    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 49.1k Views 10 Watching
      Dexter1088 @sdetweil
      Patch works perfect on Raspberry pi 3 B+, TYSM.
      • T
        Tiller
        the Ext3 module is showing events but only on 7 days including today. All following events are missing, although they show up in the default calendar module.
        I installed the fix, but the error is still there.
        Does anyone have an idea?
                                module: "MMM-CalendarExt3",
                                position: "bottom_bar",
                                title: "",
                                        waitFetch: 5000,
                                        mode: "week",
                                        weekIndex: 0,
                                        weeksInView: 3,
                                        instanceId: "basicCalendar",
                                        locale: "de-DE",
                                        maxEventLines: 5,
                                        firstDayOfWeek: 1,
                                        calendarSet: ['Family'],
        Best
        Till
          sdetweil @Tiller
          @Tiller
          Can you show the calendar config, xxx out the url
          • T
            Tiller
            This is my config of the default calendar module:
                                    header: "Calendar",
                                                            url: "xxx"
                                                            auth: {
        user: 'user',
        pass: 'password'
              sdetweil @Tiller
              @Tiller OK, can you show me the output of
              git branch
              • T
                Tiller
                I added the following to my default calendar module.
                maximumEntries: 60,
                maximumNumberOfDays: 21,
                limitDays: 21,
                fadePoint: 0.05,
                Now all the events are being displayed in the Ext3 module.
                I still got a problem.
                I want to show all events in the next 3 weeks in the Ext3 module, but I only want to display 10 events in the default module.
                Is there a way to do that?
                Best
                Till
                  sdetweil @Tiller
                  @Tiller do you have broadcast fix on
                  • T
                    Tiller
                    I installed the clipping fix from the start of this thread, if thats what you’re asking.
                    Otherwise I don’t know what the broadcast fix is.
                    Best
                    Till
                      sdetweil @Tiller
                      @Tiller yes, that is the one I meant.
                      Because you shouldn’t have to specify maxEntries with
                      It can you show the output of
                      git branch
                        svencarree @sdetweil
                        @sdetweil I’ve tried the hot fix but now I’ve got a black screen… What am i doing wrong?
                          sdetweil @svencarree
                          @svencarree did you npm run install-mm
                          after switching to the new branch?
                          • S Scott-M referenced this topic on
                          • R rkorell referenced this topic on
                            version 2.31.0 includes this fix
                            • 4 / 4
