    MMM-MPlayer
    44 Posts 10 Posters 19.9k Views 10 Watching
      sdetweil @clakkentt
      @clakkentt what do you mean by taskbar?
      C 1 Reply Last reply
        clakkentt @sdetweil
        The desktop taskbar. On the raspberry the bar at the top of the screen.
        S H 2 Replies Last reply
          sdetweil @clakkentt
          @clakkentt it pops up over MagicMirror screen?
          C 2 Replies Last reply
            clakkentt @sdetweil
            Yes, when the MPlayer RTSP stream is running
              clakkentt @sdetweil
              I don’t know if this is the cause but I am using vcgencmd to turn the display off and on and to do that I had to disable vc4-kms-v3d
                sdetweil @clakkentt
                @clakkentt crazy. i don’t know either
                plainbrokeP 1 Reply Last reply
                • plainbrokeP
                  plainbroke @sdetweil
                  Wonder what he is using for his x and y start position in MMM-MPlayer.
                  windowPosition: { x: 5, y: 5 },
                  If I remember correctly.
                  • R rkorell referenced this topic on
                    clakkentt @plainbroke
                    @plainbroke
                    No, I have the window in the middle of the screen, something like x: 450, y: 100
                    • H
                      hrmax23 @clakkentt
                      @clakkentt I’m having the same issues on my rpi4. How did you hide the taskbar?
                      R C 2 Replies Last reply
                      • H
                        hrmax23
                        Also, I have 2 windows, one RTSP stream from Frigate in each, but there is a lot of extra space between them and above the first window. Would also like to get rid of the MPLAYER header if possible.
                          rkorell Module Developer @hrmax23
                          @hrmax23 said
                          @clakkentt How did you hide the taskbar?
                          Good morning,
                          I did have this taskbar issue suddenly appearing as I upgraded to a larger monitor. Caused by this I increased the screen resolution.
                          After this I had the annoying taskbar appearing more or less randomly.
                          Played a lot with colors/height/position of the taskbar …
                          And while playing around I found an option in screen-config tool.
                          For some (really strange) reasons it seems that this setting is dependent on screen resolution !?
                          So it’s may worth a trial to stop your MagicMirror so that you can see the native Pi-OS screen and find the screen config tool - there you should be able to hide the taskbar as well …
                          Good luck!
                          Regards,
                          Ralf
                          H 1 Reply Last reply
                          • H
                            hrmax23 @rkorell
                            @rkorell I can autohide the taskbar but when it hides, it takes the MPlayer window with it.
                            R 1 Reply Last reply
                              @hrmax23 O.K., never experienced this.
                              But in my installation I rarely use MMM-MPlayer (it’s configured to have a look at my 3D-printer which seldomly is necessary), so I enable MPlayer module only if needed…
                              Sorry, than I do not know…
                              Ralf
                              evroomE 1 Reply Last reply
                              • evroomE
                                evroom @rkorell
                                When I tested the module, I used a Pi 3b connected to a 4K monitor and it was working okay.
                                After reading about the MPlayer window, that appears in the center, I decided to test again.
                                And to my surprise I have the same issue.
                                It seems that MPlayer is ignoring the window position defined by the module.
                                The GUI screen resolution is set to 1920x1080 @60Hz.
                                Both xrandr and wlr-randr reflect this.
                                On my Pi 4b, connected to a 1600x900 monitor, I do not have this issue.
                                I did do an update & upgrade of Debian before looking at the issue, so it can be that something ‘broke’ the module.
                                But then again I updated both Pis and only one has this issue.
                                I will try to connect the 1600x900 monitor to the Pi 3b, so see if it is a monitor thing.
                                All in all very odd.
                                MagicMirror version: 2.37.0
                                  clakkentt @hrmax23
                                  @hrmax23
                                  Sorry I just got notified of your reply.
                                  I set the taskbar height to 0 and autohide. I don’t remember the exact steps I took
                                    clakkentt @hrmax23
                                    @hrmax23
                                    I don’t know why but the MPlayer header show up in the latest MMM-MPlayer update, at least in my setup, it does not show up in the previous version. I upgraded and then downgraded.
                                    • evroomE
                                      evroom @clakkentt
                                      @clakkentt said in MMM-MPlayer:
                                      @hrmax23
                                      Hi, could you please sent me the output of
                                      $ ps -eaf | grep mplayer | grep -v grep
                                      for the version that is working?
                                      I am currently busy with a new version, but I messed up a bit by not using a development branch.
                                      Hope to have sorted that out soon.
                                      The new version will have a bit different configuration setting than the old one.
                                      Also refer to
                                      https://forum.magicmirror.builders/topic/19539/mmm-mplayer-display-issue
                                      for the issue I am facing (related to what you are seeing with the new version).
                                      S C 2 Replies Last reply
                                        sdetweil @evroom
                                        @evroom said in MMM-MPlayer:
                                        you can git stash ,
                                        create/switch to branch, git checkout -b newbranch_name
                                        git stash pop to move the changes to the branch (before commit)
                                        • evroomE
                                          evroom @sdetweil
                                          There is a main branch now that contains the original code.
                                          And a dev branch that contains the new code.
                                          The new code needs a different entry in the config.js.
                                            sdetweil @evroom
                                            different README in this branch
                                            • 2 / 3
