    Docker install on synology nas
    18 Posts 4 Posters 5.5k Views 4 Watching
      pauabaer @karsten13
      @karsten13
      I have the same issue but I do not really know how to run the container as user node with uid/gid 1000.
      You wrote two ways with the hint that this should happen as root. How do I do this?
      And can I make this run just for the MagicMirror docker? Because I have other dockers with other uids/gids.
      Thanks for your help.
      Paua
        sdetweil @pauabaer
        @pauabaer just change the docker compose .env file userid number from 1000 to whatever it is on your synology nas ( mine is 1026)
        (note the . in front of env)
          sdetweil @pauabaer
          @pauabaer yes, the user info is separate for each docker container
          think of a docker container as a mini pc disc, memory, cpu and software all inside a little case (container shell)
            pauabaer @sdetweil
            I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
            But I got the same message: access denied.
            So what would be the difference when I change the entry whithin the compose?
            And how do I find this file at my synology? :)
              sdetweil @pauabaer
              @pauabaer i do not know how to do it with the gui,
              there is a place where you can paste in the compose file . i have not tried that
              i ssh’d into the nas and did the manual install steps via commandline
                pauabaer @sdetweil
                I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
                  sdetweil @pauabaer
                  @pauabaer typically the group id is the same as the user id
                    @pauabaer
                    id -u will get this users id number
                    id -g will get this users group number
                      pauabaer @sdetweil
                      That’s what i checked before. Id -u > 1026 / id -g > 100.
                      These parameters i inserted in the compose file.
                        pauabaer @karsten13
                        @karsten13
                        I tried to start via command line
                        paua@NAS:~$ docker run  -d \
                        >         --user root \
                        > --name magicmirror \
                        >     --publish 8036:8080 \
                        >     --restart unless-stopped \
                        >     -e TZ=Europe/Berlin \
                        >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                        >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                        >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                        >     karsten13/magicmirror:latest
                        docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                        See 'docker run --help'.
                        But again I got the permission error.
                          pauabaer @pauabaer
                          I fixed it and now MM is running in docker on my synology diskstation.
                          I had to insert
                          user: root
                          in the compose file. It is working fine.
