    2.32.0 Calendar module limitDays and excludedEvents stopped working
    41 Posts 5 Posters 10.9k Views 5 Watching
    • A
      AndyHazz Project Sponsor @sdetweil
      @sdetweil ah - I did have ‘limitDays: 1’ previously but added the quotes to try and fix - I’ve removed them again but either way seems to make no difference.
      I’m not sure how to get the debug log out though, as I’m using a docker setup, not pm2, and can’t figure out how to stop the running instance first (so it looks like it fails to start fully) - here’s what I get:
      docker exec -it mm bash
      node@magicmirroros:/opt/magic_mirror$ npm start
      > magicmirror@2.32.0 start
      > node --run start:x11
      [2025-07-07 12:55:11.034] [LOG]   Starting MagicMirror: v2.32.0
      [2025-07-07 12:55:11.114] [LOG]   Loading config ...
      [2025-07-07 12:55:11.125] [LOG]   config template file not exists, no envsubst
      [2025-07-07 12:55:13.444] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
      [2025-07-07 12:55:13.892] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-07-07 12:55:13.898] [INFO]  Checking modules structure configuration ...
      [2025-07-07 12:55:14.362] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-07-07 12:55:14.890] [LOG]   Loading module helpers ...
      [2025-07-07 12:55:15.014] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:15.022] [LOG]   Module helper loaded: MMM-mmpm
      [2025-07-07 12:55:15.892] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:15.894] [LOG]   Module helper loaded: MMM-Remote-Control
      [2025-07-07 12:55:16.549] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:16.551] [LOG]   Module helper loaded: MMM-AuroraWatchUK
      [2025-07-07 12:55:18.106] [LOG]   MMM-Scrapey node helper is starting...
      [2025-07-07 12:55:18.108] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:18.109] [LOG]   Module helper loaded: MMM-Scrapey
      [2025-07-07 12:55:18.180] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:18.182] [LOG]   Module helper loaded: MMM-MoonPhase
      [2025-07-07 12:55:18.193] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:18.196] [LOG]   Module helper loaded: MMM-WatchDog
      [2025-07-07 12:55:18.201] [LOG]   No helper found for module: alert.
      [2025-07-07 12:55:18.395] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:18.396] [LOG]   Module helper loaded: MMM-ModuleScheduler
      [2025-07-07 12:55:18.402] [LOG]   No helper found for module: clock.
      [2025-07-07 12:55:19.042] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:19.043] [LOG]   Module helper loaded: calendar
      [2025-07-07 12:55:19.050] [LOG]   No helper found for module: weather.
      [2025-07-07 12:55:19.141] [LOG]   Initializing new module helper ...
      [2025-07-07 12:55:19.142] [LOG]   Module helper loaded: MMM-MyGarbage
      [2025-07-07 12:55:19.145] [LOG]   All module helpers loaded.
      [2025-07-07 12:55:19.177] [LOG]   Starting server on port 8080 ...
      [2025-07-07 12:55:19.185] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-07-07 12:55:19.278] [ERROR] Whoops! There was an uncaught exception...
      [2025-07-07 12:55:19.281] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (node:net:1940:16)
          at listenInCluster (node:net:1997:12)
          at node:net:2206:7
          at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
        code: 'EADDRINUSE',
        errno: -98,
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080
      [2025-07-07 12:55:19.284] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2025-07-07 12:55:19.286] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      [2025-07-07 12:55:20.074] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: Docker Container; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-v8
      ### VERSIONS: electron: undefined; used node: 22.17.0; installed node: 22.17.0; npm: 10.9.2; pm2:
      ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
        sdetweil @AndyHazz
        @AndyHazz yeh, another place where docker is unhelpful
        Maybe on the docker host
        docker compose down mm
        docker compose up mm > somefile.txt
        A 1 Reply Last reply
        • A
          @sdetweil if I cd into /opt/mm/run I can get some output but still looks like it fails before giving anything useful:
          docker compose up > somefile.txt
          [+] Running 5/5
           ✔ Container watchtower  Created0.0s
           ✔ Container xserver     Created0.0s
           ✔ Container init        Created0.0s
           ✔ Container mm          Created0.0s
           ✔ Container mmpm        Created0.0s
          xserver     |
          xserver     | X.Org X Server 1.21.1.14
          xserver     | X Protocol Version 11, Revision 0
          xserver     | Current Operating System: Linux ad48284f7eed 6.6.74+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27) aarch64
          xserver     | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=de21c80a-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB video=HDMI-A-1:1920x1080M@60,rotate=270
          xserver     |
          xserver     | Current version of pixman: 0.43.4
          xserver     |   Before reporting problems, check http://wiki.x.org
          xserver     |   to make sure that you have the latest version.
