    Restore script cannot create Backup folder?
    13 Posts 2 Posters 2.1k Views 2 Watching
      rkorell
      Dear Sam (@sdetweil ),
      Just trying to restore my config from github but the restore fails because it cannot create the MM_backup folder?
      Must I create this directory upfront?
      screen output as follows:
      pi@MagicMirrorPi5:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)" -r https://github.com/rkorell/MagicMirror -f
      restoring MM configuration from /home/pi/MM_backup to /home/pi/MagicMirror
      trying to fetch MagicMirror from github
      folder /home/pi/MM_backup does not exist, will clone it from github
      unable to create backup folder /home/pi/MM_backup
      Thanks,
      Ralf
        sdetweil @rkorell
        @rkorell oops bug, rerun
          sdetweil @rkorell
          @rkorell hmmmmm . out w family til later
            rkorell @sdetweil
            @sdetweil Don’t worry!
            Have fun with your family!
            Will stop then until tomorrow -take your time!!!
              sdetweil @rkorell
                rkorell @sdetweil
                @sdetweil cool, THANKS!
                script now is doing something :-)
                I’m really curious…
                Ralf
                  rkorell @sdetweil
                  @sdetweil has worked :-)
                  Username for 'https://github.com': rkorell
                  Password for 'https://rkorell@github.com':
                  created git branch from last tag = 10
                  restored config.js and custom.css
                  restoring birthdaylist
                  module birthdaylist contains package.json, doing npm install
                  restoring internet-monitor
                  module internet-monitor contains package.json, doing npm install
                  restoring MMM-Bring
                  module MMM-Bring contains package.json, doing npm install
                  there were files saved for this module , restoring
                  restoring MMM-CalendarExt3Agenda
                  restoring MMM-Config
                  module MMM-Config contains package.json, doing npm install
                  restoring MMM-EventHorizon
                  module MMM-EventHorizon DOES NOT contain package.json
                  restoring MMM-FrameLight
                  restoring MMM-FRITZ-Box-Callmonitor-py3
                  module MMM-FRITZ-Box-Callmonitor-py3 contains package.json, doing npm install
                  restoring MMM-Fuel
                  module MMM-Fuel contains package.json, doing npm install
                  restoring MMM-Globe
                  restoring MMM-JsonValue
                  module MMM-JsonValue contains package.json, doing npm install
                  restoring MMM-LogExt
                  module MMM-LogExt DOES NOT contain package.json
                  restoring MMM-Logging
                  module MMM-Logging contains package.json, doing npm install
                  restoring MMM-MagicMover
                  restoring MMM-MoonPhase
                  restoring MMM-MPlayer
                  restoring MMM-MyGarbage
                  module MMM-MyGarbage contains package.json, doing npm install
                  restoring MMM-NotificationTrigger
                  module MMM-NotificationTrigger DOES NOT contain package.json
                  restoring MMM-NowPlayingOnSpotify
                  module MMM-NowPlayingOnSpotify contains package.json, doing npm install
                  restoring MMM-Profilepicture
                  module MMM-Profilepicture DOES NOT contain package.json
                  restoring MMM-Remote-Control
                  module MMM-Remote-Control contains package.json, doing npm install
                  restoring MMM-Strava
                  module MMM-Strava contains package.json, doing npm install
                  restoring MMM-SweepClock
                  restoring MMM-SystemInfo
                  module MMM-SystemInfo DOES NOT contain package.json
                  restoring MMM-SystemStats
                  module MMM-SystemStats contains package.json, doing npm install
                  restoring MMM-Temp2IOT
                  module MMM-Temp2IOT DOES NOT contain package.json
                  restoring MMM-Todoist
                  module MMM-Todoist contains package.json, doing npm install
                  restoring MMM-ViewNotifications
                  module MMM-ViewNotifications DOES NOT contain package.json
                  restoring MMM-WiFiPassword
                  module MMM-WiFiPassword DOES NOT contain package.json
                  grep: MMM-LogExt
                  MMM-Strava
                  MMM-JsonValue
                  MMM-Remote-Control
                  MMM-MyGarbage
                  MMM-Bring
                  MMM-SystemStats
                  internet-monitor
                  MMM-Config
                  MMM-MoonPhase
                  MMM-Temp2IOT
                  MMM-Todoist
                  MMM-Fuel
                  MMM-SystemInfo
                  birthdaylist
                  MMM-Logging
                  MMM-MPlayer
                  MMM-FrameLight
                  MMM-NowPlayingOnSpotify/node_helper.js: File name too long
                  restore completed, you can start MagicMirror now
                  Now have to check what is working, what not …
                    rkorell @rkorell
                    @sdetweil WOW!
