    AHT20 Humidity + Temperature Sensor
    18 Posts 3 Posters 7.7k Views 3 Watching
      sdetweil @JohnGalt
      @JohnGalt the browser (electron) wants to display the data from the sensor, but it cant read it directly. so the module sends a request to the helper to get the data from device 0x38
      the module uses a python script to get the data
      the python script is reporting an error
      that is what needs to be looked at.
      you posted the code from the module/browser side which is not involved in getting the actual data
      J 1 Reply Last reply
        rkorell Module Developer @JohnGalt
        the python script you are looking for is bme280.py
        #!/usr/bin/python
        #    ___  ___  _ ____
        #   / _ \/ _ \(_) __/__  __ __
        #  / , _/ ___/ /\ \/ _ \/ // /
        # /_/|_/_/  /_/___/ .__/\_, /
        #                /_/   /___/
        #           bme280.py
        #  Read data from a digital pressure sensor.
        #  Official datasheet available from :
        #  https://www.bosch-sensortec.com/bst/products/all_products/bme280
        # Author : Matt Hawkins
        # Date   : 21/01/2018
        # https://www.raspberrypi-spy.co.uk/
        import smbus
        import sys
        import time
        from ctypes import c_short
        from ctypes import c_byte
        from ctypes import c_ubyte
        DEVICE = 0x76 # Default device I2C address
        try: #override device address like '0x77'
            DEVICE = int(sys.argv[1], 16)
        except:
            pass
        bus = smbus.SMBus(1) # Rev 2 Pi, Pi 2 & Pi 3 uses bus 1
                             # Rev 1 Pi uses bus 0
        def getShort(data, index):
          # return two bytes from data as a signed 16-bit value
          return c_short((data[index+1] << 8) + data[index]).value
        def getUShort(data, index):
          # return two bytes from data as an unsigned 16-bit value
          return (data[index+1] << 8) + data[index]
        def getChar(data,index):
          # return one byte from data as a signed char
          result = data[index]
          if result > 127:
            result -= 256
          return result
        def getUChar(data,index):
          # return one byte from data as an unsigned char
          result =  data[index] & 0xFF
          return result
        def readBME280ID(addr=DEVICE):
          # Chip ID Register Address
          REG_ID     = 0xD0
          (chip_id, chip_version) = bus.read_i2c_block_data(addr, REG_ID, 2)
          return (chip_id, chip_version)
        def readBME280All(addr=DEVICE):
          # Register Addresses
          REG_DATA = 0xF7
          REG_CONTROL = 0xF4
          REG_CONFIG  = 0xF5
          REG_CONTROL_HUM = 0xF2
          REG_HUM_MSB = 0xFD
          REG_HUM_LSB = 0xFE
          # Oversample setting - page 27
          OVERSAMPLE_TEMP = 2
          OVERSAMPLE_PRES = 2
          MODE = 1
          # Oversample setting for humidity register - page 26
          OVERSAMPLE_HUM = 2
          bus.write_byte_data(addr, REG_CONTROL_HUM, OVERSAMPLE_HUM)
          control = OVERSAMPLE_TEMP<<5 | OVERSAMPLE_PRES<<2 | MODE
          bus.write_byte_data(addr, REG_CONTROL, control)
          # Read blocks of calibration data from EEPROM
          # See Page 22 data sheet
          cal1 = bus.read_i2c_block_data(addr, 0x88, 24)
          cal2 = bus.read_i2c_block_data(addr, 0xA1, 1)
          cal3 = bus.read_i2c_block_data(addr, 0xE1, 7)
          # Convert byte data to word values
          dig_T1 = getUShort(cal1, 0)
          dig_T2 = getShort(cal1, 2)
          dig_T3 = getShort(cal1, 4)
          dig_P1 = getUShort(cal1, 6)
          dig_P2 = getShort(cal1, 8)
          dig_P3 = getShort(cal1, 10)
          dig_P4 = getShort(cal1, 12)
          dig_P5 = getShort(cal1, 14)
          dig_P6 = getShort(cal1, 16)
          dig_P7 = getShort(cal1, 18)
          dig_P8 = getShort(cal1, 20)
          dig_P9 = getShort(cal1, 22)
          dig_H1 = getUChar(cal2, 0)
          dig_H2 = getShort(cal3, 0)
          dig_H3 = getUChar(cal3, 2)
