    Restore script cannot create Backup folder?
    13 Posts 2 Posters 3.0k Views 2 Watching
      sdetweil @rkorell
      @rkorell oops bug, rerun
        @sdetweil cool, THANKS!
        script now is doing something :-)
        I’m really curious…
        Ralf
          @sdetweil has worked :-)
          pi@MagicMirrorPi5:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)" -r https://github.com/rkorell/MagicMirror -f
          restoring MM configuration from /home/pi/MM_backup to /home/pi/MagicMirror
          trying to fetch MagicMirror from github
          folder /home/pi/MM_backup does not exist, will clone it from github
          Username for 'https://github.com': rkorell
          Password for 'https://rkorell@github.com':
          created git branch from last tag = 10
          restored config.js and custom.css
          restoring birthdaylist
          module birthdaylist contains package.json, doing npm install
          restoring internet-monitor
          module internet-monitor contains package.json, doing npm install
          restoring MMM-Bring
          module MMM-Bring contains package.json, doing npm install
          there were files saved for this module , restoring
          restoring MMM-CalendarExt3Agenda
          restoring MMM-Config
          module MMM-Config contains package.json, doing npm install
          restoring MMM-EventHorizon
          module MMM-EventHorizon DOES NOT contain package.json
          restoring MMM-FrameLight
          restoring MMM-FRITZ-Box-Callmonitor-py3
          module MMM-FRITZ-Box-Callmonitor-py3 contains package.json, doing npm install
          restoring MMM-Fuel
          module MMM-Fuel contains package.json, doing npm install
          restoring MMM-Globe
          restoring MMM-JsonValue
          module MMM-JsonValue contains package.json, doing npm install
          restoring MMM-LogExt
          module MMM-LogExt DOES NOT contain package.json
          restoring MMM-Logging
          module MMM-Logging contains package.json, doing npm install
          restoring MMM-MagicMover
          restoring MMM-MoonPhase
          restoring MMM-MPlayer
          restoring MMM-MyGarbage
          module MMM-MyGarbage contains package.json, doing npm install
          restoring MMM-NotificationTrigger
          module MMM-NotificationTrigger DOES NOT contain package.json
          restoring MMM-NowPlayingOnSpotify
          module MMM-NowPlayingOnSpotify contains package.json, doing npm install
          restoring MMM-Profilepicture
          module MMM-Profilepicture DOES NOT contain package.json
          restoring MMM-Remote-Control
          module MMM-Remote-Control contains package.json, doing npm install
          restoring MMM-Strava
          module MMM-Strava contains package.json, doing npm install
          restoring MMM-SweepClock
          restoring MMM-SystemInfo
          module MMM-SystemInfo DOES NOT contain package.json
          restoring MMM-SystemStats
          module MMM-SystemStats contains package.json, doing npm install
          restoring MMM-Temp2IOT
          module MMM-Temp2IOT DOES NOT contain package.json
          restoring MMM-Todoist
          module MMM-Todoist contains package.json, doing npm install
          restoring MMM-ViewNotifications
          module MMM-ViewNotifications DOES NOT contain package.json
          restoring MMM-WiFiPassword
          module MMM-WiFiPassword DOES NOT contain package.json
          grep: MMM-LogExt
          MMM-Strava
          MMM-JsonValue
          MMM-Remote-Control
          MMM-MyGarbage
          MMM-Bring
          MMM-SystemStats
          internet-monitor
          MMM-Config
          MMM-MoonPhase
          MMM-Temp2IOT
          MMM-Todoist
          MMM-Fuel
          MMM-SystemInfo
          birthdaylist
          MMM-Logging
          MMM-MPlayer
          MMM-FrameLight
          MMM-NowPlayingOnSpotify/node_helper.js: File name too long
          restore completed, you can start MagicMirror now
          Now have to check what is working, what not …
            rkorell Module Developer @rkorell
            @sdetweil WOW!
            nearly all is working!
            Some local modifications are not catched (e.g. datafile for birthdaylist (to illustrate what I mean - you are somewhat familiar with birthdaylist :-) ) ).
            For unknown reasons “MMM-CalendarExt3Agenda” is not showing up - I may have to apply the fix I had seen somehow (have NOT to use this fix on my Pi4 with same mirror version (2.30.0))
            Calendar fetches are present (checked log) so it seems an error in C3A …
            By checking log I found a never seen error:
            0|MagicMir |     at node:internal/deps/undici/undici:13392:13
            0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
            0|MagicMir |   [cause]: ConnectTimeoutError: Connect Timeout Error (attempted addresses: 151.101.193.164:443, 151.101.65.164:443, 151.101.129.164:443, 151.101.1.164:443, timeout: 30000ms)
            0|MagicMir |       at onConnectTimeout (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:237:24)
            0|MagicMir |       at Immediate._onImmediate (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:206:11)
            0|MagicMir |       at process.processImmediate (node:internal/timers:483:21) {
            0|MagicMir |     code: 'UND_ERR_CONNECT_TIMEOUT'
            0|MagicMir |   }
            0|MagicMir | }
            0|MagicMir | [2025-03-26 04:50:09.238] [ERROR] Failed to retrieve repo info for MagicMirror: Error: Command failed: cd /home/pi/MagicMirror/ && git fetch -n --dry-run
            0|MagicMir | fatal: unable to access 'https://github.com/MagicMirrorOrg/MagicMirror.git/': Failed to connect to github.com port 443 after 133356 ms: Couldn't connect to server
            is this related to auto-update?
            And another question: On my other Mirror a restart happens when I write config.js back to raspi - this doesn’t happen on new system - can I enable this with a parameter somehow I have missed?
            Thanks a LOT for your great script and your effort behind!
            Ralf
            R S 2 Replies Last reply Reply Quote 0
              sorry, still another question…
              Your backup-script has stored the famous MMM-Pir (bugsounet’s) on my git-repository.
              The restore script does not restore this directory (I guess because the origin git repo doesn’t exist anymore - which makes sense).
              But I would at least try to get this up and running again…
              Can I restore this directory manually?
              And if possible is this done with a fully qualified path or somehow different?
              (meaning “https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir”)
              so would my command be:
              git clone https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir
              or
              git clone https://github.com/rkorell/MagicMirror/MMM-Pir
              Or do I have to transfer my tar file to the new raspi and unpack it there?
              Thanks for guidance!
              Ralf
                sdetweil @rkorell
                @rkorell said in Restore script cannot create Backup folder?:
                you could edit the MM_backup/module_list file and change the url
                and then restore from the local MM_backup to test
                if good then do another backup to make a new tag of the updated state (with the corrected url)
                  @sdetweil Thanks.
                  IN the meantime I’ve figured out that the MM-Pir directorry in github repo (backup) only contains four files, so is useless for restoring…
                    sdetweil @rkorell
                    oh my…
                    • R rkorell has marked this topic as solved on
                      @rkorell
                      thanks so much for the trouble report… fixed
                      next execution will handle it correctly and that revision of the backup will be more accurate. I noticed that I also did not preserve the file attributes (date/time, owner, permissions) , and that is corrected too…
                        @sdetweil said in Restore script cannot create Backup folder?:
                        Dear Sam, you’re REALLY (!) welcome!
                        Thanks to YOU for all of your effort!
                        Ralf
