    Docker install on synology nas
    18 Posts 4 Posters 5.4k Views 4 Watching
    • O Offline
      oliv
      I have been trying to install the karsten13/magicmirror docker image on my synology NAS. I’ve tried with docker run scripts ssh’d in as root as well as normal compose method.
      The image always fails with this error in the log “mkdir: cannot create directory ‘/opt/magic_mirror/modules/default’: Permission denied”
      I can install and run the older bastilimbach/docker-magicmirror image without this error, but it is no longer supported and the custom css doesn’t properly load anymore with this image.
      Any advice would be greatly appreciated, I feel like I’m banging my head against a wall with this!
      karsten13K S 2 Replies Last reply Reply Quote 0
        sdetweil @oliv
        this turned out to be a permissions problem. the folder was created w the synology user, but the container is running as user 1000
        • karsten13K Offline
          karsten13 @oliv
          @oliv
          to understand what is happening I need
          • the full logs of the container
          • the start command (full docker run ... or compose file)
          • O Offline
            oliv
            @karsten13 of course thanks for checking it out.
            Here is the docker start command:
            docker run  -d \
                --name magicmirror \
                --publish 8036:8080 \
                --restart unless-stopped \
                -e TZ=America/Chicago \
                --volume /volume1/docker/magicmirror/config:/opt/magic_mirror/config \
                --volume /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules \
                --volume /volume1/docker/magicmirror/css:/opt/magic_mirror/css \
                karsten13/magicmirror:latest
            and here are the logs of the container:
            karsten13K 1 Reply Last reply Reply Quote 1
              karsten13 @oliv
              @oliv
              looks like the volumes on the host were created by root. The user in the container runs as user node with uid/gid 1000.
              So you can try
              a) cd to /volume1/docker/ on the host and run chown -R 1000:1000 ./magicmirror (you have to do this as root)
              or
              b) run the container as user root, you have to add
                  --user root \
              to the docker run ... command
              S P 3 Replies Last reply Reply Quote 1
                sdetweil @karsten13
                @karsten13 i think /opt is non existent on synology
                  karsten13 @sdetweil
                  @sdetweil said in Docker install on synology nas:
                  but in the container
                    sdetweil @oliv
                      pauabaer @karsten13
                      @karsten13
                      I have the same issue but I do not really know how to run the container as user node with uid/gid 1000.
                      You wrote two ways with the hint that this should happen as root. How do I do this?
                      And can I make this run just for the MagicMirror docker? Because I have other dockers with other uids/gids.
                      Thanks for your help.
                      Paua
                        sdetweil @pauabaer
                        @pauabaer just change the docker compose .env file userid number from 1000 to whatever it is on your synology nas ( mine is 1026)
                        (note the . in front of env)
                          sdetweil @pauabaer
                          @pauabaer yes, the user info is separate for each docker container
                          think of a docker container as a mini pc disc, memory, cpu and software all inside a little case (container shell)
                            pauabaer @sdetweil
                            I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
                            But I got the same message: access denied.
                            So what would be the difference when I change the entry whithin the compose?
                            And how do I find this file at my synology? :)
                              sdetweil @pauabaer
                              @pauabaer i do not know how to do it with the gui,
                              there is a place where you can paste in the compose file . i have not tried that
                              i ssh’d into the nas and did the manual install steps via commandline
                                pauabaer @sdetweil
                                I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
                                  sdetweil @pauabaer
                                  @pauabaer typically the group id is the same as the user id
                                    @pauabaer
                                    id -u will get this users id number
                                    id -g will get this users group number
                                      pauabaer @sdetweil
                                      That’s what i checked before. Id -u > 1026 / id -g > 100.
                                      These parameters i inserted in the compose file.
                                        pauabaer @karsten13
                                        @karsten13
                                        I tried to start via command line
                                        paua@NAS:~$ docker run  -d \
                                        >         --user root \
                                        >     -e TZ=Europe/Berlin \
                                        >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                                        >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                                        >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                                        docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                                        See 'docker run --help'.
                                        But again I got the permission error.
                                          pauabaer @pauabaer
                                          I fixed it and now MM is running in docker on my synology diskstation.
                                          I had to insert
                                          user: root
                                          in the compose file. It is working fine.
