    MMM-pages - how to know which page index my module has?
    29 Posts 4 Posters 10.5k Views 4 Watching
      sdetweil @mvrlogins
      @mvrlogins why not? what triggers the notification??
      button, command , …
      you could prove this with the MMM-CommandtoNotification module
        mvrlogins @sdetweil
        I’m using MMM-Remote Control
        The issue is that the video is shown all the time on page0.
        I have 2 pages set up with MMM-Pages
        • 1 page to be shown all the time
        • 1 hidden page to be shown only when called.
        The video needs to be on the hidden page. If I put classes : “hidden_page” under MMM-Player, the video feed shows on the page0 regardless.
        The hidden page, when called, shows only the header fro MMM-Player and is otherwise blank
        The page calling works fine with MMM-RemoteControl
                module: "MMM-pages",
                    rotationTime: 1000 * 20, // rotate every 20 seconds
                        ["page1"],           // class name for page 1
                    fixed: ["fixed_page"],
                    hiddenPages: {
                        "Doorbell": ["doorbell_page"],
        and
        	module: 'MMM-MPlayer',
                classes: "doorbell_page",
                disabled: false,
                header: "MPlayer",
        	  useTwoWindows: true,
        	  layout: 'column',
        	  monitorAspect: 0,
        	  rotate: -1,
        	  windowSize: { width: 640, height: 480 },
        	  windowPosition: { x: 5, y: 225 },
        	  streamInterval: 30000,
        	  streams: {
        		window1: [
        		  'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN',
        		window2: [
        		  'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix',
          mvrlogins @mvrlogins
          Only thing I can think of right now is to put the video on page0 and the rest on page1
          and then use a combination of the PAGE_CHANGED and PAUSE_ROTATION notifications to get what I want
          Or is there a way to permanently pause rotation?
          Then I can only use the PAGE_CHANGED call to get to the page I want
          would the below disable rotation?
          rotationTime: 1000 * 0,
            sdetweil @mvrlogins
            @mvrlogins i believe so. but you should have been able to send the notification for the named hidden page
            “SHOW_HIDDEN_PAGE”, “Doorbell”
            right?!
              mvrlogins @sdetweil
              @sdetweil said in MMM-pages - how to know which page index my module has?:
              right?!
              Yes, the notification works fine.
              But mplayer does not show up on the hidden page, only on the main page
                sdetweil @mvrlogins
                @mvrlogins hm, that makes no sense as the MagicMirror operations are the same
                  sdetweil @mvrlogins
                  @mvrlogins i opened this issue
                  https://github.com/evroom/MMM-MPlayer/issues/4
                  try my fork
                  cd ~/MagicMirror/modules
                  rename the existing folder out of the way
                  git clone https://github.com/sdetweil/MMM-MPlayer
                  change the page config to have the hidden page and the
                  remote_control notification
                  I submitted this change to the module for inclusion, depending on your results.
                    mvrlogins @sdetweil
                    Maybe something to do with mplayer itself, not the module MMM-Mplayer?
                      sdetweil @mvrlogins
                      @mvrlogins no, i fixed in my fork
                        mvrlogins @sdetweil
                        Did as you suggested
                        The video appears only on page index 0 and not on the hidden page
                        See the 2 video images on the attached screenshot - both are over the weather module
                        The header for the MPlayer appears on the hidden page
                        I can change to the hidden page with Remote Control, no problem
                                    rotationTime: 1000 * 86400, // rotate every 20 seconds
                                 //       ["page2"],           // class name for page 2
                                //        ["page3"],           // class name for page 3
                                    hiddenPages: {
                                disabled: false,
                                header: "MPlayer",
                        	  layout: 'column',
                        	  monitorAspect: 0,
                        	  rotate: -1,
                        	  windowSize: { width: 640, height: 360 },
                        	  streams: {
                        		window1: [
                        		window2: [
                          mvrlogins @evroom
                          @evroom said in MMM-pages - how to know which page index my module has?:
                          As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
                          When I receive 0, then I will start streaming, otherwise I will stop streaming.
                          That seems to work.
                          @sdetweil Maybe something to do with this?
                            sdetweil @mvrlogins
                            @mvrlogins no. i added code to start streaming on hidden page,
                            let me check again.
                            you have my fork, right?
                            M evroomE 3 Replies Last reply Reply Quote 0
                              mvrlogins @sdetweil
                              Yes, using your fork
                                mvrlogins @sdetweil
                                The video appears on both pages.
                                The page with index 0 and the hidden page
                                  sdetweil @mvrlogins
                                  @mvrlogins ok, git pull in module folder…
                                  i didn’t stop the stream when switching away… or if there was another stream already running on page 0
                                  • evroomE
                                    evroom @sdetweil
                                    Hi, I notice some requests and other activities,here and on GitHub.
                                    Due to unforeseen medical issues, I do not have really time, nor the means to respond to everything
                                    Already happy I have some sort of Internet connection here.
                                    But with Sam it is in good hands, just make use of his fork.
                                    Greetings, E.J.
                                    MagicMirror version: 2.37.0
                                      sdetweil @evroom
                                      take care, this is not important in the grand scheme of things…
                                      I spent 2 months in hospital with Covid in 2021, luckily laptop, wifi , and MagicMirror kept me sane.
                                        mvrlogins @sdetweil
                                        Thanks for your help with this, Much appreciated
                                        I’m now away from the mirror for the weekend. I’ll give it a shot when I return on Tuesday