          dig_H4 = getChar(cal3, 3)
          dig_H4 = (dig_H4 << 24) >> 20
          dig_H4 = dig_H4 | (getChar(cal3, 4) & 0x0F)
          dig_H5 = getChar(cal3, 5)
          dig_H5 = (dig_H5 << 24) >> 20
          dig_H5 = dig_H5 | (getUChar(cal3, 4) >> 4 & 0x0F)
          dig_H6 = getChar(cal3, 6)
          # Wait in ms (Datasheet Appendix B: Measurement time and current calculation)
          wait_time = 1.25 + (2.3 * OVERSAMPLE_TEMP) + ((2.3 * OVERSAMPLE_PRES) + 0.575) + ((2.3 * OVERSAMPLE_HUM)+0.575)
          time.sleep(wait_time/1000)  # Wait the required time
          # Read temperature/pressure/humidity
          data = bus.read_i2c_block_data(addr, REG_DATA, 8)
          pres_raw = (data[0] << 12) | (data[1] << 4) | (data[2] >> 4)
          temp_raw = (data[3] << 12) | (data[4] << 4) | (data[5] >> 4)
          hum_raw = (data[6] << 8) | data[7]
          #Refine temperature
          var1 = ((((temp_raw>>3)-(dig_T1<<1)))*(dig_T2)) >> 11
          var2 = (((((temp_raw>>4) - (dig_T1)) * ((temp_raw>>4) - (dig_T1))) >> 12) * (dig_T3)) >> 14
          t_fine = var1+var2
          temperature = float(((t_fine * 5) + 128) >> 8);
          # Refine pressure and adjust for temperature
          var1 = t_fine / 2.0 - 64000.0
          var2 = var1 * var1 * dig_P6 / 32768.0
          var2 = var2 + var1 * dig_P5 * 2.0
          var2 = var2 / 4.0 + dig_P4 * 65536.0
          var1 = (dig_P3 * var1 * var1 / 524288.0 + dig_P2 * var1) / 524288.0
          var1 = (1.0 + var1 / 32768.0) * dig_P1
          if var1 == 0:
            pressure=0
          else:
            pressure = 1048576.0 - pres_raw
            pressure = ((pressure - var2 / 4096.0) * 6250.0) / var1
            var1 = dig_P9 * pressure * pressure / 2147483648.0
            var2 = pressure * dig_P8 / 32768.0
            pressure = pressure + (var1 + var2 + dig_P7) / 16.0
          # Refine humidity
          humidity = t_fine - 76800.0
          humidity = (hum_raw - (dig_H4 * 64.0 + dig_H5 / 16384.0 * humidity)) * (dig_H2 / 65536.0 * (1.0 + dig_H6 / 67108864.0 * humidity * (1.0 + dig_H3 / 67108864.0 * humidity)))
          humidity = humidity * (1.0 - dig_H1 * humidity / 524288.0)
          if humidity > 100:
            humidity = 100
          elif humidity < 0:
            humidity = 0
          return temperature/100.0,pressure/100.0,humidity
        def main():
          # (chip_id, chip_version) = readBME280ID()
          # print("Chip ID     :", chip_id)
          # print("Version     :", chip_version)
          temperature,pressure,humidity = readBME280All()
          print(round(temperature,1),round(humidity,1),round(pressure,1))
        if __name__=="__main__":
           main()
        @JohnGalt said in AHT20 Humidity + Temperature Sensor:
        Remote I/O error
        The given error seems to by not a program but an I/O problem.
        I’m not familiar with this sensor so I do not know how to connect and - most important - how to figure out the right “deviceAddress” - it seems that there is the error located.
        Either the address isn’t the correct one or the IO channel is somehow broken.
        For the latter came in my mind: if this is a I2C conected device - do you have enabled I2C on your Raspi?
        I’ve tried to “understand” what happens in the python script above as well as in the C-exmaple program on the Bosch product page for bme280 sensor, but didn’t got it…
        Regards,
        Ralf
        R J 3 Replies Last reply
          rkorell Module Developer @rkorell
          @JohnGalt
          just seen while re-reading my last posting:
          nodehelper.js (the part of the module which is communicating with the python program and so with the sensor) is calling python3 :
          exec(`python3 ./modules/MMM-BME280/bme280.py ${deviceAddr}`, (error, stdout) => {
          but the python script itself is referencing python 2 (see above post, source code of bme280.py, 1st line:
          #!/usr/bin/python
          I guess this must match and doesn’t …
          So may this is the cause of your problems.
