    V2.31.0 unable to start
    29 Posts 3 Posters 8.4k Views 3 Watching
    • htilburgsH
      htilburgs @sdetweil
      @sdetweil said in V2.31.0 unable to start:
      WAYLAND_DISPLAY=wayland-x
      In terminal window I typed WAYLAND_DISPLAY=wayland-1
      Then I did “env”, nothing changed.
      npm run start:wayland still gives the same error.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs said in V2.31.0 unable to start:
        you should have seen this in the env output
        but our code says IF NOT SET, use wayland-1
        which looks like an error
        so if you set it to the same value it won’t improve
        I’d try wayland-0
        maybe the wlr_randr command will tell you what it is?
        htilburgsH 1 Reply Last reply Reply Quote 0
        • htilburgsH
          htilburgs @sdetweil
          @sdetweil Maybe I don’t understand.
          WAYLAND_DISPLAY=wayland-0 still gives wayland-1 in npm run start:wayland.
          wlr_randr gives
          pi@MagicMirror:~/MagicMirror $ wlr_randr
          -bash: wlr_randr: command not found
          By the way, my PIR command do work
          onCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --on --transform 270 --mode='1920x1080'",
          offCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --off",
          htilburgsH R 2 Replies Last reply Reply Quote 0
          • htilburgsH
            htilburgs @htilburgs
            When I give command
            pi@MagicMirror:~ $ WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1
            HDMI-A-1 "Samsung Electric Company SyncMaster 0x00000001 (HDMI-A-1)"
              Physical size: 700x390 mm
              Enabled: yes
              Modes:
                720x400 px, 70.082001 Hz
                640x480 px, 59.939999 Hz
                640x480 px, 60.000000 Hz
                640x480 px, 66.667000 Hz
                640x480 px, 72.808998 Hz
                640x480 px, 75.000000 Hz
                720x480 px, 59.939999 Hz
                720x480 px, 60.000000 Hz
                720x576 px, 50.000000 Hz
                800x600 px, 60.317001 Hz
                800x600 px, 72.188004 Hz
                800x600 px, 75.000000 Hz
                832x624 px, 74.551003 Hz
                1024x768 px, 60.004002 Hz
                1024x768 px, 70.069000 Hz
                1024x768 px, 75.028999 Hz
                1280x720 px, 50.000000 Hz
                1280x720 px, 59.939999 Hz
                1280x720 px, 60.000000 Hz
                1152x864 px, 75.000000 Hz
                1280x800 px, 59.910000 Hz
                1440x900 px, 59.901001 Hz
                1280x1024 px, 60.020000 Hz
                1280x1024 px, 75.025002 Hz
                1600x900 px, 60.000000 Hz
                1680x1050 px, 59.882999 Hz
                1920x1080 px, 23.976000 Hz
                1920x1080 px, 24.000000 Hz
                1920x1080 px, 25.000000 Hz
                1920x1080 px, 29.969999 Hz
                1920x1080 px, 30.000000 Hz
                1920x1080 px, 50.000000 Hz
                1920x1080 px, 59.939999 Hz
                1920x1080 px, 60.000000 Hz
                1920x1080 px, 60.000000 Hz (preferred, current)
              Position: 0,0
              Transform: 270
              Scale: 1.000000
              sdetweil @htilburgs
              @htilburgs so wayland-1 seems to be correct
                rkorell Module Developer @htilburgs
                shouldn’t it be wlr-randr ?
                Regards,
                Ralf
                htilburgsH S 2 Replies Last reply Reply Quote 0
                • htilburgsH
                  htilburgs @rkorell
                  @rkorell
                  You’re correct, but then I get
                    @htilburgs :-)
                    this is correct on console window.
                    console didn’t know about display unless you’re telling him what display to use.
                    As far as I know you can use
                    DISPLAY=:0.0
                    as a hint upfront your terminal command.
                    At least for xrandr this works and is necessary.
                    DISPLAY=:0.0 xrandr --output HDMI-1 --off
                    is my xrandr console equivalent for the “normal” command
                    I’m not THAT sure if this is true for wlr-randr .
                    (Because wlr-randr do have this environment variable “WAYLAND_DISPLAY” which is not the case for xrandr…)
                    HTH & regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell xrandr needs DISPLAY
                        @sdetweil yes :-)
                          sdetweil @rkorell
                          @rkorell oops, never can remember when i need to use underscore vs dash! thanks for the catch!
