    Default calendar customEvents not working
    22 Posts 2 Posters 5.9k Views 2 Watching
      pauabaer @sdetweil
      Meanwhile I found the right place. Sorry for this.
      In the pic below you can see the entry.
      Does help you?
        your search regex is wrong,
        ^(.+) (\\d{4}) Geburtstag$
        its captures EVERYTHING from the start… and there is nothing left for the remainder of the expression
        you need to capture any character UP to the 1st space,
        ^([^\s]+) (\d{4}) Gerburstag$
        I use https://regex101.com/ to test (see below)
        escape the backslash as required
        P 1 Reply Last reply
          pauabaer @sdetweil
          Ok. Within the regex101 there is no mistake. But when I change within the config nothing happens again.
            sdetweil @pauabaer
            @pauabaer you needed to escape the \ with another backslash
            in the string… its a javascript thing
            as I noted in my prior post
            also remove the leading /
              pauabaer @sdetweil
              I did. But…
              I got the feeling i am not far away from the solution. Have still patient to bring me to that point? :)
              S P 2 Replies Last reply
                sdetweil @pauabaer
                @pauabaer do you still see the same error in the dev console?
                  pauabaer @pauabaer
                    pauabaer @pauabaer
                    It’s not the error I saw before.
                      sdetweil @pauabaer
                      @pauabaer ok, i am at grandson baseball for a while
                        pauabaer @sdetweil
                        Ok. Let me know when you are back and can help again.
                        Thanks a lot.
                          sdetweil @pauabaer
                          @pauabaer I’m back
                          my config for customEvents is
        keyword: "Gerburtstag",
        symbol: "birthday-cake",
        transform: {
        search: "^([^\\s]+) (\\d{4}) Gerburtstag$",
        replace: "$1 ($2)",
        yearmatchgroup: 2
                          my test calendar event title (from the summary field in the actual ICS data) is
                          SUMMARY:test 1986 Gerburtstag
                          the debug line in the parser is
                          [2025-05-25 16:08:47.371] [DEBUG] title: test 1986 Gerburtstag
                          I see
                          I walked thru the code and it worked as expected…