                    nearly all is working!
                    Some local modifications are not catched (e.g. datafile for birthdaylist (to illustrate what I mean - you are somewhat familiar with birthdaylist :-) ) ).
                    For unknown reasons “MMM-CalendarExt3Agenda” is not showing up - I may have to apply the fix I had seen somehow (have NOT to use this fix on my Pi4 with same mirror version (2.30.0))
                    Calendar fetches are present (checked log) so it seems an error in C3A …
                    By checking log I found a never seen error:
                    0|MagicMir |     at node:internal/deps/undici/undici:13392:13
                    0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                    0|MagicMir |   [cause]: ConnectTimeoutError: Connect Timeout Error (attempted addresses: 151.101.193.164:443, 151.101.65.164:443, 151.101.129.164:443, 151.101.1.164:443, timeout: 30000ms)
                    0|MagicMir |       at onConnectTimeout (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:237:24)
                    0|MagicMir |       at Immediate._onImmediate (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:206:11)
                    0|MagicMir |       at process.processImmediate (node:internal/timers:483:21) {
                    0|MagicMir |     code: 'UND_ERR_CONNECT_TIMEOUT'
                    0|MagicMir |   }
                    0|MagicMir | }
                    0|MagicMir | [2025-03-26 04:50:09.238] [ERROR] Failed to retrieve repo info for MagicMirror: Error: Command failed: cd /home/pi/MagicMirror/ && git fetch -n --dry-run
                    0|MagicMir | fatal: unable to access 'https://github.com/MagicMirrorOrg/MagicMirror.git/': Failed to connect to github.com port 443 after 133356 ms: Couldn't connect to server
                    is this related to auto-update?
                    And another question: On my other Mirror a restart happens when I write config.js back to raspi - this doesn’t happen on new system - can I enable this with a parameter somehow I have missed?
                    Thanks a LOT for your great script and your effort behind!
                    Ralf
                    R S 2 Replies Last reply Reply Quote 0
                      rkorell @rkorell
                      sorry, still another question…
                      Your backup-script has stored the famous MMM-Pir (bugsounet’s) on my git-repository.
                      The restore script does not restore this directory (I guess because the origin git repo doesn’t exist anymore - which makes sense).
                      But I would at least try to get this up and running again…
                      Can I restore this directory manually?
                      And if possible is this done with a fully qualified path or somehow different?
                      (meaning “https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir”)
                      so would my command be:
                      git clone https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir
                      or
                      git clone https://github.com/rkorell/MagicMirror/MMM-Pir
                      Or do I have to transfer my tar file to the new raspi and unpack it there?
                      Thanks for guidance!
                      Ralf
                        sdetweil @rkorell
                        @rkorell said in Restore script cannot create Backup folder?:
                        you could edit the MM_backup/module_list file and change the url
                        and then restore from the local MM_backup to test
                        if good then do another backup to make a new tag of the updated state (with the corrected url)
                          rkorell @sdetweil
                          @sdetweil Thanks.
                          IN the meantime I’ve figured out that the MM-Pir directorry in github repo (backup) only contains four files, so is useless for restoring…
