    Update a module whit git pull didn't work...
    12 Posts 4 Posters 10.5k Views 4 Watching
    • G Offline
      gismo2006
      ok i have tested it now again. after i write git pull my pi write this…
      remote: Counting objects: 24, done.
      remote: Compressing objects: 100% (10/10), done.
      remote: Total 24 (delta 11), reused 9 (delta 9), pack-reused 5
      Entpacke Objekte: 100% (24/24), Fertig.
      Von https://github.com/MichMich/MagicMirror
      5d63065…9bd42ac develop -> origin/develop
      Already up-to-date.
      And because this link i think it like to update mm² and not the module. https://github.com/MichMich/MagicMirror
        Burner911 @gismo2006
        @gismo2006 I think I am actually having a similar issue as you. I updated the same module last night using git pull, but the module is not functioning properly. @strawberry-3-141 any chance we need to npm install inside the folder again?
        • G Offline
          gismo2006
          @strawberry-3-141
          I have to lie to answer this question.
          I think i have install it with git clone. but iam not realy sure. but i think you are right that can be the misstake… :-)
          greets gismo
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Burner911
            @Burner911 only if the dependencies have changed
            • G Offline
              gismo2006
              Okay I have a new Problem. Because git pull didn’t work, i Download the git Repo as an zip file and extract into my module folder. I change the name to the correct module name and rename the old remote Modul folder. Then I restart mm2 and I only see a white page and my pi crashes. But I remember i have seen this Problem in this forum in a post too. But now I’ll decide to go sleep i will check this tomorrow.
              So good night good morning or whatever is right now :-)
                strawberry 3.141 Project Sponsor Module Developer @gismo2006
                @gismo2006 well, you will have the same problem again next time when you have downloaded it manually
                did you install the dependencies?
                • G Offline
                  gismo2006
                  @strawberry-3-141 i think I have, because it works fine till this update. But I found maybe a solution in this post: https://forum.magicmirror.builders/topic/1561/white-screen-after-mmm-remote-control-update/7
                  I will test it later…
                    PeppaPigKilla
