    V2.31.0 unable to start
    29 Posts 3 Posters 8.4k Views 3 Watching
    • htilburgsH
      htilburgs @sdetweil
      Same error😔
      npm run start
      npm run start:wayland
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH
        htilburgs @htilburgs
        I think I take a new SD Card and do an install from scratch to see what happens.
        htilburgsH 1 Reply Last reply Reply Quote 1
        • htilburgsH
          @htilburgs
          I took a new SD Card and installed everything from fresh.
          Some information:
          cat /sys/firmware/devicetree/base/model
          Raspberry Pi 4 Model B Rev 1.4
          cat /etc/debian_version
          12.10
          cat /etc/os-release
          PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
          NAME="Debian GNU/Linux"
          VERSION_ID="12"
          VERSION="12 (bookworm)"
          VERSION_CODENAME=bookworm
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          uname -a
          Linux MagicMirror 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
          node -v
          v22.14.0
          npm -v
          10.9.2
          When I start MagicMirror with “npm run start”, then everything seems to work.
          pm2 start MagicMirror works and seems to start MagicMirror in Wayland
          npm run start:wayland still gives an error
          pi@MagicMirror:~/MagicMirror $ npm run start:wayland
          > magicmirror@2.31.0 start:wayland
          > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
          [2025-04-15 21:25:47.140] [LOG]   Starting MagicMirror: v2.31.0
          [2025-04-15 21:25:47.175] [LOG]   Loading config ...
          [2025-04-15 21:25:47.179] [LOG]   config template file not exists, no envsubst
          [2025-04-15 21:25:47.752] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
          [2025-04-15 21:25:47.874] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-04-15 21:25:47.876] [INFO]  Checking modules structure configuration ...
          [2025-04-15 21:25:47.988] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-04-15 21:25:47.991] [LOG]   Loading module helpers ...
          [2025-04-15 21:25:47.992] [LOG]   No helper found for module: alert.
          [2025-04-15 21:25:48.002] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.004] [LOG]   Module helper loaded: updatenotification
          [2025-04-15 21:25:48.004] [LOG]   No helper found for module: clock.
          [2025-04-15 21:25:48.005] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
          [2025-04-15 21:25:48.005] [LOG]   No helper found for module: weather.
          [2025-04-15 21:25:48.061] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.061] [LOG]   Module helper loaded: MMM-Formula1
          [2025-04-15 21:25:48.099] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.100] [LOG]   Module helper loaded: MMM-MyGarbage
          [2025-04-15 21:25:48.225] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.225] [LOG]   Module helper loaded: calendar
          [2025-04-15 21:25:48.270] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.271] [LOG]   Module helper loaded: MMM-OnSpotify
          [2025-04-15 21:25:48.298] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.298] [LOG]   Module helper loaded: MMM-Bring
          [2025-04-15 21:25:48.487] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.487] [LOG]   Module helper loaded: MMM-Tado
          [2025-04-15 21:25:48.489] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.489] [LOG]   Module helper loaded: MMM-MyHomeWizard
          [2025-04-15 21:25:48.491] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.492] [LOG]   Module helper loaded: MMM-SystemMonitor
          [2025-04-15 21:25:48.523] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.523] [LOG]   Module helper loaded: MMM-network-signal
          [2025-04-15 21:25:48.525] [LOG]   Initializing new module helper ...
          [2025-04-15 21:25:48.526] [LOG]   Module helper loaded: MMM-Universal-Pir
          [2025-04-15 21:25:48.526] [LOG]   All module helpers loaded.
          [2025-04-15 21:25:48.536] [LOG]   Starting server on port 8080 ...
          [2025-04-15 21:25:49.396] [LOG]   Server started ...
