                              https://i.imgur.com/AEZCGRN.png
                              • PierreGodeP
                                PierreGode Module Developer @tjat
                                @tjat I recomment you to take a look at my https://github.com/PierreGode/MMM-Chores ( it supports touch )
                                • V
                                  vtek
                                  sorry to revive this thread. I’m trying to get this going on my own MM
                                  @tjat do you think you’d be able to post your config.js file so I could have a reference please?
                                  • 3 / 3
