    MMM-pages - how to know which page index my module has?
    29 Posts 4 Posters 10.5k Views 4 Watching
      sdetweil @mvrlogins
      @mvrlogins i believe so. but you should have been able to send the notification for the named hidden page
      “SHOW_HIDDEN_PAGE”, “Doorbell”
      right?!
        mvrlogins @sdetweil
        @sdetweil said in MMM-pages - how to know which page index my module has?:
        right?!
        Yes, the notification works fine.
        But mplayer does not show up on the hidden page, only on the main page
          sdetweil @mvrlogins
          @mvrlogins hm, that makes no sense as the MagicMirror operations are the same
            sdetweil @mvrlogins
            @mvrlogins i opened this issue
            https://github.com/evroom/MMM-MPlayer/issues/4
            try my fork
            cd ~/MagicMirror/modules
            rename the existing folder out of the way
            git clone https://github.com/sdetweil/MMM-MPlayer
            change the page config to have the hidden page and the
            remote_control notification
            I submitted this change to the module for inclusion, depending on your results.
              mvrlogins @sdetweil
              Maybe something to do with mplayer itself, not the module MMM-Mplayer?
                sdetweil @mvrlogins
                @mvrlogins no, i fixed in my fork
                  mvrlogins @sdetweil
                  Did as you suggested
                  The video appears only on page index 0 and not on the hidden page
                  See the 2 video images on the attached screenshot - both are over the weather module
                  The header for the MPlayer appears on the hidden page
                  I can change to the hidden page with Remote Control, no problem
                          module: "MMM-pages",
                              rotationTime: 1000 * 86400, // rotate every 20 seconds
                                  ["page1"],           // class name for page 1
                           //       ["page2"],           // class name for page 2
                          //        ["page3"],           // class name for page 3
                              fixed: ["fixed_page"],
                              hiddenPages: {
                                  "Doorbell": ["doorbell_page"],
                  	module: 'MMM-MPlayer',
                          classes: "doorbell_page",
                          disabled: false,
                          header: "MPlayer",
                  	  useTwoWindows: true,
                  	  layout: 'column',
                  	  monitorAspect: 0,
                  	  rotate: -1,
                  	  windowSize: { width: 640, height: 360 },
                  	  windowPosition: { x: 5, y: 225 },
                  	  streamInterval: 30000,
                  	  streams: {
                  		window1: [
                  		  'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN',
                  		window2: [
                  		  'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix',
                    mvrlogins @evroom
                    @evroom said in MMM-pages - how to know which page index my module has?:
                    As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
                    When I receive 0, then I will start streaming, otherwise I will stop streaming.
                    That seems to work.
                    @sdetweil Maybe something to do with this?
                      sdetweil @mvrlogins
                      @mvrlogins no. i added code to start streaming on hidden page,
                      let me check again.
                      you have my fork, right?
                      M evroomE 3 Replies Last reply Reply Quote 0
                        mvrlogins @sdetweil
                        Yes, using your fork
                          mvrlogins @sdetweil
                          The video appears on both pages.
                          The page with index 0 and the hidden page
                            sdetweil @mvrlogins
                            @mvrlogins ok, git pull in module folder…
                            i didn’t stop the stream when switching away… or if there was another stream already running on page 0
                            • evroomE
                              evroom @sdetweil
                              Hi, I notice some requests and other activities,here and on GitHub.
                              Due to unforeseen medical issues, I do not have really time, nor the means to respond to everything
                              Already happy I have some sort of Internet connection here.
                              But with Sam it is in good hands, just make use of his fork.
                              Greetings, E.J.
                              MagicMirror version: 2.37.0
                                sdetweil @evroom
                                take care, this is not important in the grand scheme of things…
                                I spent 2 months in hospital with Covid in 2021, luckily laptop, wifi , and MagicMirror kept me sane.
                                  mvrlogins @sdetweil
                                  Thanks for your help with this, Much appreciated
                                  I’m now away from the mirror for the weekend. I’ll give it a shot when I return on Tuesday