          xserver     | Markers: (--) probed, (**) from config file, (==) default setting,
          xserver     |   (++) from command line, (!!) notice, (II) informational,
          xserver     |   (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
          xserver     | (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul  7 13:42:05 2025
          xserver     | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
          watchtower  | time="2025-07-07T13:42:06Z" level=info msg="Watchtower 1.7.1"
          watchtower  | time="2025-07-07T13:42:06Z" level=info msg="Using no notifications"
          watchtower  | time="2025-07-07T13:42:06Z" level=info msg="Checking all containers (except explicitly disabled with label)"
          watchtower  | time="2025-07-07T13:42:06Z" level=info msg="Scheduling first run: 2025-07-14 13:42:06 +0000 UTC"
          watchtower  | time="2025-07-07T13:42:06Z" level=info msg="Note that the first check will be performed in 167 hours, 59 minutes, 59 seconds"
          mm          | [2025-07-07 14:42:46.322] [WARN]  You're using a full whitelist configuration to allow for all IPs
          mm          | [2025-07-07 14:43:11.194] [ERROR] Mon Jul 07 2025 14:43:11 GMT+0100 (British Summer Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
          mm          | [2025-07-07 14:43:37.677] [WARN]  You're using a full whitelist configuration to allow for all IPs
          mm          | [2025-07-07 14:43:48.386] [ERROR] Whoops! There was an uncaught exception...
          mm          | [2025-07-07 14:43:48.396] [ERROR] TypeError: Unexpected ? at 17, expected END: https://git.new/pathToRegexpError
          mm          |     at Iter.consume (/opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:123:15)
          mm          |     at consume (/opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:179:16)
          mm          |     at parse (/opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:183:20)
          mm          |     at /opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:294:74
          mm          |     at Array.map (<anonymous>)
          mm          |     at pathToRegexp (/opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:294:25)
          mm          |     at Object.match (/opt/magic_mirror/node_modules/path-to-regexp/dist/index.js:264:30)
          mm          |     at matcher (/opt/magic_mirror/node_modules/router/lib/layer.js:86:23)
          mm          |     at new Layer (/opt/magic_mirror/node_modules/router/lib/layer.js:93:46)
          mm          |     at router.route (/opt/magic_mirror/node_modules/router/index.js:428:17)
          mm          |     at Class.createApiRoutes (/opt/magic_mirror/modules/MMM-Remote-Control/API/api.js:172:24)
          mm          |     at Class.onModulesLoaded (/opt/magic_mirror/modules/MMM-Remote-Control/node_helper.js:83:10)
          mm          |     at Class.loadModuleDefaultConfig (/opt/magic_mirror/modules/MMM-Remote-Control/node_helper.js:354:25)
          mm          |     at /opt/magic_mirror/modules/MMM-Remote-Control/node_helper.js:225:14
          mm          |     at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3)
          mm          | [2025-07-07 14:43:48.397] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          mm          | [2025-07-07 14:43:48.398] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
          mm          | [2025-07-07 14:43:48.405] [ERROR] Mon Jul 07 2025 14:43:48 GMT+0100 (British Summer Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
          … then it just gets stuck in a loop trying to restart
          mumblebajM KristjanESPERANTOK 2 Replies Last reply
          • mumblebajM
            mumblebaj Module Developer @AndyHazz
            @AndyHazz You can do the following from the docker host, docker compose up -d this will launch you container. Then you can run the following command docker exec -it magicmirror bash replacing magicmirror with your container name. This essentially puts you into the MagicMirror directory. You can then acces the debug log from there.
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @AndyHazz
              @AndyHazz said in 2.32.0 Calendar module limitDays and excludedEvents stopped working:
              Looks like an issue with MMM-Remote-Control.
              Which version are you using? Run grep '"version":' package.json in MMM-Remote-Control’s directory to find out.
              • A
                AndyHazz Project Sponsor @mumblebaj
                @mumblebaj for a bit more context I’m using MagicMirrorOS and it’s been great whilst it was working, but certainly seems to make dubugging harder so perhaps I’ll switch back to regular setup when I get a bit more time …
                To clarify, I’m only seeing errors when trying to work around lack of access to logs in docker - if I just let the system run normally I’m not getting any errors, just an unexpected change in calendar behaviour.
                docker compose up -d works if I enter /opt/mm/run directory first.
                Not sure I need that compose up command though as the container is running ok already. docker exec -it mm bash works to get into the container, but then I can’t find any debug logs …
                @KristjanESPERANTO I’m not sure but I think the errors referring to MMM-Remote-Control I posted were more to do with my failed attempts to get logs from the docker container, not the original issue of calendar display … but in case you’re onto something:
                > node@magicmirroros:/opt/magic_mirror/modules/MMM-Remote-Control$ grep '"version":' package.json
                  "version": "3.1.4",
                KristjanESPERANTOK 1 Reply Last reply
                  Not sure, but you have a rather old version of MMM-Remote-Control which is only compatible to a limited extent with MM 2.32.0. If you update MMM-Remote-Control, the start of MM may not abort like above.
