    MMM-SmartWebDisplay is not running under 2.31.0
    12 Posts 3 Posters 4.8k Views 3 Watching
    • V
      Volkae
      After the update to MM 2.31.0 MMM-SmartWebDisplay is gone. All the other modules don´t make any problems.
      Any Idea??
        sdetweil @Volkae
        @Volkae can you show the config of the module?
        if you look at the developer window (ctrl-shift-i) console tab
        can you see any errors , add smart to the filter field
        V 1 Reply Last reply
        • V
          Volkae @sdetweil
                          module: 'MMM-SmartWebDisplay',
                          position: 'middle_center',      // This can be any of the regions.
                                  logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                                  height:"600px", //hauteur du cadre en pixel ou %
                                  width:"400px", //largeur
                                  updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                                  NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                  displayLastUpdate: false, //to display the last update of the URL
                                                  displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                  url: ["rtsp://XXXXXXXXXXXXXXXXXXX/h264Preview_01_sub"], //source of the URL to be displayed
                                                  scrolling: "no", // allow scrolling or not. html 4 only
                                                  shutoffDelay: 10000 //delay in miliseconds to video shut-off while using together with MMM-PIR-Sensor
          S KristjanESPERANTOK 2 Replies Last reply
            sdetweil @Volkae
            @Volkaeplease always use code block for config and log info
            paste text into message editor, blank line above and below
            select text just paste
            hit button </>
            to wrap selection in code block
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @Volkae
              With a https address the module works on my system with MM v2.30.0 and v2.31.0. Does it work if you use a https address instead a rtsp one?
              Like this:
              url: ["https://www.openstreetmap.org/export/embed.html?bbox=-151.34765625000003%2C-39.77476948529546%2C142.20703125000003%2C75.00494000767517&amp;layer=mapnik"],
              • V
                Volkae @sdetweil
                okay, sorry, I will do my very best next time
                • V
                  Volkae @KristjanESPERANTO
                  @KristjanESPERANTO
                  I made a complete MM-new install on a new SD-Card. With your url it works. With my url it does not work. On my other MM with 2.30.0 my url works fine.
                  KristjanESPERANTOK 1 Reply Last reply
                    @Volkae I can’t get an rtsp stream work with MMM-SmartWebDisplay neither with MM 2.30.0 nor with 2.31.0. With MMM-MPlayer it works, but that module doesn’t have the same features as MMM-SmartWebDisplay.
                    • V
                      @KristjanESPERANTO
                      Oh, I see.
                      RTSP-Stream is running under 2.27.0.
                      Now MMM-SmartWebdisplay is only running under 2.27.0 and MMM-PublicTransportHafas is only running under 2.31.0 ☹️
                        @Volkae
                        Here you can find a quick and dirty approach to get an older version of MMM-PublicTransportHafas to run. I would prefer a cleaner solution, but I currently lack the capacity to dive deeper into this problem.
                        • V
                          @KristjanESPERANTO
                          not able to do this:
                          <error: Pfadspezifikation ‘v3.1.8’ stimmt mit keinen git-bekannten Dateien überein>
                            @Volkae Odd… What is the output if you run git tag in the directory ~/MagicMirror/modules/MMM-PublicTransportHafas? Did you run git checkout v3.1.8 in ~/MagicMirror/modules/MMM-PublicTransportHafas?
