    MMM-MPlayer
    44 Posts 10 Posters 19.9k Views 10 Watching
    • Cr4z33C
      Cr4z33 @myfingersarecold
      @myfingersarecold said in MMM-MPlayer:
      I couldnt get the EXT-FreeboxTV module to work on my magic mirror
      Out of curiosity what was the issue with it?
      I use that module all the time to watch the TV channels of my Enigma2 decoder.
      M 1 Reply Last reply
      • evroomE
        evroom @myfingersarecold
        regarding #2 on my pi i didnt have to rotate the mplayer orientation, but i adjusted the output of my pi to portrait and everything behaved but ymmv depending on how it’s setup.
        Could you please tell me how you do the general rotation to portrait ?
        I use the custom.css to get it rotated clockwise.
        As MPlayer is an overlay, like OMXPlayer, it is not affected by this.
        body {
          transform: rotate(-90deg);
          transform-origin: top left;
          width: 100vh;
          height: 100vw;
        But of course there are more, potential better, ways of getting it rotated.
        MagicMirror version: 2.37.0
          myfingersarecold @evroom
          @evroom
          i didnt use this guide to do it, but this is how i rotated my screen.
          https://www.makeuseof.com/how-to-rotate-your-raspberry-pi-screen-without-moving-the-display/
          I am running the latest version of raspbian on my pi3
          this results in my magicmirror instance loading in portrait mode, and my 16x9 streams loading properly where i want them without having to do any CSS rotation.
            myfingersarecold @Cr4z33
            @Cr4z33 no idea but couldn’t get RTSP streams to work.
            • G
              Guku
              HI, im running my MM on on Proxmox VM and pointing my display to IP on VM, when i try to run Mplayer it just displays black box but no feed, i doo see the feed on the server VM. any ideas how to get this playing on my remote display?
                sdetweil @Guku
                @Guku did you expose that port on the vm to another connecting host?
                maybe a firewall filter?
                I don’t use proxmox, but I see this on windows VM’s all the time
                G 1 Reply Last reply
                • G
                  Guku @sdetweil
                  thanks for checking in with me, i gave up on the player since even when i ran it localy on my VM the camera feed was delayed by about 5sec which defeted the pourpose. thanks anyways!
                    clakkentt
                    Just a comment
                    I am using MagicMirror on a pi using bullseye 32bit.
                    When using a rpi4 everything works fine. When I transfer the sd card to a rpi3 every time the MPlayer shows a live feed the desktop taskbar shows up, when MPlayer is switching between feeds the taskbar is not visible.
                    This is probably due to my specific choice of settings but just thought it might help someone.
                      sdetweil @clakkentt
                      @clakkentt if you use my backup/restore to capture your MM config
                      and build a new card ON the pi3, and install MM and restore the config
                      do you see the same problem?
                      backup/restore here https://github.com/sdetweil/MagicMirror-backup-restore
                      install/upgrade here https://github.com/sdetweil/MagicMirror_scripts
                      C 1 Reply Last reply
                        clakkentt @sdetweil
                        Yes the problem is the same. I initially had MM running on a rpi3, when I installed MMM-MPlayer, I noticed the taskbar showing every time there was a feed showing.
                        I started from scratch on an rpi4 and saw no problem but when I transferred the card to the rpi3 the issue came up again.
                        Since I wanted to keep using the rpi3 for the MagicMirror I solved the problem by making the taskbar 0 pixels in height.
                          sdetweil @clakkentt
                          @clakkentt what do you mean by taskbar?
                            clakkentt @sdetweil
                            The desktop taskbar. On the raspberry the bar at the top of the screen.
                            S H 2 Replies Last reply
                              sdetweil @clakkentt
                              @clakkentt it pops up over MagicMirror screen?
                              C 2 Replies Last reply
                                clakkentt @sdetweil
                                Yes, when the MPlayer RTSP stream is running
                                  clakkentt @sdetweil
                                  I don’t know if this is the cause but I am using vcgencmd to turn the display off and on and to do that I had to disable vc4-kms-v3d
                                    sdetweil @clakkentt
                                    @clakkentt crazy. i don’t know either
                                    plainbrokeP 1 Reply Last reply
                                    • plainbrokeP
                                      plainbroke @sdetweil
                                      Wonder what he is using for his x and y start position in MMM-MPlayer.
                                      windowPosition: { x: 5, y: 5 },
                                      If I remember correctly.
                                      • R rkorell referenced this topic on
                                        clakkentt @plainbroke
                                        @plainbroke
                                        No, I have the window in the middle of the screen, something like x: 450, y: 100
                                        • H
                                          hrmax23 @clakkentt
                                          @clakkentt I’m having the same issues on my rpi4. How did you hide the taskbar?
                                          R C 2 Replies Last reply
                                          • H
                                            hrmax23
                                            Also, I have 2 windows, one RTSP stream from Frigate in each, but there is a lot of extra space between them and above the first window. Would also like to get rid of the MPLAYER header if possible.
                                            • 2 / 3
