    Restore script cannot create Backup folder?
    13 Posts 2 Posters 3.2k Views 2 Watching
      sdetweil @rkorell
      @rkorell hmmmmm . out w family til later
      R 1 Reply Last reply
        @sdetweil Don’t worry!
        Have fun with your family!
        Will stop then until tomorrow -take your time!!!
          sdetweil @rkorell
          @rkorell oops bug, rerun
          R 2 Replies Last reply
            @sdetweil cool, THANKS!
            script now is doing something :-)
            I’m really curious…
            Ralf
              @sdetweil has worked :-)
              pi@MagicMirrorPi5:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)" -r https://github.com/rkorell/MagicMirror -f
              restoring MM configuration from /home/pi/MM_backup to /home/pi/MagicMirror
              trying to fetch MagicMirror from github
              folder /home/pi/MM_backup does not exist, will clone it from github
              Username for 'https://github.com': rkorell
              Password for 'https://rkorell@github.com':
              created git branch from last tag = 10
              restored config.js and custom.css
              restoring birthdaylist
              module birthdaylist contains package.json, doing npm install
              restoring internet-monitor
              module internet-monitor contains package.json, doing npm install
              restoring MMM-Bring
              module MMM-Bring contains package.json, doing npm install
              there were files saved for this module , restoring
              restoring MMM-CalendarExt3Agenda
              restoring MMM-Config
              module MMM-Config contains package.json, doing npm install
              restoring MMM-EventHorizon
              module MMM-EventHorizon DOES NOT contain package.json
              restoring MMM-FrameLight
              restoring MMM-FRITZ-Box-Callmonitor-py3
              module MMM-FRITZ-Box-Callmonitor-py3 contains package.json, doing npm install
              restoring MMM-Fuel
              module MMM-Fuel contains package.json, doing npm install
              restoring MMM-Globe
              restoring MMM-JsonValue
              module MMM-JsonValue contains package.json, doing npm install
              restoring MMM-LogExt
              module MMM-LogExt DOES NOT contain package.json
              restoring MMM-Logging
              module MMM-Logging contains package.json, doing npm install
              restoring MMM-MagicMover
              restoring MMM-MoonPhase
              restoring MMM-MPlayer
              restoring MMM-MyGarbage
              module MMM-MyGarbage contains package.json, doing npm install
              restoring MMM-NotificationTrigger
              module MMM-NotificationTrigger DOES NOT contain package.json
              restoring MMM-NowPlayingOnSpotify
              module MMM-NowPlayingOnSpotify contains package.json, doing npm install
              restoring MMM-Profilepicture
              module MMM-Profilepicture DOES NOT contain package.json
              restoring MMM-Remote-Control
              module MMM-Remote-Control contains package.json, doing npm install
              restoring MMM-Strava
              module MMM-Strava contains package.json, doing npm install
              restoring MMM-SweepClock
              restoring MMM-SystemInfo
              module MMM-SystemInfo DOES NOT contain package.json
              restoring MMM-SystemStats
              module MMM-SystemStats contains package.json, doing npm install
              restoring MMM-Temp2IOT
              module MMM-Temp2IOT DOES NOT contain package.json
              restoring MMM-Todoist
              module MMM-Todoist contains package.json, doing npm install
              restoring MMM-ViewNotifications
              module MMM-ViewNotifications DOES NOT contain package.json
              restoring MMM-WiFiPassword
              module MMM-WiFiPassword DOES NOT contain package.json
              grep: MMM-LogExt
              MMM-Strava
              MMM-JsonValue
              MMM-Remote-Control
              MMM-MyGarbage
              MMM-Bring
              MMM-SystemStats
              internet-monitor
              MMM-Config
              MMM-MoonPhase
              MMM-Temp2IOT
              MMM-Todoist
              MMM-Fuel
              MMM-SystemInfo
              birthdaylist
              MMM-Logging
              MMM-MPlayer
              MMM-FrameLight
              MMM-NowPlayingOnSpotify/node_helper.js: File name too long
              restore completed, you can start MagicMirror now
              Now have to check what is working, what not …
                rkorell Module Developer @rkorell
                @sdetweil WOW!
                nearly all is working!
