    Docker install on synology nas
    18 Posts 4 Posters 5.5k Views 4 Watching
      sdetweil @karsten13
      @karsten13 i think /opt is non existent on synology
      • karsten13K
        karsten13 @sdetweil
        @sdetweil said in Docker install on synology nas:
        but in the container
          sdetweil @oliv
          this turned out to be a permissions problem. the folder was created w the synology user, but the container is running as user 1000
            pauabaer @karsten13
            @karsten13
            I have the same issue but I do not really know how to run the container as user node with uid/gid 1000.
            You wrote two ways with the hint that this should happen as root. How do I do this?
            And can I make this run just for the MagicMirror docker? Because I have other dockers with other uids/gids.
            Thanks for your help.
            Paua
              sdetweil @pauabaer
              @pauabaer just change the docker compose .env file userid number from 1000 to whatever it is on your synology nas ( mine is 1026)
              (note the . in front of env)
                sdetweil @pauabaer
                @pauabaer yes, the user info is separate for each docker container
                think of a docker container as a mini pc disc, memory, cpu and software all inside a little case (container shell)
                  pauabaer @sdetweil
                  I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
                  But I got the same message: access denied.
                  So what would be the difference when I change the entry whithin the compose?
                  And how do I find this file at my synology? :)
                    sdetweil @pauabaer
                    @pauabaer i do not know how to do it with the gui,
                    there is a place where you can paste in the compose file . i have not tried that
                    i ssh’d into the nas and did the manual install steps via commandline
                      pauabaer @sdetweil
                      I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
                        sdetweil @pauabaer
                        @pauabaer typically the group id is the same as the user id
                          @pauabaer
                          id -u will get this users id number
                          id -g will get this users group number
                            pauabaer @sdetweil
                            That’s what i checked before. Id -u > 1026 / id -g > 100.
                            These parameters i inserted in the compose file.
                              pauabaer @karsten13
                              @karsten13
                              I tried to start via command line
                              paua@NAS:~$ docker run  -d \
                              >         --user root \
                              > --name magicmirror \
                              >     --publish 8036:8080 \
                              >     --restart unless-stopped \
                              >     -e TZ=Europe/Berlin \
                              >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                              >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                              >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                              >     karsten13/magicmirror:latest
                              docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                              See 'docker run --help'.
                              But again I got the permission error.
                                pauabaer @pauabaer
                                I fixed it and now MM is running in docker on my synology diskstation.
                                I had to insert
                                user: root
                                in the compose file. It is working fine.
