    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 424.6k Views 32 Watching
    • BKeyportB
      @sdetweil I added it, and it seemed to delete all the calendars, so I removed it, and they’re still gone.
      They are broadcasting correctly from calendar.
      I’ve restarted both the server and the client.
      ACK!
        sdetweil @BKeyport
        @BKeyport again watch out for waitFetch and refreshInterval
        if the events come AFTER waitfetch (default 5 seconds)
        they wait til refreshInterval (default 30 minutes)
        • BKeyportB
          @sdetweil both are set low, and it worked before. - – whoops - forgot I moved refresh up on those as they don’t change very much. Restored them to 1 minute for testing.
          – and it don’t seem to be targeting correctly. does nothing.
            sdetweil @BKeyport
            @BKeyport and you removed the custom.css entry
            • BKeyportB
              @sdetweil yeah, I put it back… both it, and the target I wrote up don’t target it.
                sdetweil @BKeyport
                @BKeyport ok , ill look at it tomorrow. i dont use agenda normally
                  sdetweil @BKeyport
                  @BKeyport ok, he has an attribute on the agenda day, which contains the count of events
                  this will hide the day if there are no events
                  .CX3A [data-events-counts='0'] {
                    display: none;
                  • F
                    FMancuso5 @sdetweil
                    Thanks for the info. I read through that thread and made some adjustments. I have waitFetch for both CX3 and CX3A set for 20 seconds. I left the refresh intervals at 30 min. Prior to the waitFetch, at startup the CX3 module would have a calendar or two missing, but it would correct at the next refresh interval. With waitFetch, all events display when the calendar is drawn, which makes obvious sense. The extra time helped.
                    That didn’t change the CX3A module though. It’s still blank in the bottom right corner of the screen, save for my “Next 3 Days” header. It stays blank even when I shorten the refreshInterval to run it through some extra cycles. All the necessary calendars are broadcasting without issue, I can see that on the terminal when I stop MM. I’m trying to make sense of it because my understanding is that both CX3 and CX3A modules grab the default calendar broadcasts simultaneously. And my weekly CX3 module is functioning perfectly right next to it.
                      sdetweil @FMancuso5
                      @FMancuso5 can you show the agenda config?
                      here is mine
                            module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                            classes:"page1",
                              showMiniMonthCalendar: false,
                              refreshInterval: 3600000, // Should be one hour
                              waitFetch: 20000,
                              firstDayOfWeek: 0,
                              startDayIndex: 1,
                              endDayIndex: 30,
                              animationSpeed: 0,
                              useSymbol: true,
                              useWeather: false,
                      • F
                        FMancuso5 @sdetweil
                                    header: "Next 3 Days",
                                        showMiniMonthlyCalendar: false,
                                        instanceId: "basicAgenda",
                                        locale: "en-US",
                                        startDayIndex: 0,
                                        endDayIndex: 3,
                                        calendarSet: ["John", "Jane", "Joe", "Jill", "Family", "Important"],
                                        waitFetch: 30 * 1000,
                                        refreshInterval: 30 * 60 * 1000,
                          sdetweil @FMancuso5
                          @FMancuso5 one thing, for all config and logs, PLEASE use the code wrapper here in the forums…
                          to do this
                          copy the text you want to post
                          paste into the message editor, blank line above and below
                          select the text you just pasted
                          hit the </> button over the editor
                          I fixed the prior post
                            sdetweil @FMancuso5
                            @FMancuso5 said in MMM-CalendarExt3Agenda:
                                        startDayIndex: 0,
                                        endDayIndex: 3,
                            sorry to ask dumb question, are there events in the next 3 days?
                            if you remove those do you get a display?
                            if you comment out the calendarSets does that make a difference
                            waitFecth, 30 seconds, then nothing til refreshInterval…(30 minutes)
                            make waitFetch longer, 60*1000 (1 minute)
                            to test
                            • BKeyportB
                              Sam: Here’s a live example of no-event item, and an event item. The count don’t show unless it’s got 1 event. Module_4 is blank, Module_5 is showing one event.
