    default calendar fetching issues
    21 Posts 3 Posters 7.9k Views 3 Watching
    • N Offline
      nowayto @sdetweil
      It’s very long.
      I checked the end paragraph ad I saw just errors from growatt module.
      Do I have to search something in particular?
        sdetweil @nowayto
        @nowayto said in default calendar fetching issues:
        I do not know
        can you recreate this if un restart MagicMirror? does it always fail in the morning?
        pm2 is really for production use,
        if you can repeat it
        pm2 stop all
        npm start &>somefile.txt
        wait til failure
        ctrl-q on MagicMirror screen
        then examine the somefile.txt
        • N Offline
          nowayto @sdetweil
          Recreated 2 times.
          First time calendar loaded Holidays calendar only
          [2025-03-19 22:23:55.917] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/**MYCAL**>
          [2025-03-19 22:23:56.467] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/**HOLIDAYPUBLICCAL**/publ>
          [2025-03-19 22:23:56.675] [LOG] Create new newsfetcher for url: https://www.ansa.it/sito/ansait_rss.xml - Interval: 300000
          [2025-03-19 22:23:56.698] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:23:56.836] [LOG] MMM-Formula1 received a notification: CONFIG
          [2025-03-19 22:23:56.838] [LOG] MMM-Formula1 is requesting the SCHEDULE on url https://api.jolpi.ca/ergast/f1/2025.json
          [2025-03-19 22:24:02.687] [INFO] updatenotification: Updater Class Loaded!
          [2025-03-19 22:24:02.733] [INFO] updatenotification: Checking PM2 using…
          [2025-03-19 22:24:02.735] [INFO] updatenotification: [PM2] You are not using pm2
          [2025-03-19 22:24:02.740] [INFO] Checking git for module: MMM-CalendarExt3
          [2025-03-19 22:24:03.525] [INFO] Checking git for module: MMM-Growatt
          [2025-03-19 22:24:03.850] [INFO] Checking git for module: MMM-Formula1
          [2025-03-19 22:24:04.283] [INFO] Checking git for module: MMM-RAIN-MAP
          [2025-03-19 22:24:07.693] [INFO] Checking git for module: MagicMirror
          [2025-03-19 22:24:08.072] [LOG] MMM-Formula1 is returning the SCHEDULE for the season
          [2025-03-19 22:24:40.393] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
          [2025-03-19 22:24:45.457] [INFO] Calendar-Fetcher: Broadcasting 61 events from https://calendar.google.com/calendar/**MYPRIVCAL**>
          [2025-03-19 22:24:46.745] [INFO] Calendar-Fetcher: Broadcasting 36 events from https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL/>
          [2025-03-19 22:24:57.986] [LOG] Publishing GROWATT data
          [2025-03-19 22:25:51.745] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:25:54.191] [LOG] Publishing GROWATT data
          [2025-03-19 22:27:51.368] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:27:53.447] [LOG] Publishing GROWATT data
          2nd time I got the error and no calendar loaded:
          [2025-03-19 22:32:06.388] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL**>
          [2025-03-19 22:32:07.767] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/**MYPRIVCAL**>
          [2025-03-19 22:32:07.881] [LOG] Create new newsfetcher for url: https://www.ansa.it/sito/ansait_rss.xml - Interval: 300000
          [2025-03-19 22:32:07.903] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:32:08.057] [INFO] updatenotification: Updater Class Loaded!
          [2025-03-19 22:32:08.059] [INFO] updatenotification: Checking PM2 using…
          [2025-03-19 22:32:08.063] [INFO] updatenotification: [PM2] You are not using pm2
          [2025-03-19 22:32:08.066] [INFO] Checking git for module: MMM-CalendarExt3
          [2025-03-19 22:32:08.132] [LOG] MMM-Formula1 received a notification: CONFIG
          [2025-03-19 22:32:08.134] [LOG] MMM-Formula1 is requesting the SCHEDULE on url https://api.jolpi.ca/ergast/f1/2025.json
          [2025-03-19 22:32:08.516] [INFO] Checking git for module: MMM-Growatt
          [2025-03-19 22:32:10.043] [INFO] Checking git for module: MMM-Formula1
          [2025-03-19 22:32:11.007] [INFO] Checking git for module: MMM-RAIN-MAP
          [2025-03-19 22:32:14.346] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
          [2025-03-19 22:32:14.404] [LOG] MMM-Formula1 is returning the SCHEDULE for the season
          [2025-03-19 22:32:14.414] [INFO] Checking git for module: MagicMirror
          [2025-03-19 22:32:48.815] [INFO] Calendar-Fetcher: Broadcasting 61 events from https://calendar.google.com/calendar/**MYPRIVCAL**>
          [2025-03-19 22:32:50.508] [INFO] Calendar-Fetcher: Broadcasting 36 events from https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL**>
          [2025-03-19 22:32:51.949] [LOG] Publishing GROWATT data
          [2025-03-19 22:34:08.485] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:34:14.955] [LOG] Publishing GROWATT data
          [2025-03-19 22:36:06.721] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:36:09.906] [LOG] Publishing GROWATT data
          [2025-03-19 22:37:16.339] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
          [2025-03-19 22:38:07.502] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:38:10.302] [LOG] Publishing GROWATT data
          [2025-03-19 22:40:09.496] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:40:12.087] [LOG] Publishing GROWATT data
          [2025-03-19 22:42:11.495] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:42:13.869] [LOG] Publishing GROWATT data
          [2025-03-19 22:42:16.743] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
          [2025-03-19 22:44:13.525] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:44:15.562] [LOG] Publishing GROWATT data
          [2025-03-19 22:46:15.496] [LOG] MMM-Growatt: GROWATT_GET_DATA
          [2025-03-19 22:46:17.289] [LOG] Publishing GROWATT data
          [2025-03-19 22:47:17.588] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
          [2025-03-19 22:47:20.690] [LOG] Shutting down server…
          [2025-03-19 22:47:20.696] [LOG] Stopping module helper: calendar
          Honestly… I don’t see nothing strange.
