    2.32.0 Calendar module limitDays and excludedEvents stopped working
    41 Posts 5 Posters 9.0k Views 5 Watching
      sdetweil @AndyHazz
      @AndyHazz what release were you on prior to the upgrade?
      I don’t see any code change from 2.31
      | correction, there is a test of date after change here.
        sdetweil @AndyHazz
        @AndyHazz can you show your calendar config, xxx out the URLs.
          @AndyHazz I should note that this property is NOT a sequential limit of days from today
          it is UNIQUE days INCLUDING today
          limitDays:2
          so if there no events til next Thursday, that is the 1st day
          and no events til the following Tuesday, that is the second day
          which is different than event tomorrow and saturday, but only show tomorrow… (2 consecutive days gets today and tomorrow), or two days from NOW gets today/thurs/friday, but still not saturday.
            AndyHazz Project Sponsor @sdetweil
            @sdetweil yeah that’s what I was using limitDays for and it was working great for my needs until now - I have my kids school lessons synced to a google calendar, and setting limitDays to 1 used to show the full set of lessons for the day. When they get home from school (all events from the current day are in the past), it automatically showed all of the lessons for the following day. Best thing I’ve ever used MM for! Even highlights PE lessons so they know when to bring kit :)
            For me now, limitDays: 1 just shows the single next event even when there are 6 more events on that day (and if that event is ‘Tutor time’, it displays when it should be hidden).
            I can’t say exactly what version I was on prior to the update but it should have been whatever the previous version was - since I set this up with watchtower in docker I’ve not had to do any manual upgrades.
            Here’s my anonamised calendar config - I have 5 different calendar modules running if that’s likely to be a factor, but this is one that has the config issues:
                    module: 'calendar',
                    header: 'School day',
                    position: 'bottom_right',
                        coloredSymbol: true,
                        coloredText: true,
                        showLocation: true,
                        displaySymbol: false,
                        hideTime: true,
                        tableClass: 'medium',
                        flipDateHeaderTitle: true,
                        fade: false,
                        timeFormat: 'absolute',
                        dateFormat: 'ddd',
                        fullDayEventDateFormat: 'ddd',
                        urgency: '0',
                        sliceMultiDayEvents: true,
                        nextDaysRelative: false,
                        limitDays: 1,
                        fetchInterval: '600000',
                        displayRepeatingCountTitle: true,
                        wrapEvents: false,
                        //maxTitleLength: 30,
                        customEvents: [{ keyword: 'Physical Education', symbol: 'volleyball', color: 'Gold' }],
                        excludedEvents: [
                            'Tutor time'
                                symbol: 'graduation-cap',
                                url: 'https://calendar.google.com/calendar/ical/REDACTED/basic.ics'
            mumblebajM S 2 Replies Last reply Reply Quote 0
            • mumblebajM Offline
              mumblebaj Module Developer @AndyHazz
              @AndyHazz Do you mind sharing your ICS, anonymized off course.
                sdetweil @AndyHazz
                @AndyHazz found it…
                comparing date AND TIME oops…
                edit modules/default/calendar/calendar.js
                approx line 708
                change the lines marked below with //
                		if (this.config.limitDays > 0) {
                			let newEvents = [];
                			let lastDate = today.clone().subtract(1, "days").startOf('day');  // add .startOf('day'), note dot
                			let days = 0;
                			for (const ev of events) {
                				let eventDate = this.timestampToMoment(ev.startDate).startOf('day'); // add .startOf('day'), note dot
                  @sdetweil nice! Yes that’s fixed the limitDays issue for me …
                  Now, how about part 2 of my issue, the excludedEvents config? The first event showing for me is titled ‘Tutor time’ despite that string being excluded. I’ve tried other terms with/without spaces and nothing seems to work to exclude events any more?
                    sdetweil @AndyHazz
                    @AndyHazz working on it
                      @AndyHazz ok, got it too… this one looks like a javascript difference in scopes…
                      I added the Log.debug lines, they are not important
                      modules/default/calendar/calendarfetcherutils.js , starting line 18 (4 changes total)
                      see // change this line
                      	shouldEventBeExcluded (config, title) {
                      		let result = {  // change this line
                      			excluded: false,
                      			until: null
                      		for (let f in config.excludedEvents) {
                      			let filter = config.excludedEvents[f],  // this line uses the same variable name, filter,   now we have two,
                      				testTitle = title.toLowerCase(),
                      				until = null,
                      				useRegex = false,
                      				regexFlags = "g";
                      			if (filter instanceof Object) {
                      				if (typeof filter.until !== "undefined") {
                      					until = filter.until;
                      				if (typeof filter.regex !== "undefined") {
                      					useRegex = filter.regex;
                      				// If additional advanced filtering is added in, this section
                      				// must remain last as we overwrite the filter object with the
                      				// filterBy string
                      				if (filter.caseSensitive) {
                      					filter = filter.filterBy;
                      					testTitle = title;
                      				} else if (useRegex) {
                      					testTitle = title;
                      					regexFlags += "i";
                      				} else {
                      					filter = filter.filterBy.toLowerCase();
                      			} else {
                      				filter = filter.toLowerCase();
                      			Log.debug("should be excluded ", testTitle, filter, useRegex, regexFlags)
                      			if (CalendarFetcherUtils.titleFilterApplies(testTitle, filter, useRegex, regexFlags)) {
                      				if (until) {
                      					result.until = until;  // change this line
                      				} else {
                      					Log.debug("event should be excluded = true,", testTitle )
                      					result.excluded = true;  // change this line
                      				Log.debug("filter applies result =", result)
                      				break;
                      		Log.debug("filter applies returning =", result)
                      		return result;  // change this line
                        @sdetweil perhaps I’m missing something, but that’s not working for me - it’s made no difference, excluded events are still appearing … I’ve double checked and can’t spot anything amiss, I’ve made the 4 changes from ‘filter’ to ‘result’?
