Calendar config
@JbeesonMagic16
Looks like you may be missing a close bracket. Try this:
module: 'calendar', header: 'Calender', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' }, { url: 'htpps://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics' }, { url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics' }, ], } } -
So I added the bracket, but still get the ‘please create a config file’, which is what I get when I add something new and inevitably mess something up.
Try putting your config.js in a website like http://jshint.com/. It should help you find any brackets you might be missing.
@mochman How do I know what needs to be changed though? It’s finding a lot of issues, even with the default code that I’ve not changed?
Ater adding that } , it’s complaining about double quotes instead of singular, unexpected label ‘modules’, and expected an identifier and instead saw ‘}’.
It doesn’t seem to be geared towards the code for Magic Mirror? -
Please post your entire config
btw … I don’t know for google calendars, but I replaced https with webcal for my outlook.com calendar. -
@JbeesonMagic16 No, it’s a general javascript problem finder. If you paste your config.js file in it’s entirety into http://jshint.com/. You should see it say “One undefined variable”. If you see
Expected '}' to match '{' from line XXX and instead saw ']'You are missing a bracket. Look at line XXX and then follow the code down to see where the missing bracket is.
The full config file will definitely help. You also have one more small typo here -
{ url: 'htpps://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics' },that should probably be ‘https’ rather than ‘htpps’ but I don’t think this should be breaking your config.
@in_a_days Nice catch! I fixed it, but yeah, it wasn’t the source.
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 12, units: 'imperial', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'Calender', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' }, { url: 'https://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics' }, { url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics' }, ], } } { module: 'compliments', position: 'lower_third' }, { module: 'MMM-WunderGround', position: 'top_right', config: { apikey: 'MYKEY', pws: 'pws:KMOOFALL59', hourly: '1', fctext: '1', fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0 } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}Also modified the API to hide it in the weather section, but it’s there. JShint gave me 4 errors, but I was going off that link from the other question for syntax, so I’m not 100% what needs to be removed or added.
Four warnings
46 Expected ‘]’ to match ‘[’ from line 15 and instead saw ‘{’.
47 Expected ‘}’ to match ‘{’ from line 7 and instead saw ‘module’.
47 Missing semicolon.
47 Unrecoverable syntax error. (52% scanned). -
@JbeesonMagic16
add a comma here:
{ url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics' }, ], } } { module: 'compliments', position: 'lower_third'so it looks like this
{ url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics' }, ], } }, { module: 'compliments', position: 'lower_third'See if that solves it.
