    2.32.0 Calendar module limitDays and excludedEvents stopped working
    41 Posts 5 Posters 10.9k Views 5 Watching
      sdetweil @AndyHazz
      @AndyHazz and
      the fetcherutils processes this exclude list very early after getting the events parsed
                      // loop thru the parsed data, one event at a time
      		Object.entries(data).forEach(([key, event]) => {
      			Log.debug("Processing entry...");
      			const title = CalendarFetcherUtils.getTitleFromEvent(event);
      			Log.debug(`title: ${title}`);
      			// Return quickly if event should be excluded.
      			let { excluded, eventFilterUntil } = this.shouldEventBeExcluded(config, title);
      			if (excluded) {
      				return;
      A 1 Reply Last reply
      • A
        AndyHazz Project Sponsor @sdetweil
        @sdetweil should I see a console message from loader.js about calendarfetcherutils.js being loaded?
        I see
        Load script: modules/default/calendar/calendar.js
        Load script: modules/default/calendar/calendarutils.js
        but no mention in the console of calendarfetcherutils.js
          sdetweil @AndyHazz
          @AndyHazz no.
          • A
            @sdetweil I’ve no idea then, but if you were able to reproduce the issue I had, and then fix it on your end, I probably just messed something up somewhere and without any access to logs on my docker setup that may remain a mystery … I’ve just had another go at trying to figure out what that may be, no luck.
            No rush at all but I guess if you’re happy with the fix it’ll show up in a new MM version at some point and I’ll update to that.
            S 2 Replies Last reply
              sdetweil @AndyHazz
              @AndyHazz next release isn’t til Oct 1
                @AndyHazz weird…
                  sdetweil @AndyHazz
                  @AndyHazz would you be willing to test another implementation of the limitDays code fix
                  another author has changed the code quite a bit,
                  copy the existing calendar.js so not losing what you have
                  new code
                  		if (this.config.limitDays > 0 && events.length>0) {   // line 708
                  			// Group all events by date, events on the same date will be in a list with the key being the date.
                  			Log.info("limitdays starting, events list length=", events.length)
                  			const eventsByDate = Object.groupBy(events, (ev) => this.timestampToMoment(ev.startDate).format("YYYY-MM-DD"));
                  			Log.info("eventsByDate keys=",Object.keys(eventsByDate))
                  			const newEvents = [];
                  			let currentDate = moment().subtract(1,'days');
                  			let daysCollected = 0;
                  			while (daysCollected < this.config.limitDays) {
                  				const dateStr = currentDate.format("YYYY-MM-DD");
                  				Log.info("limitDays checking=",dateStr)
                  				// Check if there are events on the currentDate
                  				if (eventsByDate[dateStr])
                  					Log.info("eventsByDate[",dateStr,"] length=",eventsByDate[dateStr].length)
                  				if (eventsByDate[dateStr] && eventsByDate[dateStr].length > 0) {
                  					// If there are any events today then get all those events and select the currently active events and the events that are starting later in the day.
                  					newEvents.push(...eventsByDate[dateStr].filter((ev) => this.timestampToMoment(ev.endDate).isAfter(moment())));
                  					// Since we found a day with events, increase the daysCollected by 1
                  					daysCollected++;
                  					Log.info("limitDays, found day with events, count=",daysCollected)
                  			        // Search for the next day
                  				currentDate.add(1, "day");
                  			Log.info("limitDays done")
                  			events = newEvents;
                  this line is unchanged after replacing above code
                  		Log.info(`slicing events total maxcount=${this.config.maximumEntries}`);  // this line is unchanged
                  • A
                    @sdetweil no problem, that new code seems to work fine for me.
                    However, I don’t seem to have a great setup for testing - after making the changes, I can load up MM in my remote/laptop browser and immediately see the changes working, but if I try and refresh the electron browser on the raspberry pi running my mirror (using MMM-Remote-Control), it seems to take ages, crash, and then reverts the code back to the docker image default 😮‍💨
                    I can see this in the docker container logs so I reckon it’s reverting any changes I make there?
                    [entrypoint 18:36:04.283] [INFO]   copy default modules
                    [entrypoint 18:36:04.918] [INFO]   copy css files
                    > magicmirror@2.32.0 start
                    > node --run start:x11
                    karsten13K 1 Reply Last reply
                    • karsten13K
                      karsten13 @AndyHazz
                      @AndyHazz said in 2.32.0 Calendar module limitDays and excludedEvents stopped working:
                      yes it overrides the default modules but you can change this behavior
                      • A
                        AndyHazz Project Sponsor @karsten13
                        @karsten13 aha, good to know, although I already started and now finished setting up from scratch again 🙄 no docker this time … I kept it on a spare sd card though so may switch back.
                        @sdetweil new code for limitDays reapplied on a fresh install, still seems fine. Previous suggestions to fix the excludedEvents still not working though.
                        • A
                          AndyHazz Project Sponsor @AndyHazz
                          @sdetweil hold up - it’s all working now! I don’t think I changed anything else, just an extra refresh. So, all your fixes are good. Sorry that took a while to figure out, and if I’d read @karsten13’s docker instructions properly I think that docker module override feature was probably the cause of earlier confusion.
                            sdetweil @AndyHazz
                            @AndyHazz thanks for the feedback and extra effort
                              sdetweil @AndyHazz
                              @AndyHazz these fixes are in the next release Oct 1
                              • J Jacky5 referenced this topic on
                              • 2 / 3
