    MMM-MPlayer
    44 Posts 10 Posters 18.9k Views 10 Watching
      sdetweil @clakkentt
      @clakkentt if you use my backup/restore to capture your MM config
      and build a new card ON the pi3, and install MM and restore the config
      do you see the same problem?
      backup/restore here https://github.com/sdetweil/MagicMirror-backup-restore
      install/upgrade here https://github.com/sdetweil/MagicMirror_scripts
        clakkentt @sdetweil
        Yes the problem is the same. I initially had MM running on a rpi3, when I installed MMM-MPlayer, I noticed the taskbar showing every time there was a feed showing.
        I started from scratch on an rpi4 and saw no problem but when I transferred the card to the rpi3 the issue came up again.
        Since I wanted to keep using the rpi3 for the MagicMirror I solved the problem by making the taskbar 0 pixels in height.
          sdetweil @clakkentt
          @clakkentt what do you mean by taskbar?
            clakkentt @sdetweil
            The desktop taskbar. On the raspberry the bar at the top of the screen.
            S H 2 Replies Last reply Reply Quote 0
              sdetweil @clakkentt
              @clakkentt it pops up over MagicMirror screen?
              C 2 Replies Last reply Reply Quote 0
                clakkentt @sdetweil
                Yes, when the MPlayer RTSP stream is running
                  clakkentt @sdetweil
                  I don’t know if this is the cause but I am using vcgencmd to turn the display off and on and to do that I had to disable vc4-kms-v3d
                    sdetweil @clakkentt
                    @clakkentt crazy. i don’t know either
                    • plainbrokeP Offline
                      plainbroke @sdetweil
                      Wonder what he is using for his x and y start position in MMM-MPlayer.
                      windowPosition: { x: 5, y: 5 },
                      If I remember correctly.
                      • R rkorell referenced this topic on
                        clakkentt @plainbroke
                        @plainbroke
                        No, I have the window in the middle of the screen, something like x: 450, y: 100
                        • H Offline
                          hrmax23 @clakkentt
                          @clakkentt I’m having the same issues on my rpi4. How did you hide the taskbar?
                          R C 2 Replies Last reply Reply Quote 0
                          • H Offline
                            hrmax23
                            Also, I have 2 windows, one RTSP stream from Frigate in each, but there is a lot of extra space between them and above the first window. Would also like to get rid of the MPLAYER header if possible.
                              rkorell Module Developer @hrmax23
                              @hrmax23 said
                              @clakkentt How did you hide the taskbar?
                              Good morning,
                              I did have this taskbar issue suddenly appearing as I upgraded to a larger monitor. Caused by this I increased the screen resolution.
                              After this I had the annoying taskbar appearing more or less randomly.
                              Played a lot with colors/height/position of the taskbar …
                              And while playing around I found an option in screen-config tool.
                              For some (really strange) reasons it seems that this setting is dependent on screen resolution !?
                              So it’s may worth a trial to stop your MagicMirror so that you can see the native Pi-OS screen and find the screen config tool - there you should be able to hide the taskbar as well …
                              Good luck!
                              Regards,
                              Ralf
                              • H Offline
                                hrmax23 @rkorell
                                @rkorell I can autohide the taskbar but when it hides, it takes the MPlayer window with it.
                                  @hrmax23 O.K., never experienced this.
                                  But in my installation I rarely use MMM-MPlayer (it’s configured to have a look at my 3D-printer which seldomly is necessary), so I enable MPlayer module only if needed…
                                  Sorry, than I do not know…
                                  Ralf
                                  • evroomE Offline
                                    evroom @rkorell
                                    When I tested the module, I used a Pi 3b connected to a 4K monitor and it was working okay.
                                    After reading about the MPlayer window, that appears in the center, I decided to test again.
                                    And to my surprise I have the same issue.
                                    It seems that MPlayer is ignoring the window position defined by the module.
                                    The GUI screen resolution is set to 1920x1080 @60Hz.
                                    Both xrandr and wlr-randr reflect this.
                                    On my Pi 4b, connected to a 1600x900 monitor, I do not have this issue.
                                    I did do an update & upgrade of Debian before looking at the issue, so it can be that something ‘broke’ the module.
                                    But then again I updated both Pis and only one has this issue.
                                    I will try to connect the 1600x900 monitor to the Pi 3b, so see if it is a monitor thing.
                                    All in all very odd.
                                    MagicMirror version: 2.37.0
                                      clakkentt @hrmax23
                                      @hrmax23
                                      Sorry I just got notified of your reply.
                                      I set the taskbar height to 0 and autohide. I don’t remember the exact steps I took
                                        clakkentt @hrmax23
                                        @hrmax23
                                        I don’t know why but the MPlayer header show up in the latest MMM-MPlayer update, at least in my setup, it does not show up in the previous version. I upgraded and then downgraded.
                                        • evroomE Offline
                                          evroom @clakkentt
                                          @clakkentt said in MMM-MPlayer:
                                          @hrmax23
                                          Hi, could you please sent me the output of
                                          $ ps -eaf | grep mplayer | grep -v grep
                                          for the version that is working?
                                          I am currently busy with a new version, but I messed up a bit by not using a development branch.
                                          Hope to have sorted that out soon.
                                          The new version will have a bit different configuration setting than the old one.
                                          Also refer to
                                          https://forum.magicmirror.builders/topic/19539/mmm-mplayer-display-issue
                                          for the issue I am facing (related to what you are seeing with the new version).
                                          S C 2 Replies Last reply Reply Quote 0
                                            sdetweil @evroom
                                            @evroom said in MMM-MPlayer:
                                            you can git stash ,
                                            create/switch to branch, git checkout -b newbranch_name
                                            git stash pop to move the changes to the branch (before commit)
                                            • 2 / 3
