    MMM-MPlayer
    44 Posts 10 Posters 18.9k Views 10 Watching
      clakkentt @sdetweil
      Yes the problem is the same. I initially had MM running on a rpi3, when I installed MMM-MPlayer, I noticed the taskbar showing every time there was a feed showing.
      I started from scratch on an rpi4 and saw no problem but when I transferred the card to the rpi3 the issue came up again.
      Since I wanted to keep using the rpi3 for the MagicMirror I solved the problem by making the taskbar 0 pixels in height.
        sdetweil @clakkentt
        @clakkentt what do you mean by taskbar?
          clakkentt @sdetweil
          The desktop taskbar. On the raspberry the bar at the top of the screen.
          S H 2 Replies Last reply Reply Quote 0
            sdetweil @clakkentt
            @clakkentt it pops up over MagicMirror screen?
            C 2 Replies Last reply Reply Quote 0
              clakkentt @sdetweil
              Yes, when the MPlayer RTSP stream is running
                clakkentt @sdetweil
                I don’t know if this is the cause but I am using vcgencmd to turn the display off and on and to do that I had to disable vc4-kms-v3d
                  sdetweil @clakkentt
                  @clakkentt crazy. i don’t know either
                  • plainbrokeP Offline
                    plainbroke @sdetweil
                    Wonder what he is using for his x and y start position in MMM-MPlayer.
                    windowPosition: { x: 5, y: 5 },
                    If I remember correctly.
                    • R rkorell referenced this topic on
                      clakkentt @plainbroke
                      @plainbroke
                      No, I have the window in the middle of the screen, something like x: 450, y: 100
                      • H Offline
                        hrmax23 @clakkentt
                        @clakkentt I’m having the same issues on my rpi4. How did you hide the taskbar?
                        R C 2 Replies Last reply Reply Quote 0
                        • H Offline
                          hrmax23
                          Also, I have 2 windows, one RTSP stream from Frigate in each, but there is a lot of extra space between them and above the first window. Would also like to get rid of the MPLAYER header if possible.
                            rkorell Module Developer @hrmax23
                            @hrmax23 said
                            @clakkentt How did you hide the taskbar?
                            Good morning,
                            I did have this taskbar issue suddenly appearing as I upgraded to a larger monitor. Caused by this I increased the screen resolution.
                            After this I had the annoying taskbar appearing more or less randomly.
                            Played a lot with colors/height/position of the taskbar …
                            And while playing around I found an option in screen-config tool.
                            For some (really strange) reasons it seems that this setting is dependent on screen resolution !?
                            So it’s may worth a trial to stop your MagicMirror so that you can see the native Pi-OS screen and find the screen config tool - there you should be able to hide the taskbar as well …
                            Good luck!
                            Regards,
                            Ralf
                            • H Offline
                              hrmax23 @rkorell
                              @rkorell I can autohide the taskbar but when it hides, it takes the MPlayer window with it.
                                @hrmax23 O.K., never experienced this.
                                But in my installation I rarely use MMM-MPlayer (it’s configured to have a look at my 3D-printer which seldomly is necessary), so I enable MPlayer module only if needed…
                                Sorry, than I do not know…
                                Ralf
                                • evroomE Offline
                                  evroom @rkorell
                                  When I tested the module, I used a Pi 3b connected to a 4K monitor and it was working okay.
                                  After reading about the MPlayer window, that appears in the center, I decided to test again.
                                  And to my surprise I have the same issue.
                                  It seems that MPlayer is ignoring the window position defined by the module.
                                  The GUI screen resolution is set to 1920x1080 @60Hz.
                                  Both xrandr and wlr-randr reflect this.
                                  On my Pi 4b, connected to a 1600x900 monitor, I do not have this issue.
                                  I did do an update & upgrade of Debian before looking at the issue, so it can be that something ‘broke’ the module.
                                  But then again I updated both Pis and only one has this issue.
                                  I will try to connect the 1600x900 monitor to the Pi 3b, so see if it is a monitor thing.
                                  All in all very odd.
                                  MagicMirror version: 2.37.0
                                    clakkentt @hrmax23
                                    @hrmax23
                                    Sorry I just got notified of your reply.
                                    I set the taskbar height to 0 and autohide. I don’t remember the exact steps I took
                                      clakkentt @hrmax23
                                      @hrmax23
                                      I don’t know why but the MPlayer header show up in the latest MMM-MPlayer update, at least in my setup, it does not show up in the previous version. I upgraded and then downgraded.
                                      • evroomE Offline
                                        evroom @clakkentt
                                        @clakkentt said in MMM-MPlayer:
                                        @hrmax23
                                        Hi, could you please sent me the output of
                                        $ ps -eaf | grep mplayer | grep -v grep
                                        for the version that is working?
                                        I am currently busy with a new version, but I messed up a bit by not using a development branch.
                                        Hope to have sorted that out soon.
                                        The new version will have a bit different configuration setting than the old one.
                                        Also refer to
                                        https://forum.magicmirror.builders/topic/19539/mmm-mplayer-display-issue
                                        for the issue I am facing (related to what you are seeing with the new version).
                                        S C 2 Replies Last reply Reply Quote 0
                                          sdetweil @evroom
                                          @evroom said in MMM-MPlayer:
                                          you can git stash ,
                                          create/switch to branch, git checkout -b newbranch_name
                                          git stash pop to move the changes to the branch (before commit)
                                          • evroomE Offline
                                            evroom @sdetweil
                                            There is a main branch now that contains the original code.
                                            And a dev branch that contains the new code.
                                            The new code needs a different entry in the config.js.
                                            • 2 / 3