          But when this error appear, if I left MM on for a day, it wont load calendar entries.
          I have to restart it one or more time till it show entries
            sdetweil @nowayto
            @nowayto ok, disable the updatenotification module in config.js
            add
            disabled:true,
            after the
            module:line
            • N Offline
              nowayto @sdetweil
              I did it.
              I usually put the “disabled: true” before the module name line, instead of after
              Is it different?
                sdetweil @nowayto
                @nowayto no. just some users dont know what i mean
                • N Offline
                  nowayto @sdetweil
                  behaviour seems the same. I suspect this, could this issues be related to the raspberry pi 3 computing capacity? could it be not enough?
                  Is there a way to delay the pm2 automatic startup.
                  For example I though to try a delay of 1-2 minutes so:
                  1- raspbian startup
                  2- delay of 1-2 minutes to make sure all the services are up and the cpu is idle
                  3- mm startup
                  4- if it’s possible, I will add a delay to the modules startup also, maybe 20 seconds between every module loading
                  Honestly I checked his capacity a lot of times using the htop, free and cpu temperature command.
                  With my amazement I see everytime an amount of free memory, low cpu load and good cpu temp (like 40 to 50 degrees)
                  But if there is a way to delay everything, I’ll just check if with a “calmly” startup It will go better
                    sdetweil @nowayto
                    @nowayto i do not know on pm2
                    you could put a sleep 120
                    in the mm.sh to wait a while
                    how is swap space?
                    free -m
                    pi02w only has 512mb
                    • N Offline
                      nowayto @sdetweil
                      Yes I agree, the memory is very limiting.
                      Although mine is a Pi3 model A, but the memory is 512mb like the pi02w.
                      When I started the project I had something different in my mind and now I’m pushing it to the limit.
                      But as I said I checked everytime the CPU temperature, memory and generally resources usage from “htop” command.
                      This morning MM started with calendar error, I did a “pm2 restart mm” and goes OK.
                      Now I put “sleep 120” inside mm.sh as first line
                      I restarted it now
                      Memory BEFORE restart was this
                      total used free shared buff/cache available
                      Mem: 427 156 90 70 179 147
                      Swap: 1023 231 792
                      Not so good but not so bad, same time.
                      I’ll check if this delay could help.
                      Is there a way to put a little delay between the loading of every module ? Maybe 5/10 seconds, I though it could be very helpful on a limited machine like mine :)
                        sdetweil @nowayto
                        @nowayto there is no way to delay loading
                        • emloweE Offline
                          emlowe Module Developer
                          I had considerable problems with running on a model A - but I found dietPI (https://dietpi.com/) to be a solid distro that works well even when using the default electron GUI front-end. (Previously OOM’d consistently)
                          Note, also I frequently have trouble with the calendar events appears as there seems to be some problem in the websocket communication layer (this bug: https://github.com/MagicMirrorOrg/MagicMirror/issues/3380)
                          I basically use MMM-RemoteControl to force a refresh in a daily cron job (curl http://localhost:8080/api/refresh) and this works. Why? No One knows
                          • N Offline
                            nowayto @emlowe
                            @emlowe I have a similar problem, I solved modifing mm.sh with
                            sleep 30
                            DISPLAY=:0 npm start
                            sleep 60
                            pm2 restart mm
                            “pm2 restart mm” does a refresh like you do with RemoteControl
                              sdetweil @nowayto
                              @nowayto if pm2 is being used, its JOB is to keep the app running
                              so the pm2 restart seems odd as if the app was ended , ctrl-q
                              pm2 would do restart already
