    troubleshooting
    7 Posts 2 Posters 1.0k Views 2 Watching
      rob73
      I have a few MagicMirror installs going and I just love them. I notice that some config.js file edits will be applied with a MagicMirror reload(ctrl-r), some wont take without a complete program close and restart. What edits require a restart and what requires a reload and how can you check? How can I troubleshoot those things?
      I have a latest install that I am configuring a calendar for my dad, and I can not get the clock to take edits. No change that I make will be applied. Not even with a whole restart. I am not sure how to troubleshoot this.
      Rob
      S 3 Replies Last reply Reply Quote 0
        sdetweil @rob73
        @rob73 the pm2 app can restart on config change, and my installer sets it up that way.
        however it doesn’t work reliably on any platform.
        i made changes last year to solve this, and its works sometimes
          sdetweil @rob73
          @rob73 show the module structure for clock in config. js please
            sdetweil @rob73
            @rob73 oh, some ctrl-r
            ctrl-r only reloads the web page, its does not restart any of the node_helpers some modules use
            node_helpers only get loaded at startup
            example. weather is all in browser, calendar uses a node_helper to get data
            so ctrl-r will reload weather completely
            if you changed the calendar config to add/remove a calendar, then ctrl-r will NOT do that
            so, you have to look a the module implementation to see how you need to restart
              rob73 @sdetweil
              @sdetweil That makes sense to me about reloading the page and not restarting the modules and things.
              I figured out the calendar config. I was leaving out the config {} section and just adding the options right under the module: “clock” & position:“top_left”.
              I looked at that over and over and compared to examples and I couldnt figure it out to save my life. I woke up in the middle of the night and took a look at it again and it jumped out at me.
              Thanks for the responses.
              Rob
                sdetweil @rob73
                @rob73 cool was thinking missing config section
                hate those wake up in the night thoughts
                  rob73 @sdetweil
                  @sdetweil those wake up in the night thoughts may be some of my best work… lol…
                  Thanks again!