                  • A
                    AndyHazz Project Sponsor @KristjanESPERANTO
                    @KristjanESPERANTO I’ve been able to update MMM-Remote-Control to 3.2.0 and you were right that stops the errors I was getting in the logs when running docker compose up.
                    Still doesn’t look like there are any clues there for my calendar issues though …
                    docker compose up > somenewfile.txt        ─╯
                    [+] Running 6/6
                     ✔ Network magicmirror_default  Created0.2s
                     ✔ Container xserver            Created0.8s
                     ✔ Container watchtower         Created0.7s
                     ✔ Container init               Created0.8s
                     ✔ Container mm                 Created0.2s
                     ✔ Container mmpm               Created0.2s
                    xserver     |
                    xserver     | Current Operating System: Linux 2133690aa282 6.12.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64
                    xserver     |
                    xserver     | (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul  8 21:49:11 2025
                    watchtower  | time="2025-07-08T21:49:12Z" level=info msg="Watchtower 1.7.1"
                    watchtower  | time="2025-07-08T21:49:12Z" level=info msg="Using no notifications"
                    watchtower  | time="2025-07-08T21:49:12Z" level=info msg="Checking all containers (except explicitly disabled with label)"
                    watchtower  | time="2025-07-08T21:49:12Z" level=info msg="Scheduling first run: 2025-07-15 21:49:12 +0000 UTC"
                    watchtower  | time="2025-07-08T21:49:12Z" level=info msg="Note that the first check will be performed in 167 hours, 59 minutes, 59 seconds"
                    mm          | [2025-07-08 22:50:02.823] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    mm          | [2025-07-08 22:50:26.661] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:50:26.684] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:50:26.765] [ERROR] Tue Jul 08 2025 22:50:26 GMT+0100 (British Summer Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
                    mm          | [2025-07-08 22:50:26.873] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:50:26.888] [ERROR] table not found in HTML.
                    mm          | npm notice
                    mm          | npm notice New major version of npm available! 10.9.2 -> 11.4.2
                    mm          | npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.4.2
                    mm          | npm notice To update run: npm install -g npm@11.4.2
                    mm          | npm notice
                    mm          | [2025-07-08 22:50:56.210] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    mm          | [2025-07-08 22:51:04.036] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:51:04.866] [ERROR] Tue Jul 08 2025 22:51:04 GMT+0100 (British Summer Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
                    mm          | [2025-07-08 22:51:24.381] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    mm          | [2025-07-08 22:51:42.944] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:51:42.966] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:52:10.109] [ERROR] table not found in HTML.
                    mm          | [2025-07-08 22:52:11.413] [ERROR] table not found in HTML.
                    I think the repeating ‘table not found in HTML’ error is just from my MMM-Scrapey module, as it’s looking for bus times and it’s late, the last bus has gone.
                      @AndyHazz Unfortunately, I don’t know if I can help any further here. The error message ([ERROR] table not found in HTML.) is indeed from MMM-Scrapey - I have created a pull request for the module to improve logging, at least in the future.
                      • A
                        Thanks, I’ve merged that logging improvement to MMM-Scrapey.
                        I suppose my query is simply whether anybody else can see the same calendar functionality issues as me?
                        • limitDays has changed to limit the number of calendar items, not the number of days worth of calendar items
                        • excludedEvents appears to do nothing any more, events matching excluded words have started showing when prior to 2.32.0 they were hidden
                        If it’s only affecting me, I’ll probably try rebuilding my setup from scratch.
                        S 2 Replies Last reply
                          sdetweil @AndyHazz
                          @AndyHazz what release were you on prior to the upgrade?
                          I don’t see any code change from 2.31
                          | correction, there is a test of date after change here.
                            sdetweil @AndyHazz
                            @AndyHazz can you show your calendar config, xxx out the URLs.
                              @AndyHazz I should note that this property is NOT a sequential limit of days from today
                              it is UNIQUE days INCLUDING today
                              limitDays:2
                              so if there no events til next Thursday, that is the 1st day
                              and no events til the following Tuesday, that is the second day
                              which is different than event tomorrow and saturday, but only show tomorrow… (2 consecutive days gets today and tomorrow), or two days from NOW gets today/thurs/friday, but still not saturday.
                              • A
                                @sdetweil yeah that’s what I was using limitDays for and it was working great for my needs until now - I have my kids school lessons synced to a google calendar, and setting limitDays to 1 used to show the full set of lessons for the day. When they get home from school (all events from the current day are in the past), it automatically showed all of the lessons for the following day. Best thing I’ve ever used MM for! Even highlights PE lessons so they know when to bring kit :)
                                For me now, limitDays: 1 just shows the single next event even when there are 6 more events on that day (and if that event is ‘Tutor time’, it displays when it should be hidden).