          And if this is true it is may really hard to get this working because you may run in several incompatibilities and library-conflicts …
          Regards,
          Ralf
            JohnGalt @sdetweil
            @sdetweil – Thanks, Sam. It looks like I intended to send bme280.py but actually copied MMM-BME280.js. I see below where Ralf did post it, so I will look at that, too.
              JohnGalt @rkorell
              @rkorell – Hi Ralf:
              Yes, I2C is enabled and functioning. There is a test script that does return current temperature and humidity:
              Invoking “python AHT20_test.py” does launch this script (Note - I launch from the terminal using ‘python’, not ‘python3’, telling me the system is indeed defaulting to python3):
              # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
              # SPDX-License-Identifier: MIT
              Basic `AHTx0` example test
              import time
              import board
              import adafruit_ahtx0
              # Create sensor object, communicating over the board's default I2C bus
              i2c = board.I2C()  # uses board.SCL and board.SDA
              # i2c = board.STEMMA_I2C()  # For using the built-in STEMMA QT connector on a microcontroller
              sensor = adafruit_ahtx0.AHTx0(i2c)
              while True:
                  print("\nTemperature: %0.1f C" % sensor.temperature)
                  print("Humidity: %0.1f %%" % sensor.relative_humidity)
                  time.sleep(2)
                JohnGalt @rkorell
                @rkorell + @sdetweil - Thanks for the support. I think I have fixed this for myself by adapting an existing module (“MMM-Temperature”, // https://github.com/Tom-Hirschberger/MMM-Temperature).
                That module calls scripts for various sensors to capture the data. I was able to adapt an existing script for use with this sensor, so I think I am good for now.
                R 1 Reply Last reply
                Reply Quote 2
                  @JohnGalt cool.
                  congratulations.
                  It’s may be worth to show the community what you have done?
                  Regards,
                  Ralf
                    JohnGalt @rkorell
                    @rkorell Yes, I can describe how I arrived at a resolution for my particular problem - which was to replace DHTxx sensors with the more accurate AHT20 temperature and humidity sensors.
                    Caveat: I do not necessarily recommend this for the average person though, because I did not find Magic Mirror modules that natively support this sensor, and as a result had to make changes outside of the config.js and custom.css files. As usual, this puts me at risk of something breaking when the module is updated.
                    The module being used (MMM-Temperature - found at https://github.com/Tom-Hirschberger/MMM-Temperature) utilizes python scripts to capture the data from the sensor. While the module is quite complete, with script support for many sensors, I did create a new script in order to use this particular sensor.
                    The sensor is supported by Adafruit (https://learn.adafruit.com/adafruit-aht20/python-circuitpython), with instructions to install various adafruit libraries including adafruit-ahtx0 (sudo pip3 install adafruit-circuitpython-ahtx0).
                    Using those libraries, your script needs to include the following instructions:
                    import board
                    sensor = adafruit_ahtx0.AHTx0(board.I2C())
                    One of the existing scripts supports I2C sensors using the Adafruit libraries, so it looked like a good candidate to use as a model. See htu21:
                    #!/usr/bin/env python3
                    #pip3 install adafruit-circuitpython-htu21d
                    import board
                    from adafruit_htu21d import HTU21D
                    import json
                    result = {}
                    try:
                        sensor = HTU21D(i2c)
                        result["temperature_c"] = sensor.temperature
                        result["humidity"] = sensor.relative_humidity
                        result["temperature_f"] = (result["temperature_c"]*1.8) + 32
                        result["error"] = False
                    except:
                        result["temperature_c"] = 0.0
                        result["humidity"] = 0.0
                        result["error"] = True
                    print(json.dumps(result))
                    My resulting script is aht20:
                    # aht20: Modeled on htu21
                    # pip3 install adafruit-circuitpython-htu21d
                    # pip3 install adafruit-circuitpython-ahtx0
                    import board
                    import json
                    result = {}
                    try:
                        # sensor = HTU21D(i2c)
                    except:
                    This module is now displaying the temperature and humidity from the sensor directly connected it it. Now all I have to do is figure out the complicated css and get it to look like the other modules on my Magic Mirror.
                    Barring any objections, I will mark this as solved.
                    S R 2 Replies Last reply
                      sdetweil @JohnGalt
                      @JohnGalt css, use the developers window
                      see the second link in my signature below
                        @JohnGalt Really COOL!
                        Thanks for sharing!
                        Ralf
                          JohnGalt @sdetweil
                          @sdetweil – Thanks for the reminder, I’ll take a look.
                            JohnGalt @rkorell
                            @rkorell – My pleasure.
                            • J JohnGalt has marked this topic as solved on