                Some local modifications are not catched (e.g. datafile for birthdaylist (to illustrate what I mean - you are somewhat familiar with birthdaylist :-) ) ).
                For unknown reasons “MMM-CalendarExt3Agenda” is not showing up - I may have to apply the fix I had seen somehow (have NOT to use this fix on my Pi4 with same mirror version (2.30.0))
                Calendar fetches are present (checked log) so it seems an error in C3A …
                By checking log I found a never seen error:
                0|MagicMir |     at node:internal/deps/undici/undici:13392:13
                0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                0|MagicMir |   [cause]: ConnectTimeoutError: Connect Timeout Error (attempted addresses: 151.101.193.164:443, 151.101.65.164:443, 151.101.129.164:443, 151.101.1.164:443, timeout: 30000ms)
                0|MagicMir |       at onConnectTimeout (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:237:24)
                0|MagicMir |       at Immediate._onImmediate (/home/pi/MagicMirror/node_modules/undici/lib/core/connect.js:206:11)
                0|MagicMir |       at process.processImmediate (node:internal/timers:483:21) {
                0|MagicMir |     code: 'UND_ERR_CONNECT_TIMEOUT'
                0|MagicMir |   }
                0|MagicMir | }
                0|MagicMir | [2025-03-26 04:50:09.238] [ERROR] Failed to retrieve repo info for MagicMirror: Error: Command failed: cd /home/pi/MagicMirror/ && git fetch -n --dry-run
                0|MagicMir | fatal: unable to access 'https://github.com/MagicMirrorOrg/MagicMirror.git/': Failed to connect to github.com port 443 after 133356 ms: Couldn't connect to server
                is this related to auto-update?
                And another question: On my other Mirror a restart happens when I write config.js back to raspi - this doesn’t happen on new system - can I enable this with a parameter somehow I have missed?
                Thanks a LOT for your great script and your effort behind!
                Ralf
                R S 2 Replies Last reply
                  sorry, still another question…
                  Your backup-script has stored the famous MMM-Pir (bugsounet’s) on my git-repository.
                  The restore script does not restore this directory (I guess because the origin git repo doesn’t exist anymore - which makes sense).
                  But I would at least try to get this up and running again…
                  Can I restore this directory manually?
                  And if possible is this done with a fully qualified path or somehow different?
                  (meaning “https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir”)
                  so would my command be:
                  git clone https://github.com/rkorell/MagicMirror/tree/main/MMM-Pir
                  or
                  git clone https://github.com/rkorell/MagicMirror/MMM-Pir
                  Or do I have to transfer my tar file to the new raspi and unpack it there?
                  Thanks for guidance!
                  Ralf
                    sdetweil @rkorell
                    @rkorell said in Restore script cannot create Backup folder?:
                    you could edit the MM_backup/module_list file and change the url
                    and then restore from the local MM_backup to test
                    if good then do another backup to make a new tag of the updated state (with the corrected url)
                      @sdetweil Thanks.
                      IN the meantime I’ve figured out that the MM-Pir directorry in github repo (backup) only contains four files, so is useless for restoring…
                        sdetweil @rkorell
                        oh my…
                        • R rkorell has marked this topic as solved on
                          @rkorell
                          thanks so much for the trouble report… fixed
                          next execution will handle it correctly and that revision of the backup will be more accurate. I noticed that I also did not preserve the file attributes (date/time, owner, permissions) , and that is corrected too…
                            @sdetweil said in Restore script cannot create Backup folder?:
                            Dear Sam, you’re REALLY (!) welcome!
                            Thanks to YOU for all of your effort!
                            Ralf
