    MMM-DBF does not work, no error messages
    12 Posts 3 Posters 2.6k Views 3 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @sletrabf
      @sletrabf With your config and the changes to the custom.css file, the module works on my system.
      Please show us the system information provided in the terminal when you start MM. It looks like this:
      [2025-05-18 11:54:32.378] [INFO]  System information:
      ### SYSTEM:   manufacturer: Notebook; model: N650DU; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 5.10.0-20-amd64
      ### VERSIONS: electron: 35.1.2; used node: 24.0.1; installed node: 24.0.1; npm: 10.9.0; pm2: 5.4.3
      ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
        sletrabf @KristjanESPERANTO
        @KristjanESPERANTO
        The same appears with app mode and table mode:
        [2025-05-18 15:53:57.429] [INFO]  System information:
        ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false
        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.25+rpt-rpi-v8
        ### VERSIONS: electron: 35.1.2; used node: 22.15.1; installed node: 22.15.1; npm: 10.9.2; pm2: 5.4.3
        [2025-05-18 15:53:59.735] [INFO]  updatenotification: Updater Class Loaded!
        [2025-05-18 15:53:59.737] [INFO]  updatenotification: Checking PM2 using...
        [2025-05-18 15:53:59.743] [INFO]  updatenotification: [PM2] You are not using pm2
        I could try more different things, also reinstall the whole MM if needed :)
        best regards,
        Felix
          @sletrabf Have you tried deactivating all modules except for MMM-DBF to see if the problem disappears?
            @KristjanESPERANTO
            OK, I temporarily disabled all other modules following this advice here except for MMM-DBF.
            With
            showApp: false,
            I now get a black (blank) screen; with “true” it is showing the timetable app but nothing else (as expected).
            Is there any way to enable a (verbose) logging output to show what this module does?
              showApp: false,
              disabled: true, is the option setting to disable modules. Where did you find showApp?
              So it works without the other modules and doesn’t work when you activate the other modules? Can you figure out with which module it stops working?
              Seem that this module doesn’t have debug outputs. Only errors you could see in the browser console.
              Also, maybe it is important - when I start up MagicMirror, it gives the following error messages:
              I’m quit sure this is unrelated to this issue. You can try using the Wayland start option (npm run start:wayland) instead of the default start option (npm run start).
                @KristjanESPERANTO said in MMM-DBF does not work, no error messages:
                showApp: false,
                I did use the setting disabled: true, to disable the other modules (as explained here). The setting showApp: false, tells MMM-DBF to not load the table in the iFrame but generate a HTML table from the loaded information. showApp: true, works whereas showApp: false, does not.
                No, disabling the other modules doesn’t change anything.
                OK, I’ll try to see something there!
                  sletrabf @sletrabf
                  @KristjanESPERANTO:
                  I installed the module MMM-ViewNotifications and then I added several notifications to the file MMM-DBF.js, see: https://pastebin.com/YZEYgPpA
                  Now the outcome is as follows:
                  showApp: true,
                  • The message “MMM_DBF_LOADED” is not shown. From my understanding this means that start() is not being (fully) executed?
                  • The following messages are shown (in this order): MMM_DBF_GENERATING_URL, MMM_DBF_IFRAME_URL_GENERATED, MMM_DBF_ERROR_PROCESSING_DATA.
                  showApp: false,
                  • Only the following message is shown: MMM_DBF_ERROR_PROCESSING_DATA
                  So, from my understanding, the error occurs here, possibly in the line await fetch (urlApi):
                    async getData() {
                      const self = this;
                      const urlApi = `${this.generateUrl()}&mode=json&version=3`;
                      const dataRequest = await fetch(urlApi);
                      if (!dataRequest.ok) {
                        // Show that the data request is being processed
                        this.sendNotification("MMM_DBF_ERROR_PROCESSING_DATA", { message: '[MMM-DBF] Data processing returned an error.'});
                        let message = `An error has occurred: ${dataRequest.status}`;
                        if (dataRequest.status === 300) {
                          message += " - Ambiguous station name.";
                        throw new Error(message);
                      else {
                        const data = await dataRequest.json();
                        this.sendNotification("MMM_DBF_START_PROCESSING_DATA", { message: '[MMM-DBF] Data processing started.'});
                        self.processData(data);
                      self.scheduleUpdate(self.config.retryDelay);
                  I’m somehow not able to see the actual error that happened. Could you maybe please point out where I have to look for the value of dataRequest.status?
                  Thanks in advance!
                  Best regards,
                  sletrabf
                    sdetweil @sletrabf
                    @sletrabf open the developers window
                    ctrl-shift-i
                    select the console tab
                    enter a unique part of the module name in the filter field, dbf
                    and see what you see
