    MMM-MPlayer
    44 Posts 10 Posters 19.4k Views 10 Watching
      sdetweil @clakkentt
      @clakkentt it pops up over MagicMirror screen?
      C 2 Replies Last reply Reply Quote 0
        clakkentt @sdetweil
        Yes, when the MPlayer RTSP stream is running
          clakkentt @sdetweil
          I don’t know if this is the cause but I am using vcgencmd to turn the display off and on and to do that I had to disable vc4-kms-v3d
            sdetweil @clakkentt
            @clakkentt crazy. i don’t know either
            • plainbrokeP
              plainbroke @sdetweil
              Wonder what he is using for his x and y start position in MMM-MPlayer.
              windowPosition: { x: 5, y: 5 },
              If I remember correctly.
              • R rkorell referenced this topic on
                clakkentt @plainbroke
                @plainbroke
                No, I have the window in the middle of the screen, something like x: 450, y: 100
                • H
                  hrmax23 @clakkentt
                  @clakkentt I’m having the same issues on my rpi4. How did you hide the taskbar?
                  R C 2 Replies Last reply Reply Quote 0
                  • H
                    hrmax23
                    Also, I have 2 windows, one RTSP stream from Frigate in each, but there is a lot of extra space between them and above the first window. Would also like to get rid of the MPLAYER header if possible.
                      rkorell Module Developer @hrmax23
                      @hrmax23 said
                      @clakkentt How did you hide the taskbar?
                      Good morning,
                      I did have this taskbar issue suddenly appearing as I upgraded to a larger monitor. Caused by this I increased the screen resolution.
                      After this I had the annoying taskbar appearing more or less randomly.
                      Played a lot with colors/height/position of the taskbar …
                      And while playing around I found an option in screen-config tool.
                      For some (really strange) reasons it seems that this setting is dependent on screen resolution !?
                      So it’s may worth a trial to stop your MagicMirror so that you can see the native Pi-OS screen and find the screen config tool - there you should be able to hide the taskbar as well …
                      Good luck!
                      Regards,
                      Ralf
                      • H
                        hrmax23 @rkorell
                        @rkorell I can autohide the taskbar but when it hides, it takes the MPlayer window with it.
                          @hrmax23 O.K., never experienced this.
                          But in my installation I rarely use MMM-MPlayer (it’s configured to have a look at my 3D-printer which seldomly is necessary), so I enable MPlayer module only if needed…
                          Sorry, than I do not know…
                          Ralf
                          • evroomE
                            evroom @rkorell
                            When I tested the module, I used a Pi 3b connected to a 4K monitor and it was working okay.
                            After reading about the MPlayer window, that appears in the center, I decided to test again.
                            And to my surprise I have the same issue.
                            It seems that MPlayer is ignoring the window position defined by the module.
                            The GUI screen resolution is set to 1920x1080 @60Hz.
                            Both xrandr and wlr-randr reflect this.
                            On my Pi 4b, connected to a 1600x900 monitor, I do not have this issue.
                            I did do an update & upgrade of Debian before looking at the issue, so it can be that something ‘broke’ the module.
                            But then again I updated both Pis and only one has this issue.
                            I will try to connect the 1600x900 monitor to the Pi 3b, so see if it is a monitor thing.
                            All in all very odd.
                            MagicMirror version: 2.37.0
                              clakkentt @hrmax23
                              @hrmax23
                              Sorry I just got notified of your reply.
                              I set the taskbar height to 0 and autohide. I don’t remember the exact steps I took
                                clakkentt @hrmax23
                                @hrmax23
                                I don’t know why but the MPlayer header show up in the latest MMM-MPlayer update, at least in my setup, it does not show up in the previous version. I upgraded and then downgraded.
                                • evroomE
                                  evroom @clakkentt
                                  @clakkentt said in MMM-MPlayer:
                                  @hrmax23
                                  Hi, could you please sent me the output of
                                  $ ps -eaf | grep mplayer | grep -v grep
                                  for the version that is working?
                                  I am currently busy with a new version, but I messed up a bit by not using a development branch.
                                  Hope to have sorted that out soon.
                                  The new version will have a bit different configuration setting than the old one.
                                  Also refer to
                                  https://forum.magicmirror.builders/topic/19539/mmm-mplayer-display-issue
                                  for the issue I am facing (related to what you are seeing with the new version).
                                  S C 2 Replies Last reply Reply Quote 0
                                    sdetweil @evroom
                                    @evroom said in MMM-MPlayer:
                                    you can git stash ,
                                    create/switch to branch, git checkout -b newbranch_name
                                    git stash pop to move the changes to the branch (before commit)
                                    • evroomE
                                      evroom @sdetweil
                                      There is a main branch now that contains the original code.
                                      And a dev branch that contains the new code.
                                      The new code needs a different entry in the config.js.
                                        sdetweil @evroom
                                        different README in this branch
                                          clakkentt @evroom
                                          @evroom
                                          pi-mirr+ 25230 22066 53 11:17 ? 00:00:03 mplayer -noborder -monitoraspect 0 -vf rotate=-1 -geometry 450:100 -xy 352 288 rtsp://admin:password@192.168.0.85:554/cam/realmonitor?channel=1&subtype=1
                                          Sorry for the delay in replying, I don’t get e-mail notices when someone replies to my posts.
                                          S evroomE 2 Replies Last reply Reply Quote 0
                                            sdetweil @clakkentt
                                            you can change this in your profile
                                            • 2 / 3
