    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 48.2k Views 20 Watching
    • PierreGodeP
      PierreGode Module Developer @mischag
      @mischag
      Hi the ip adress id 192.168.1.whatevertheipofghepi:5003
      • PierreGodeP
        PierreGode Module Developer @sarote
        @sarote
        It is done
          sdetweil @PierreGode
          @PierreGode .1 is typically the router , not the pi
          on the MagicMirror system do
          ip addr
          PierreGodeP 1 Reply Last reply
          • PierreGodeP
            PierreGode Module Developer @sdetweil
            What?? 🤭
            Like I said I think it is 192.168.subdomain.yourip ❤️
            So yes you are right 1 could be 0 depending on your router. I mention http://yourmirrorip:5003/ in my readme for the reason that it can vary, it could even be 10. 24.x.x
              @PierreGode yes. all my routers set their ip address to.1 of the assigned address range
              home is 192.168.2.(1)
              a test network i have it 10.0.2.(1)
              all the devices start at .2
              on linux
              ip addr
              will give this machine’s address
              on windows its
              ipconfig /all
                supascoopa74 @mischag
                @mischag I’m having the exact same problems that you describe here. Cannot connect to admin page via ip address/trying to use the admin.html page directly is non-responsive. Did you make any progress?
                • PierreGodeP
                  PierreGode Module Developer @supascoopa74
                  @supascoopa74 @mischag
                  I created a wiki on the repository I hope it helps.
                  https://github.com/PierreGode/MMM-Chores/wiki/MMM‐Chores-Wiki
                  KristjanESPERANTOK K S 3 Replies Last reply
                  • KristjanESPERANTOK
                    KristjanESPERANTO Module Developer @PierreGode
                    @PierreGode The wiki page is empty :-(
                    S PierreGodeP 2 Replies Last reply
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO i see the link to the front page
                      • PierreGodeP
                        PierreGode Module Developer @KristjanESPERANTO
                        @KristjanESPERANTO
                        Thank you, updated
                        • K
                          khayfer @PierreGode
                          @PierreGode Hello, I’m having the same issues as supascoopa74 and mischag. I went through all the points in the wiki page and still unable to get to the admin page. Checked my firwalls and they were “open”… unsure how to proceed.
                            sdetweil @khayfer
                            @khayfer what is the address: setting in config.js
                            it CANNOT be localhost. as thst mesns only apps INSIDE the same system can connect (a browser on the same system)
                            K 1 Reply Last reply
                              supascoopa74 @PierreGode
                              @PierreGode Thank you for the wiki. I didn’t realize the MagicMirror needs to be running for the admin page to work. Doh! It works now trying to access myPIip:5003 from another computer on my network.
                              • PierreGodeP
                                PierreGode Module Developer @khayfer
                                @khayfer Hi!
                                Could you tell me about your setup?
                                Is it ”vanilla” raspberry pi setup?
                                What is pm2 logs saying?
                                • K
                                  khayfer @sdetweil
                                  @sdetweil my apologies for the late reply, the stomach flu ravaged our home this past week.
                                  As for the address in config it is set to “local host” and it lists the raspberry pi 's ip address.
                                    sdetweil @khayfer
                                    @khayfer address:“localhost”
                                    means ONLY apps INSIDE the same system can connect, means a browser started from the desktop
                                    if you want to use another system, set
                                    address:“0.0.0.0”,
                                    • K
                                      khayfer @sdetweil
                                      @sdetweil I changed it to 0.0.0.0 and it still says it could not connect to the server :-/
                                        sdetweil @khayfer
                                        @khayfer can you open the MagicMirror page from that machine?
                                        many browsers have started to implement local network access security. i know on my mac, i cannot access my 3d print server w chrome anymore. i have to use safari
                                        • K
                                          khayfer @sdetweil
                                          @sdetweil yes, I’m able to use the browser in the pi. I can navigate the internet no problem, but the moment I type the ip address, it still says could not connect to the server.
                                          I then tried it on multiple different devices/browsers on the same wifi and they all say the same thing.
                                            sdetweil @khayfer
                                            @khayfer and you are doing
                                            http://address:port
                                            for MagicMirror
                                            port from config.js
                                            on the same machine
                                            you can use localhost
                                            http://localhost:8080
                                            ip addr
                                            will give you the address of the pi
                                            from your laptop
                                            http://xxxxx:8080
                                            where xxxxx was the addr from ip addr
                                            • 3 / 6
