    Default calendar customEvents not working
    22 Posts 2 Posters 5.9k Views 2 Watching
      sdetweil @pauabaer
      @pauabaer you didn’t add the debug setting to config.js
      the transform happens in the front end, the backend (node_helper) gets the events from source and formats them for frontend.tye log you showed is from the backend
      P 1 Reply Last reply
        pauabaer @sdetweil
        I did add the debug setting but presumably at the wrong position.
        Thought I should add it here:
        header: "Familienkalender",
                           config:{
                                  loglevel: ["DEBUG"],
                                                customEvents: [
                                                        keyword: "Geburtstag",
                                                        symbol: "birthday-cake",
                                                        transform: {
        search: "^([^\']*) \'(\\d{4})$",
        replace: "$1 ($2)",
        yearmatchgroup: 2
          sdetweil @pauabaer
          @pauabaer logevel is above the modules list
          its not a module setting
            pauabaer @sdetweil
            Meanwhile I found the right place. Sorry for this.
            In the pic below you can see the entry.
            Does help you?
              your search regex is wrong,
              ^(.+) (\\d{4}) Geburtstag$
              its captures EVERYTHING from the start… and there is nothing left for the remainder of the expression
              you need to capture any character UP to the 1st space,
              ^([^\s]+) (\d{4}) Gerburstag$
              I use https://regex101.com/ to test (see below)
              escape the backslash as required
                pauabaer @sdetweil
                Ok. Within the regex101 there is no mistake. But when I change within the config nothing happens again.
                  sdetweil @pauabaer
                  @pauabaer you needed to escape the \ with another backslash
                  in the string… its a javascript thing
                  as I noted in my prior post
                  also remove the leading /
                    pauabaer @sdetweil
                    I did. But…
                    I got the feeling i am not far away from the solution. Have still patient to bring me to that point? :)
                    S P 2 Replies Last reply
                      sdetweil @pauabaer
                      @pauabaer do you still see the same error in the dev console?
                        pauabaer @pauabaer
                          pauabaer @pauabaer
                          It’s not the error I saw before.
                            sdetweil @pauabaer
                            @pauabaer ok, i am at grandson baseball for a while
                              pauabaer @sdetweil
                              Ok. Let me know when you are back and can help again.
                              Thanks a lot.
                                sdetweil @pauabaer
                                @pauabaer I’m back
                                my config for customEvents is
        keyword: "Gerburtstag",
        transform: {
        search: "^([^\\s]+) (\\d{4}) Gerburtstag$",
        replace: "$1 ($2)",
        yearmatchgroup: 2
                                my test calendar event title (from the summary field in the actual ICS data) is
                                SUMMARY:test 1986 Gerburtstag
                                the debug line in the parser is
                                [2025-05-25 16:08:47.371] [DEBUG] title: test 1986 Gerburtstag
                                I see
                                I walked thru the code and it worked as expected…
