    Docker install on synology nas
    18 Posts 4 Posters 5.1k Views 4 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      @sdetweil said in Docker install on synology nas:
      @karsten13 i think /opt is non existent on synology
      but in the container
        sdetweil @oliv
        this turned out to be a permissions problem. the folder was created w the synology user, but the container is running as user 1000
          pauabaer @karsten13
          @karsten13
          I have the same issue but I do not really know how to run the container as user node with uid/gid 1000.
          You wrote two ways with the hint that this should happen as root. How do I do this?
          And can I make this run just for the MagicMirror docker? Because I have other dockers with other uids/gids.
          Thanks for your help.
          Paua
            sdetweil @pauabaer
            @pauabaer just change the docker compose .env file userid number from 1000 to whatever it is on your synology nas ( mine is 1026)
            (note the . in front of env)
              sdetweil @pauabaer
              @pauabaer yes, the user info is separate for each docker container
              think of a docker container as a mini pc disc, memory, cpu and software all inside a little case (container shell)
                pauabaer @sdetweil
                I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
                But I got the same message: access denied.
                So what would be the difference when I change the entry whithin the compose?
                And how do I find this file at my synology? :)
                  sdetweil @pauabaer
                  @pauabaer i do not know how to do it with the gui,
                  there is a place where you can paste in the compose file . i have not tried that
                  i ssh’d into the nas and did the manual install steps via commandline
                    pauabaer @sdetweil
                    I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
                      sdetweil @pauabaer
                      @pauabaer typically the group id is the same as the user id
                        @pauabaer
                        id -u will get this users id number
                        id -g will get this users group number
                          pauabaer @sdetweil
                          That’s what i checked before. Id -u > 1026 / id -g > 100.
                          These parameters i inserted in the compose file.
                            pauabaer @karsten13
                            @karsten13
                            I tried to start via command line
                            paua@NAS:~$ docker run  -d \
                            >         --user root \
                            > --name magicmirror \
                            >     --publish 8036:8080 \
                            >     --restart unless-stopped \
                            >     -e TZ=Europe/Berlin \
                            >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                            >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                            >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                            >     karsten13/magicmirror:latest
                            docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                            See 'docker run --help'.
                            But again I got the permission error.
                              pauabaer @pauabaer
                              I fixed it and now MM is running in docker on my synology diskstation.
                              I had to insert
                              user: root
                              in the compose file. It is working fine.
