    MMM-MPlayer
    44 Posts 10 Posters 19.5k Views 10 Watching
    • H
      hrmax23 @rkorell
      @rkorell I can autohide the taskbar but when it hides, it takes the MPlayer window with it.
      R 1 Reply Last reply
        rkorell Module Developer @hrmax23
        @hrmax23 O.K., never experienced this.
        But in my installation I rarely use MMM-MPlayer (it’s configured to have a look at my 3D-printer which seldomly is necessary), so I enable MPlayer module only if needed…
        Sorry, than I do not know…
        Ralf
        evroomE 1 Reply Last reply
        • evroomE
          evroom @rkorell
          When I tested the module, I used a Pi 3b connected to a 4K monitor and it was working okay.
          After reading about the MPlayer window, that appears in the center, I decided to test again.
          And to my surprise I have the same issue.
          It seems that MPlayer is ignoring the window position defined by the module.
          The GUI screen resolution is set to 1920x1080 @60Hz.
          Both xrandr and wlr-randr reflect this.
          On my Pi 4b, connected to a 1600x900 monitor, I do not have this issue.
          I did do an update & upgrade of Debian before looking at the issue, so it can be that something ‘broke’ the module.
          But then again I updated both Pis and only one has this issue.
          I will try to connect the 1600x900 monitor to the Pi 3b, so see if it is a monitor thing.
          All in all very odd.
          MagicMirror version: 2.37.0
            clakkentt @hrmax23
            @hrmax23
            Sorry I just got notified of your reply.
            I set the taskbar height to 0 and autohide. I don’t remember the exact steps I took
              clakkentt @hrmax23
              @hrmax23
              I don’t know why but the MPlayer header show up in the latest MMM-MPlayer update, at least in my setup, it does not show up in the previous version. I upgraded and then downgraded.
              • evroomE
                evroom @clakkentt
                @clakkentt said in MMM-MPlayer:
                @hrmax23
                Hi, could you please sent me the output of
                $ ps -eaf | grep mplayer | grep -v grep
                for the version that is working?
                I am currently busy with a new version, but I messed up a bit by not using a development branch.
                Hope to have sorted that out soon.
                The new version will have a bit different configuration setting than the old one.
                Also refer to
                https://forum.magicmirror.builders/topic/19539/mmm-mplayer-display-issue
                for the issue I am facing (related to what you are seeing with the new version).
                S C 2 Replies Last reply
                  sdetweil @evroom
                  @evroom said in MMM-MPlayer:
                  you can git stash ,
                  create/switch to branch, git checkout -b newbranch_name
                  git stash pop to move the changes to the branch (before commit)
                  • evroomE
                    evroom @sdetweil
                    There is a main branch now that contains the original code.
                    And a dev branch that contains the new code.
                    The new code needs a different entry in the config.js.
                      sdetweil @evroom
                      different README in this branch
                        clakkentt @evroom
                        @evroom
                        pi-mirr+ 25230 22066 53 11:17 ? 00:00:03 mplayer -noborder -monitoraspect 0 -vf rotate=-1 -geometry 450:100 -xy 352 288 rtsp://admin:password@192.168.0.85:554/cam/realmonitor?channel=1&subtype=1
                        Sorry for the delay in replying, I don’t get e-mail notices when someone replies to my posts.
                        S evroomE 2 Replies Last reply
                          sdetweil @clakkentt
                          you can change this in your profile
                          • evroomE
                            evroom @clakkentt
                            @evroom
                            No problem.
                            I discovered the reason why it happens and am busy with a new version.
                            Hope to release it soon (first need to solve an issue with recalculating the window position).
                            Those that are interested can have a look at the README of the dev branch.
                            • R rkorell referenced this topic on
                            • 3 / 3
