    MMM-Pinfo Help
    5 Posts 3 Posters 736 Views 3 Watching
    • plainbrokeP Offline
      plainbroke
      I am having an issue with the display being different from one Pi to another.
      Mine is having issues with the dual lines.
      both are running the same configurations…
      S R 2 Replies Last reply Reply Quote 0
        plainbroke @plainbroke
        @rkorell
        Never mind I am stupid.
        I figured out that I had removed several sections of the config file that was in his readme. Then went and re numbered the lines.
        Which really upset the apple cart.
        I did have to change the parts you said @rkorell.
        But the rest was my doing. Compare the first Config i posted and this one and you will see what I did.
                                module: "MMM-Pinfo",
                                position: "middle_center",
                                  debug: false,
                                  refresh: 5000,
                                  itemAlign: "left",
                                  labelAlign: "left",
         valueAlign: "right",
        labelSize: 400,
        containerSize: 500,
                                  DEVICE: {
                                        labelModel: "Model",
                                        displayModel: true,
                                        orderModel: 1,
                                        labelSerial: "Serial",
                                        displaySerial: true,
                                        orderSerial: 2
                                  OS: {
                                        labelOs: "OS",
                                        displayOs: true,
                                        orderOs: 3
                                  NETWORK: {
                                        labelType: "NET Type",
                                        displayType: true,
                                        orderType: 4,
                                        labelIPv4: "IPv4",
                                        displayIPv4: true,
                                        orderIPv4: 5,
                                        labelIPv6: "IPv6",
        I deleted these 2 lines and then changed orderMac: 6  and so on down the
        List..
        DISPLAYIPV6: FALSE,
        ORDERIPV6: 6,
                                        labelMac: "MAC",
                                        displayMac: true,
                                        orderMac: 7
                                  RAM: {
                                        labelRam: "RAM",
                                        displayRam: true,
                                        orderRam: 8
                                  STORAGE: {
                                        labelStorage: "Storage",
                                        displayStorage: true,
                                        orderStorage: 9,
                                  CPU: {
                                        labelType: "CPU Type",
                                        displayType: true,
                                        orderType: 10,
                                        labelUsage: "CPU Usage",
                                        displayUsage: true,
                                        orderUsage: 11,
                                        labelTemp: "CPU Temp",
                                        displayTemp: true,
                                        orderTemp: 12
                                  UPTIME: {
                                        labelUptime: "Uptime",
                                        displayUptime: true,
                                        orderUptime: 13
                                  WARNING: {
                                        enable: true,
                                        interval: 1000 * 60 * 5,
                                        check: {
                                          CPU_TEMP: 65,
                                          CPU_USAGE: 75,
                                          RAM_USED: 80,
                                          STORAGE_USED: 80
          sdetweil @plainbroke
          @plainbroke css?
            rkorell Module Developer @plainbroke
            @plainbroke
            This time actually not a CSS issue :-)
            If I‘m not going wrong and remember correctly, I had a similar problem with MMM-Pinfo.
            There is a configuration option in the module-declaration in config.js.
            I‘ve set containerSize to 180.
            And valueAlign to right.
            This solved the shown overlayed look …
            And your labels are aligned „center“ - this I would set to left (labelAlign is the parameter)
            HTH,
            Warm regards,
            Ralf
              plainbroke @rkorell
              @rkorell @sdetweil
              Here is what I have in my config.js and custom.css
                                        debug: false,
                                        refresh: 10000,
                                        itemAlign: "left",
                                        labelAlign: "left",
                                        labelSize: "60px", //null,
                                        containerSize: "180px",
                                       DEVICE: {
                                              labelModel: "Model:",
                                              displayModel: true,
                                              orderModel: 1,
                                       OS: {
                                              labelOs: "OS:",
                                              displayOs: true,
                                              orderOs: 2
                                       NETWORK: {
                                              labelType: "NET Type:",
                                              displayType: true,
                                              orderType: 3,
                                              labelIPv4: "IPv4:",
                                              displayIPv4: true,
                                              orderIPv4: 4,
                                              labelMac: "MAC:",
                                              displayMac: true,
                                              orderMac: 5
                                       RAM: {
                                              labelRam: "RAM:",
                                              displayRam: true,
                                              orderRam: 6
                                       STORAGE: {
                                              labelStorage: "Storage:",
                                              orderStorage: 7,
                                       CPU: {
                                              labelType: "CPU Type:",
                                              displayType: true,
                                              orderType: 8,
                                              labelUsage: "CPU Usage:",
                                              displayUsage: true,
                                              orderUsage: 9,
                                              labelTemp: "CPU Temp:",
                                              displayTemp: true,
                                              orderTemp: 10
                                       UPTIME: {
                                                labelUptime: "Uptime:",
                                                orderUptime: 11
              CUSTOM.CSS ##########
              .Pinfo {
                      font-size: 50px;
                      line-height: 55px;
              And this is what I get
              @rkorell
              I tried changing the left to right and the size of the container from 80 to 1800 with absolutely no change.
              I made a test config.js so I could only have it on screen to test with.
              Doesn’t seem to matter what I change in the config.js It stays the same .
              I remove the lines from my custom.css and it is still the same only very small on my screen… 42" TV… The really weird part is it looks fine on my pi w2
                @rkorell
                                          debug: false,
                                          refresh: 5000,
                                          itemAlign: "left",
                                          labelAlign: "left",
                labelSize: 400,
                containerSize: 500,
                                          DEVICE: {
                                                displayModel: true,
                                                orderModel: 1,
                                                orderSerial: 2
                                          OS: {
                                                labelOs: "OS",
                                                displayOs: true,
                                                orderOs: 3
                                          NETWORK: {
                                                displayType: true,
                                                orderType: 4,
                                                labelIPv4: "IPv4",
                                                displayIPv4: true,
                                                orderIPv4: 5,
                                                labelIPv6: "IPv6",
                List..
                DISPLAYIPV6: FALSE,
                ORDERIPV6: 6,
                                                labelMac: "MAC",
                                                displayMac: true,
                                                orderMac: 7
                                          RAM: {
                                                labelRam: "RAM",
                                                displayRam: true,
                                                orderRam: 8
                                          STORAGE: {
                                                orderStorage: 9,
                                          CPU: {
                                                displayType: true,
                                                orderType: 10,
                                                displayUsage: true,
                                                orderUsage: 11,
                                                displayTemp: true,
                                                orderTemp: 12
                                          UPTIME: {
                                                orderUptime: 13
                                          WARNING: {
                                                enable: true,
                                                check: {
                                                  CPU_TEMP: 65,
                                                  CPU_USAGE: 75,
                                                  RAM_USED: 80,
                                                  STORAGE_USED: 80