                          sdetweil @AndyHazz
                          @AndyHazz hm…
                          my config parm for excluded Events
                          I added one event for saturday… without excluded it shows, with excluded it doesn’t
                                     excludedEvents: [
                                          'Birthday'
                          I checked the changed lines and only see those 4
                          - is old line
                          + is new line
                                   * until: the date until the event should be excluded.
                          -               let filter = {
                          +               let result = {
                                                  excluded: false,
                                                  until: null
                          @@ -52,17 +52,20 @@ const CalendarFetcherUtils = {
                                                  } else {
                                                          if (until) {
                          -                                       filter.until = until;
                          +                                       result.until = until;
                                                          } else {
                          -                                       filter.excluded = true;
                          +                                       result.excluded = true;
                                                          break;
                          -               return filter;
                          +               return result;
                            @sdetweil yep that’s what I’ve got, copying below in case I’m missing something …
                            I’ve also added your debug messages back in and changed Log.debug to console.log (as I still can’t get any debug logs from docker but I do get console.log messages from other modules) but nothing comes out in the console log - seems odd that all these changes have had zero effect, am I missing something that might be needed to get these changes to kick in?
                                            let result = {  // CHANGED
                                                    excluded: false,
                                                    until: null
                                                            until = null,
                                                            useRegex = false,
                                                            regexFlags = "g";
                                                            // filterBy string
        testTitle = title;
        testTitle = title;
        regexFlags += "i";
                                                            } else {
                                                    } else {
                                                    console.log("should be excluded ", testTitle, filter, useRegex, regexFlags)
                                                            if (until) {
        result.until = until;  // CHANGED
                                                            } else {
        console.log("event should be excluded = true,", testTitle )
        result.excluded = true;  // CHANGED
                                                            console.log("filter applies result =", result)
                                                            break;
                                            console.log("filter applies returning =", result)
                                            return result;  // CHANGED
                            p.s. just spotted comment on line 12 😅
                            TODO This seems like an overly complicated way to exclude events based on the title.
                              sdetweil @AndyHazz
                              @AndyHazz note that the excluded events is an ARRAY (so for loop to look thru them )
                              test ALL til find one that is true (CalendarFetcherUtils.titleFilterApplies returns true) , or not
                              AND the item in the array can be an object with more specific controls, or a string
                              MM doc entries on separate lines
                              'Birthday',     // text
                              'Hide This Event',    // text
                              {filterBy: 'Payment', until: '6 days', caseSensitive: true},  // complex, but text
                              {filterBy: '^[0-9]{1,}.*', regex: true} // complex, uses regex
                              AND the list/array can be a MIX of those things,
                              and the string test is the test string is SOMEWHERE in the title, doesn’t have to BE the entire title
                                @sdetweil fair enough, complexity no doubt warranted!
                                Perhaps is there any reason why shouldEventBeExcluded function might not be getting called at all for me? I’m stumped why after making all these changes including console.log messages, nothing is appearing any different -
                                S 3 Replies Last reply Reply Quote 0
                                  sdetweil @AndyHazz
                                  @AndyHazz can’t think of any, MM is case sensitive, some times people get the case wrong and we don’t report unexpected parms or missing parms…
                                  but you’ve been using that so, it doesn’t shouldn’t be an issue for you
                                    sdetweil @AndyHazz
                                    @AndyHazz I copied your post in exactly, i reverted back to 2.32 original first
                                    and got the right debug and results
                                    [2025-07-09 16:27:38.473] [DEBUG] Processing entry…
                                    [2025-07-09 16:27:38.473] [DEBUG] title: Dad’s Birthday
                                    [2025-07-09 16:27:38.473] [LOG] should be excluded dad’s birthday birthday false g
                                    [2025-07-09 16:27:38.473] [LOG] event should be excluded = true, dad’s birthday
                                    [2025-07-09 16:27:38.473] [LOG] filter applies result = { excluded: true, until: null }
                                    [2025-07-09 16:27:38.473] [LOG] filter applies returning = { excluded: true, until: null }
                                      sdetweil @AndyHazz
                                      @AndyHazz and
                                      the fetcherutils processes this exclude list very early after getting the events parsed
                                                      // loop thru the parsed data, one event at a time
                                      		Object.entries(data).forEach(([key, event]) => {
                                      			Log.debug("Processing entry...");
                                      			const title = CalendarFetcherUtils.getTitleFromEvent(event);
                                      			Log.debug(`title: ${title}`);
                                      			// Return quickly if event should be excluded.
                                      			let { excluded, eventFilterUntil } = this.shouldEventBeExcluded(config, title);
                                      			if (excluded) {
                                      				return;
                                        @sdetweil should I see a console message from loader.js about calendarfetcherutils.js being loaded?
                                        I see
                                        Load script: modules/default/calendar/calendar.js
                                        Load script: modules/default/calendar/calendarutils.js
                                        but no mention in the console of calendarfetcherutils.js
                                          sdetweil @AndyHazz
                                          @AndyHazz no.
                                            @sdetweil I’ve no idea then, but if you were able to reproduce the issue I had, and then fix it on your end, I probably just messed something up somewhere and without any access to logs on my docker setup that may remain a mystery … I’ve just had another go at trying to figure out what that may be, no luck.
                                            No rush at all but I guess if you’re happy with the fix it’ll show up in a new MM version at some point and I’ll update to that.
                                            • 2 / 3