          [2025-04-15 21:25:49.401] [LOG]   Connecting socket for: updatenotification
          [2025-04-15 21:25:49.407] [LOG]   Starting module helper: updatenotification
          [2025-04-15 21:25:49.409] [LOG]   Connecting socket for: MMM-Formula1
          [2025-04-15 21:25:49.414] [LOG]   Starting module: MMM-Formula1
          [2025-04-15 21:25:49.418] [LOG]   Connecting socket for: MMM-MyGarbage
          [2025-04-15 21:25:49.419] [LOG]   Starting node_helper for module: MMM-MyGarbage
          [2025-04-15 21:25:49.420] [LOG]   Connecting socket for: calendar
          [2025-04-15 21:25:49.422] [LOG]   Starting node helper for: calendar
          [2025-04-15 21:25:49.424] [LOG]   Connecting socket for: MMM-OnSpotify
          [2025-04-15 21:25:49.427] [LOG]   [MMM-OnSpotify] by Fabrizz >> Node helper loaded.
          [2025-04-15 21:25:49.428] [LOG]   Connecting socket for: MMM-Bring
          [2025-04-15 21:25:49.430] [LOG]   Connecting socket for: MMM-Tado
          [2025-04-15 21:25:49.438] [LOG]       - MMM-Tado: Refresh token loaded.
          [2025-04-15 21:25:49.440] [LOG]   Connecting socket for: MMM-MyHomeWizard
          [2025-04-15 21:25:49.443] [LOG]   Starting node_helper for: MMM-MyHomeWizard
          [2025-04-15 21:25:49.444] [LOG]   Connecting socket for: MMM-SystemMonitor
          [2025-04-15 21:25:49.446] [LOG]   Starting module helper: MMM-SystemMonitor
          [2025-04-15 21:25:49.450] [LOG]   Connecting socket for: MMM-network-signal
          [2025-04-15 21:25:49.452] [LOG]   MMM-network-signal helper started ...
          [2025-04-15 21:25:49.454] [LOG]   Connecting socket for: MMM-Universal-Pir
          [2025-04-15 21:25:49.457] [LOG]   Sockets connected & modules started ...
          [2025-04-15 21:25:50.513] [LOG]   Launching application.
          [2025-04-15 21:25:51.278] [INFO]  System information:
          ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.4; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
          ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
          ### OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
          I was just wondering, couldn’t it have something to do with the WAYLAND_DISPLAY parameter?
            sdetweil @htilburgs
            @htilburgs could be
            when you open a terminal session and do
            env
            is the WAYLAND_DISPLAY variable set?
            that code you referenced says use WAYLAND_DISPLAY, and if not set, set it to wayland-1
            • htilburgsH
              htilburgs @sdetweil
              @sdetweil It seems it’s not set
              pi@MagicMirror:~ $ env
              SHELL=/bin/bash
              NO_AT_BRIDGE=1
              PWD=/home/pi
              LOGNAME=pi
              XDG_SESSION_TYPE=tty
              MOTD_SHOWN=pam
              HOME=/home/pi
              LANG=en_GB.UTF-8
              LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
              SSH_CONNECTION=192.168.0.200 57994 192.168.0.47 22
              XDG_SESSION_CLASS=user
              TERM=xterm-256color
              USER=pi
              SHLVL=1
              XDG_SESSION_ID=4
              XDG_RUNTIME_DIR=/run/user/1000
              SSH_CLIENT=192.168.0.200 57994 22
              PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
              SSH_TTY=/dev/pts/0
              OLDPWD=/home/pi/.config
              TEXTDOMAIN=Linux-PAM
              _=/usr/bin/env
              pi@MagicMirror:~ $
              How do I set this?
                sdetweil @htilburgs
                @htilburgs in terminal window no spaces between things…
                this is like the windows set var=value (without the set prefix)
                WAYLAND_DISPLAY=wayland-x
                x is a number from 0 to …
                we thought wayand-1 was default
                • htilburgsH
                  htilburgs @sdetweil
                  @sdetweil said in V2.31.0 unable to start:
                  In terminal window I typed WAYLAND_DISPLAY=wayland-1
                  Then I did “env”, nothing changed.
                  npm run start:wayland still gives the same error.
                    sdetweil @htilburgs
                    @htilburgs said in V2.31.0 unable to start:
                    you should have seen this in the env output
                    but our code says IF NOT SET, use wayland-1
                    which looks like an error
                    so if you set it to the same value it won’t improve
                    I’d try wayland-0
                    maybe the wlr_randr command will tell you what it is?
