    Docker install on synology nas
    18 Posts 4 Posters 5.7k Views 4 Watching
    • O
      oliv
      @karsten13 of course thanks for checking it out.
      Here is the docker start command:
      docker run  -d \
          --name magicmirror \
          --publish 8036:8080 \
          --restart unless-stopped \
          -e TZ=America/Chicago \
          --volume /volume1/docker/magicmirror/config:/opt/magic_mirror/config \
          --volume /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules \
          --volume /volume1/docker/magicmirror/css:/opt/magic_mirror/css \
          karsten13/magicmirror:latest
      and here are the logs of the container:
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @oliv
        @oliv
        looks like the volumes on the host were created by root. The user in the container runs as user node with uid/gid 1000.
        So you can try
        a) cd to /volume1/docker/ on the host and run chown -R 1000:1000 ./magicmirror (you have to do this as root)
        or
        b) run the container as user root, you have to add
            --user root \
        to the docker run ... command
        S P 3 Replies Last reply
          sdetweil @karsten13
          @karsten13 i think /opt is non existent on synology
          • karsten13K
            karsten13 @sdetweil
            @sdetweil said in Docker install on synology nas:
            but in the container
              sdetweil @oliv
              this turned out to be a permissions problem. the folder was created w the synology user, but the container is running as user 1000
                pauabaer @karsten13
                @karsten13
                I have the same issue but I do not really know how to run the container as user node with uid/gid 1000.
                You wrote two ways with the hint that this should happen as root. How do I do this?
                And can I make this run just for the MagicMirror docker? Because I have other dockers with other uids/gids.
                Thanks for your help.
                Paua
                S 2 Replies Last reply
                  sdetweil @pauabaer
                  @pauabaer just change the docker compose .env file userid number from 1000 to whatever it is on your synology nas ( mine is 1026)
                  (note the . in front of env)
                  P 1 Reply Last reply
                    sdetweil @pauabaer
                    @pauabaer yes, the user info is separate for each docker container
                    think of a docker container as a mini pc disc, memory, cpu and software all inside a little case (container shell)
                      pauabaer @sdetweil
                      I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
                      But I got the same message: access denied.
                      So what would be the difference when I change the entry whithin the compose?
                      And how do I find this file at my synology? :)
                        sdetweil @pauabaer
                        @pauabaer i do not know how to do it with the gui,
                        there is a place where you can paste in the compose file . i have not tried that
                        i ssh’d into the nas and did the manual install steps via commandline
                          pauabaer @sdetweil
                          I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
                            sdetweil @pauabaer
                            @pauabaer typically the group id is the same as the user id
                              @pauabaer
                              id -u will get this users id number
                              id -g will get this users group number
                                pauabaer @sdetweil
                                That’s what i checked before. Id -u > 1026 / id -g > 100.
                                These parameters i inserted in the compose file.
                                  pauabaer @karsten13
                                  @karsten13
                                  I tried to start via command line
                                  paua@NAS:~$ docker run  -d \
                                  >         --user root \
                                  >     -e TZ=Europe/Berlin \
                                  >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                                  >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                                  >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                                  docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                                  See 'docker run --help'.
                                  But again I got the permission error.
                                    pauabaer @pauabaer
                                    I fixed it and now MM is running in docker on my synology diskstation.
                                    I had to insert
                                    user: root
                                    in the compose file. It is working fine.
