    2.32.0 Calendar module limitDays and excludedEvents stopped working
    41 Posts 5 Posters 10.9k Views 5 Watching
    • A
      AndyHazz Project Sponsor @sdetweil
      @sdetweil fair enough, complexity no doubt warranted!
      Perhaps is there any reason why shouldEventBeExcluded function might not be getting called at all for me? I’m stumped why after making all these changes including console.log messages, nothing is appearing any different -
      S 3 Replies Last reply
        sdetweil @AndyHazz
        @AndyHazz can’t think of any, MM is case sensitive, some times people get the case wrong and we don’t report unexpected parms or missing parms…
        but you’ve been using that so, it doesn’t shouldn’t be an issue for you
          sdetweil @AndyHazz
          @AndyHazz I copied your post in exactly, i reverted back to 2.32 original first
          and got the right debug and results
          [2025-07-09 16:27:38.473] [DEBUG] Processing entry…
          [2025-07-09 16:27:38.473] [DEBUG] title: Dad’s Birthday
          [2025-07-09 16:27:38.473] [LOG] should be excluded dad’s birthday birthday false g
          [2025-07-09 16:27:38.473] [LOG] event should be excluded = true, dad’s birthday
          [2025-07-09 16:27:38.473] [LOG] filter applies result = { excluded: true, until: null }
          [2025-07-09 16:27:38.473] [LOG] filter applies returning = { excluded: true, until: null }
            sdetweil @AndyHazz
            @AndyHazz and
            the fetcherutils processes this exclude list very early after getting the events parsed
                            // loop thru the parsed data, one event at a time
            		Object.entries(data).forEach(([key, event]) => {
            			Log.debug("Processing entry...");
            			const title = CalendarFetcherUtils.getTitleFromEvent(event);
            			Log.debug(`title: ${title}`);
            			// Return quickly if event should be excluded.
            			let { excluded, eventFilterUntil } = this.shouldEventBeExcluded(config, title);
            			if (excluded) {
            				return;
            A 1 Reply Last reply
            • A
              @sdetweil should I see a console message from loader.js about calendarfetcherutils.js being loaded?
              I see
              Load script: modules/default/calendar/calendar.js
              Load script: modules/default/calendar/calendarutils.js
              but no mention in the console of calendarfetcherutils.js
                sdetweil @AndyHazz
                @AndyHazz no.
                • A
                  @sdetweil I’ve no idea then, but if you were able to reproduce the issue I had, and then fix it on your end, I probably just messed something up somewhere and without any access to logs on my docker setup that may remain a mystery … I’ve just had another go at trying to figure out what that may be, no luck.
                  No rush at all but I guess if you’re happy with the fix it’ll show up in a new MM version at some point and I’ll update to that.
                  S 2 Replies Last reply
                    sdetweil @AndyHazz
                    @AndyHazz next release isn’t til Oct 1
                      @AndyHazz weird…
                        sdetweil @AndyHazz
                        @AndyHazz would you be willing to test another implementation of the limitDays code fix
                        another author has changed the code quite a bit,
                        copy the existing calendar.js so not losing what you have
                        new code
                        		if (this.config.limitDays > 0 && events.length>0) {   // line 708
                        			// Group all events by date, events on the same date will be in a list with the key being the date.
                        			Log.info("limitdays starting, events list length=", events.length)
                        			const eventsByDate = Object.groupBy(events, (ev) => this.timestampToMoment(ev.startDate).format("YYYY-MM-DD"));
                        			Log.info("eventsByDate keys=",Object.keys(eventsByDate))
                        			const newEvents = [];
                        			let currentDate = moment().subtract(1,'days');
                        			let daysCollected = 0;
                        			while (daysCollected < this.config.limitDays) {
                        				const dateStr = currentDate.format("YYYY-MM-DD");
                        				Log.info("limitDays checking=",dateStr)
                        				// Check if there are events on the currentDate
                        				if (eventsByDate[dateStr])
                        					Log.info("eventsByDate[",dateStr,"] length=",eventsByDate[dateStr].length)
                        				if (eventsByDate[dateStr] && eventsByDate[dateStr].length > 0) {
                        					// If there are any events today then get all those events and select the currently active events and the events that are starting later in the day.
                        					newEvents.push(...eventsByDate[dateStr].filter((ev) => this.timestampToMoment(ev.endDate).isAfter(moment())));
                        					// Since we found a day with events, increase the daysCollected by 1
                        					daysCollected++;
                        					Log.info("limitDays, found day with events, count=",daysCollected)
                        			        // Search for the next day
                        				currentDate.add(1, "day");
                        			Log.info("limitDays done")
                        			events = newEvents;
                        this line is unchanged after replacing above code
                        		Log.info(`slicing events total maxcount=${this.config.maximumEntries}`);  // this line is unchanged
                        • A
                          @sdetweil no problem, that new code seems to work fine for me.
                          However, I don’t seem to have a great setup for testing - after making the changes, I can load up MM in my remote/laptop browser and immediately see the changes working, but if I try and refresh the electron browser on the raspberry pi running my mirror (using MMM-Remote-Control), it seems to take ages, crash, and then reverts the code back to the docker image default 😮‍💨
                          I can see this in the docker container logs so I reckon it’s reverting any changes I make there?
                          [entrypoint 18:36:04.283] [INFO]   copy default modules
                          [entrypoint 18:36:04.918] [INFO]   copy css files
                          > magicmirror@2.32.0 start
                          > node --run start:x11
                          karsten13K 1 Reply Last reply
                          • karsten13K
                            karsten13 @AndyHazz
                            @AndyHazz said in 2.32.0 Calendar module limitDays and excludedEvents stopped working:
                            yes it overrides the default modules but you can change this behavior
                            • A
                              AndyHazz Project Sponsor @karsten13
                              @karsten13 aha, good to know, although I already started and now finished setting up from scratch again 🙄 no docker this time … I kept it on a spare sd card though so may switch back.
                              @sdetweil new code for limitDays reapplied on a fresh install, still seems fine. Previous suggestions to fix the excludedEvents still not working though.
                              • A
                                AndyHazz Project Sponsor @AndyHazz
                                @sdetweil hold up - it’s all working now! I don’t think I changed anything else, just an extra refresh. So, all your fixes are good. Sorry that took a while to figure out, and if I’d read @karsten13’s docker instructions properly I think that docker module override feature was probably the cause of earlier confusion.
                                  sdetweil @AndyHazz
                                  @AndyHazz thanks for the feedback and extra effort
                                    sdetweil @AndyHazz
                                    @AndyHazz these fixes are in the next release Oct 1
                                    • J Jacky5 referenced this topic on
                                    • 2 / 3
