    MMM-CalendarExt3Agenda - Two questions
    19 Posts 3 Posters 4.0k Views 3 Watching
    • K Offline
      Kelemvor @sdetweil
      @sdetweil Thanks. I’ll take a look tomorrow when my brain is fresh. ;)
      • K Offline
        Kelemvor @Kelemvor
        There’s already this in the CSS that makes the passed events Gray:
        .CX3A .event.passed {
        filter: brightness(0.6) grayscale(0.33);
        But, there must be something else that removes them completely when it updates so they don’t show at all.
        • BKeyportB Online
          BKeyport Module Developer @Kelemvor
          As for the #1 question, look at these config items:
          startDayIndex
          endDayIndex
          That will adjust your view to specific days - startDayIndex: 0 will set it to start on the current day, and then continue for the number of days listed in endDayIndex
          • K Offline
            Kelemvor @BKeyport
            @BKeyport said in MMM-CalendarExt3Agenda - Two questions:
            startDayIndex
            endDayIndex
            Those are already set correctly. There’s something hard coded somewhere that removes events that are in the past from showing, even if they’re from Today. If those settings were wrong I wouldn’t see anything from today.
            K BKeyportB 2 Replies Last reply Reply Quote 0
            • K Offline
              Kelemvor @Kelemvor
              Maybe something in this section if I’m deciphering things correctly…
              • BKeyportB Online
                @Kelemvor do you have broadcastPastEvents: true, set in the default calendar app?
                • BKeyportB Online
                  @Kelemvor Actually, I think you might be right - does look hardcoded.
                  • K Offline
                    Kelemvor @BKeyport
                    Not if that goes in the normal Config area. Does that make ALL events from the entire calendar get passed over to Ext3? Is that going to overload anything since it’s decades of events? :)
                    • BKeyportB Online
                      @Kelemvor It won’t overload anything. broadcastPastEvents is required to show old events.
                      • K Offline
                        Kelemvor @BKeyport
                        @BKeyport I know it says its broadcasting 400+ events so I’m assuming it’s sending old stuff.
                        BKeyportB K 2 Replies Last reply Reply Quote 0
