    updating without losing settings in config, and js files?
    10 Posts 6 Posters 7.3k Views 5 Watching
    • N Offline
      navyvette87
      I just updated today and had to reset all the screen adjustments I had set during build. Is there a way to do the update without it changing the files back to default?
        Cyberwrights
        Do all of your editing, configuration and addition of new modules in the MagicMirror/config/config.js file.
        Did you modify each module’s javascript file separately?
        MMM-GoogleAssistant
        MMM-Hue
        MMM-MyCommute
        MMM-Formula1
        MMM-SystemStats
        MMM-moon-phases
        • N Offline
          navyvette87 @Cyberwrights
          @Cyberwrights mine is highly modified. Pretty much every character is changed in some way.
          N N 2 Replies Last reply Reply Quote 0
          • N Offline
            ninjabreadman @navyvette87
            @navyvette87 @Cyberwrights is right, and where possible you should migrate your changes into config.js, custom.css, etc.
            When updating, git insists that your files not have changes that conflict with those of the repository. Use git stash as outlined here to store your local changes, pull updates from the repo, then restore your own changes.
            • MichMichM Offline
              MichMich
              Just curious, why would you modify any file other than the config.js and the custom.css file?
              • N Offline
                Nneuland @navyvette87
                @navyvette87
                I am not aware of how to implement “everything” into config.js.
                Custom MMM-remotecontrol buttons, cache options, MMM-spotify buttons…
                S N 2 Replies Last reply Reply Quote 0
                  sdetweil @Nneuland
                  @Nneuland ALL module and MagicMirror config goes in config.js
                  the design is anything in config.js is used before the defaults from system and modules
                  ALL css goes in css/custom.css
                  anything in css/custom.css overrides anything specified by modules or system settings
                  IF you edit any other file, you risk blocking updates AND losing your changes when you force update
                  the override design means you never have your lose anything
                  this is why my upgrade script is 2 pass, to warn you of changes(that you may have forgotten) that WILL be lost.
                  • N Offline
                    Nneuland @Nneuland
                    Just to play devils advocate. Wouldn’t some modifications need to take place before electron launches?
                    I’d love to clean up my set up. is there any way to single out modified files that need to be implemented into config.js
                      sdetweil @Nneuland
                      @Nneuland no, we read config. js for electron options and
                      commandline switches too
                      to detect changes to base files, in each place (MagicMirror snd module folders ) do
                      git status
                      if there are modified files do
                      git diff filename
                      to see the actual changes
                      once you migrate those to config.js
                      git stash the changed files in that location
                      run MagicMirror and test that
                      then git stash pop
                      to restore from stash
                      the git checkout filename
                      to restore from the repository (hidden in .git folder)
                      repeat til no changed files and MagicMirror and modules run as expected
                      • N Offline
                        Nneuland @Nneuland
                        This is gold. Thank you Sam!
