    new Raspi OS release
    19 Posts 5 Posters 5.8k Views 5 Watching
      sdetweil @mumblebaj
      @mumblebaj every time they fiddle w the ui we have all kinds of fun. mostly not MagicMirror but rotation, sleep/wake,
      streaming
      mumblebajM 1 Reply Last reply Reply Quote 1
      • mumblebajM Offline
        @sdetweil Busy upgrading now. Will provide some feedback once done and MM is up and running. Will advise if my screen on and off stuff still work but may only be tomorrow sometime.
        mumblebajM 1 Reply Last reply Reply Quote 2
          mumblebaj Module Developer @mumblebaj
          @mumblebaj After the upgrade I got presented with a screen asking me to Keep Wayfire or Switch to Labwc. I elected to switch to labwc. I have opted to switch to labwc.
          Warning to others: this has reset my screen orientation and resolution. Easy fix for me but others may have a problem.
          What I have noticed, when upgrading, around 99% mark, it asked a bunch of questions around keeping labc configs or install the vendor ones, I elected Y to install the vendor ones for those and I have noticed that my MM splash screen at startup has been replaced by the Raspi one. Not an issue for me but for anybody else who may want to keep theirs say no to those questions.
          Started the MM and it is running. Now, just to test my Screen On and Off scripta later this evening and tomorrow morning to see if they still work as is. Will update but it looks fine thus far.
          • karsten13K Offline
            karsten13 @sdetweil
            thanks for the hint, had to check mmos …
              sdetweil @mumblebaj
              @mumblebaj yes, those prompts are problematic.
              i pipe all the output to the log during scripted install
              and set the option -y, reply yes
              well it doesn’t affect THOSE prompts, so upgrade and install hang. i’ve had to stop being nice and let all the junk fly by.
              and most of the users dont have a clue what to answer.
              but i cant ask different questions and feed the answers.
              sad.
                @sdetweil As was expected, my screen on and screen off scripts no longer work. I will have a look at them today and see if I can get them to work with Labwc else I will switch back to Wayfire. Will advise after I have had a chance to look at them.
                First have to give the boss his time today then I can play…😉
                  rkorell Module Developer @mumblebaj
                  @mumblebaj , @sdetweil ,
                  any idea, advise what will happen if updating bookworm while NOT using wayfire but X11 (because wayfire doesn’t work even in the earlier bookworm I had reconfigure to X11 in raspi-config)?
                  Thanks for any hint.
                  Regards,
                  Ralf
                    mumblebaj Module Developer @rkorell
                    @rkorell I just switched back to Wayfire now and it works fine for me. I am running Pi5. When I tested X11 the screen blanking did not work for me. I have been reading around Labwc and wlopm but have seen a lot of people having issues with Labwc. I will test it later today but for now I have switched back to Wayfire.
                    • BKeyportB Offline
                      BKeyport Module Developer @mumblebaj
                      I still take my mirror displays and put them back into X11 mode. It’s what I understand, it’s what allows me to do what I want to do.
                      R mumblebajM 2 Replies Last reply Reply Quote 2
                        rkorell Module Developer @BKeyport
                        @BKeyport said in new Raspi OS release:
                        So from your perspective X11 still does work?
                        Thanks and regards,
                        Ralf
                          mumblebaj Module Developer @BKeyport
                          @BKeyport X11 does not work for me, hence I use Wayfire. As Labwc is supposed to be the newer lighter compositor, I would like to get that to work for me.
                            sdetweil @mumblebaj
                            @mumblebaj @rkorell and rumor has it x11 is gone next release
                            edit: seems rumors are not true for trixie (next release code name)
                            thanks everyone
                            mumblebajM R 2 Replies Last reply Reply Quote 1
                              @sdetweil I did not see it mentioned for trixie, but that is possible.
                                @sdetweil said in new Raspi OS release:
                                bad news :-(
                                But may things becomes better and the wayland implementation is better in Trixie than in Bookworm…
                                Ralf
                                  @rkorell Just read that X11 is still there in Trixie. So no stress yet, but yes, it is old and may be on it’s way out one of these good ol days.
                                  R mumblebajM 2 Replies Last reply Reply Quote 1
                                    @mumblebaj
                                    Thanks for information!
                                    I currently stay with x11 because - at least in my configuration - I wasn’t able to use wayland …
                                    If this becomes better in further releases I simply would switch…
                                    Regards,
                                    Ralf
                                      @sdetweil So, I have not seen any issues thus far other than having to figure out the screen blanking for me on Labwc, I have to test the wlopm, but for now I have switched back to Wayfire. No other issues in logs etc.