                    • htilburgsH
                      htilburgs @sdetweil
                      @sdetweil Maybe I don’t understand.
                      WAYLAND_DISPLAY=wayland-0 still gives wayland-1 in npm run start:wayland.
                      wlr_randr gives
                      pi@MagicMirror:~/MagicMirror $ wlr_randr
                      -bash: wlr_randr: command not found
                      By the way, my PIR command do work
                      onCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --on --transform 270 --mode='1920x1080'",
                      offCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --off",
                      htilburgsH R 2 Replies Last reply Reply Quote 0
                      • htilburgsH
                        When I give command
                        pi@MagicMirror:~ $ WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1
                        HDMI-A-1 "Samsung Electric Company SyncMaster 0x00000001 (HDMI-A-1)"
                          Physical size: 700x390 mm
                          Enabled: yes
                          Modes:
                            720x400 px, 70.082001 Hz
                            640x480 px, 59.939999 Hz
                            640x480 px, 60.000000 Hz
                            640x480 px, 66.667000 Hz
                            640x480 px, 72.808998 Hz
                            640x480 px, 75.000000 Hz
                            720x480 px, 59.939999 Hz
                            720x480 px, 60.000000 Hz
                            720x576 px, 50.000000 Hz
                            800x600 px, 60.317001 Hz
                            800x600 px, 72.188004 Hz
                            800x600 px, 75.000000 Hz
                            832x624 px, 74.551003 Hz
                            1024x768 px, 60.004002 Hz
                            1024x768 px, 70.069000 Hz
                            1024x768 px, 75.028999 Hz
                            1280x720 px, 50.000000 Hz
                            1280x720 px, 59.939999 Hz
                            1280x720 px, 60.000000 Hz
                            1152x864 px, 75.000000 Hz
                            1280x800 px, 59.910000 Hz
                            1440x900 px, 59.901001 Hz
                            1280x1024 px, 60.020000 Hz
                            1280x1024 px, 75.025002 Hz
                            1600x900 px, 60.000000 Hz
                            1680x1050 px, 59.882999 Hz
                            1920x1080 px, 23.976000 Hz
                            1920x1080 px, 24.000000 Hz
                            1920x1080 px, 25.000000 Hz
                            1920x1080 px, 29.969999 Hz
                            1920x1080 px, 30.000000 Hz
                            1920x1080 px, 50.000000 Hz
                            1920x1080 px, 59.939999 Hz
                            1920x1080 px, 60.000000 Hz
                            1920x1080 px, 60.000000 Hz (preferred, current)
                          Position: 0,0
                          Transform: 270
                          Scale: 1.000000
                          sdetweil @htilburgs
                          @htilburgs so wayland-1 seems to be correct
                            rkorell Module Developer @htilburgs
                            shouldn’t it be wlr-randr ?
                            Regards,
                            Ralf
                            htilburgsH S 2 Replies Last reply Reply Quote 0
                            • htilburgsH
                              htilburgs @rkorell
                              @rkorell
                              You’re correct, but then I get
                                @htilburgs :-)
                                this is correct on console window.
                                console didn’t know about display unless you’re telling him what display to use.
                                As far as I know you can use
                                DISPLAY=:0.0
                                as a hint upfront your terminal command.
                                At least for xrandr this works and is necessary.
                                DISPLAY=:0.0 xrandr --output HDMI-1 --off
                                is my xrandr console equivalent for the “normal” command
                                I’m not THAT sure if this is true for wlr-randr .
                                (Because wlr-randr do have this environment variable “WAYLAND_DISPLAY” which is not the case for xrandr…)
                                HTH & regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell xrandr needs DISPLAY
                                    @sdetweil yes :-)
                                      sdetweil @rkorell
                                      @rkorell oops, never can remember when i need to use underscore vs dash! thanks for the catch!