                                I can’t say exactly what version I was on prior to the update but it should have been whatever the previous version was - since I set this up with watchtower in docker I’ve not had to do any manual upgrades.
                                Here’s my anonamised calendar config - I have 5 different calendar modules running if that’s likely to be a factor, but this is one that has the config issues:
                                        module: 'calendar',
                                        header: 'School day',
                                        position: 'bottom_right',
                                            coloredSymbol: true,
                                            coloredText: true,
                                            showLocation: true,
                                            displaySymbol: false,
                                            hideTime: true,
                                            tableClass: 'medium',
                                            flipDateHeaderTitle: true,
                                            fade: false,
                                            timeFormat: 'absolute',
                                            dateFormat: 'ddd',
                                            fullDayEventDateFormat: 'ddd',
                                            urgency: '0',
                                            sliceMultiDayEvents: true,
                                            nextDaysRelative: false,
                                            limitDays: 1,
                                            fetchInterval: '600000',
                                            displayRepeatingCountTitle: true,
                                            wrapEvents: false,
                                            //maxTitleLength: 30,
                                            customEvents: [{ keyword: 'Physical Education', symbol: 'volleyball', color: 'Gold' }],
                                            excludedEvents: [
                                                'Tutor time'
                                                    symbol: 'graduation-cap',
                                                    url: 'https://calendar.google.com/calendar/ical/REDACTED/basic.ics'
                                mumblebajM S 2 Replies Last reply
                                • mumblebajM
                                  @AndyHazz Do you mind sharing your ICS, anonymized off course.
                                    sdetweil @AndyHazz
                                    @AndyHazz found it…
                                    comparing date AND TIME oops…
                                    edit modules/default/calendar/calendar.js
                                    approx line 708
                                    change the lines marked below with //
                                    		if (this.config.limitDays > 0) {
                                    			let newEvents = [];
                                    			let lastDate = today.clone().subtract(1, "days").startOf('day');  // add .startOf('day'), note dot
                                    			let days = 0;
                                    			for (const ev of events) {
                                    				let eventDate = this.timestampToMoment(ev.startDate).startOf('day'); // add .startOf('day'), note dot
                                    • A
                                      @sdetweil nice! Yes that’s fixed the limitDays issue for me …
                                      Now, how about part 2 of my issue, the excludedEvents config? The first event showing for me is titled ‘Tutor time’ despite that string being excluded. I’ve tried other terms with/without spaces and nothing seems to work to exclude events any more?
                                        sdetweil @AndyHazz
                                        @AndyHazz working on it
                                          @AndyHazz ok, got it too… this one looks like a javascript difference in scopes…
                                          I added the Log.debug lines, they are not important
                                          modules/default/calendar/calendarfetcherutils.js , starting line 18 (4 changes total)
                                          see // change this line
                                          	shouldEventBeExcluded (config, title) {
                                          		let result = {  // change this line
                                          			excluded: false,
                                          			until: null
                                          		for (let f in config.excludedEvents) {
                                          			let filter = config.excludedEvents[f],  // this line uses the same variable name, filter,   now we have two,
                                          				testTitle = title.toLowerCase(),
                                          				until = null,
                                          				useRegex = false,
                                          				regexFlags = "g";
                                          			if (filter instanceof Object) {
                                          				if (typeof filter.until !== "undefined") {
                                          					until = filter.until;
                                          				if (typeof filter.regex !== "undefined") {
                                          					useRegex = filter.regex;
                                          				// If additional advanced filtering is added in, this section
                                          				// must remain last as we overwrite the filter object with the
                                          				// filterBy string
                                          				if (filter.caseSensitive) {
                                          					filter = filter.filterBy;
                                          					testTitle = title;
                                          				} else if (useRegex) {
                                          					testTitle = title;
                                          					regexFlags += "i";
                                          				} else {
                                          					filter = filter.filterBy.toLowerCase();
                                          			} else {
                                          				filter = filter.toLowerCase();
                                          			Log.debug("should be excluded ", testTitle, filter, useRegex, regexFlags)
                                          			if (CalendarFetcherUtils.titleFilterApplies(testTitle, filter, useRegex, regexFlags)) {
                                          				if (until) {
                                          					result.until = until;  // change this line
                                          				} else {
                                          					Log.debug("event should be excluded = true,", testTitle )
                                          					result.excluded = true;  // change this line
                                          				Log.debug("filter applies result =", result)
                                          				break;
                                          		Log.debug("filter applies returning =", result)
                                          		return result;  // change this line
                                          • A
                                            @sdetweil perhaps I’m missing something, but that’s not working for me - it’s made no difference, excluded events are still appearing … I’ve double checked and can’t spot anything amiss, I’ve made the 4 changes from ‘filter’ to ‘result’?