                              <div id="module_4_MMM-CalendarExt3Agenda" class="module MMM-CalendarExt3Agenda MMM-CalendarExt3Agenda" style="order: 0;">
                                  <header class="module-header" style="display: none;">undefined</header>
                                  <div class="module-content">
                                      <div class="bodice CX3A_undefined CX3A">
                                          <div class="agenda"></div>
                                      </div>
                                  </div>
                              </div>
                              <div id="module_5_MMM-CalendarExt3Agenda" class="module MMM-CalendarExt3Agenda MMM-CalendarExt3Agenda" style="order: 0;">
                                              <div class="cell thisMonth thisYear year_2025 month_8 date_10 weekday_0 seq_0 week_32 weekend weekend_2" data-events-counts="1">
                                                  <div class="cellHeader">
                                                      <div class="cellHeaderMain">
                                                          <div class="cellDay relativeDay relativeNamedDay relativeDayGap_1"><span class="dateParts literal seq_0 unit_none">tomorrow</span></div>
                                                          <div class="cellDate"><span class="dateParts weekday seq_0">Sunday</span><span class="dateParts literal seq_1">, </span><span class="dateParts month seq_2">Aug</span><span class="dateParts literal seq_3"> </span><span class="dateParts day seq_4">10</span></div>
                                                          <div class="cw">32</div>
                                                      </div>
                                                      <div class="cellHeaderSub"></div>
                                                  </div>
                                                  <div class="cellBody">
                                                      <div class="fullday"></div>
                                                      <div class="single">
                                                          <div class="event calendar_Sounders future singleday" data-calendar-seq="1" data-calendar-name="Sounders" data-color="#5D9741" data-description="Calendar not up to date? Check https://fixtur.es/up-to-date" data-title="Los Angeles Galaxy - Seattle Sounders FC" data-full-day-event="false" data-geo="false" data-location="" data-start-date="1754877600000" data-end-date="1754883900000" data-today="false" data-symbol="fas fa-fw fa-futbol" style="--calendarColor: #5D9741; --oppositeColor: white;">
                                                              <div class="headline useSymbol"><span class="symbol"><span class="fas fa-fw fa-futbol"></span></span>
        <div class="time startTime inDay"><span class="eventTimeParts hour seq_0">7</span><span class="eventTimeParts literal seq_1">:</span><span class="eventTimeParts minute seq_2">00</span><span class="eventTimeParts literal seq_3"> </span><span class="eventTimeParts dayPeriod seq_4">PM</span></div>
        <div class="time endTime inDay"><span class="eventTimeParts hour seq_0">8</span><span class="eventTimeParts literal seq_1">:</span><span class="eventTimeParts minute seq_2">45</span><span class="eventTimeParts literal seq_3"> </span><span class="eventTimeParts dayPeriod seq_4">PM</span></div>
        <div class="title">Los Angeles Galaxy - Seattle Sounders FC</div>
                                                              </div>
                                                              <div class="description">Calendar not up to date? Check https://fixtur.es/up-to-date</div>
                                                              <div class="location"></div>
                                                          </div>
                                                      </div>
                                                  </div>
                                                  <div class="cellFooter"></div>
                                              </div>
                                          </div>
                                      </div>
                                  </div>
                              </div>
                                sdetweil @BKeyport
                                @BKeyport you want the whole module gone. right?
                                • BKeyportB
                                  @sdetweil correct.
                                    sdetweil @BKeyport
                                    @BKeyport my previous has() should have worked…
                                    let me see how to get empty instance
                                      sdetweil @BKeyport
                                      @BKeyport
                                      note the CX3A class is NOT added to the module entry
                                      div id="module_4_MMM-CalendarExt3Agenda" class="module **MMM-CalendarExt3Agenda** MMM-CalendarExt3Agenda" style="order: 0;">
                                      but to the bodice entry
                                      so the outer div still took up space
                                      this works,
                                      .MMM-CalendarExt3Agenda:has(.agenda:empty){
                                              /* background-color: red;*/
                                              display: none;
                                      • F
                                        FMancuso5 @sdetweil
                                        My apologies! I’ll make sure I format correctly going forward.
                                        Not a dumb question at all, that was the first thing I checked. I wish my life would go three days without an event. But I’ve tried setting endDayIndex to 10, eliminating the indexes completely, eliminating the calendarSet, stripping the entire module down to just the header, the position, the waitFetch and refreshInterval, and it’s still blank. The only way I know that there’s something happening is the header is still there. I tried commenting out the other modules and positioning CX3A top left to see if it was a graphics issue but it’s the same empty header. Yet when I fire up all the modules, CX3 weekly is still showing every event perfectly from the first fetch. I’m stumped. And then when I quit out, the terminal shows no issues, and lists all the events that are successfully being broadcasted by each calendar.
                                          sdetweil @FMancuso5
                                          @FMancuso5 can you try this
                                          https://forum.magicmirror.builders/post/127456
                                          • BKeyportB
                                            @sdetweil Nope. Not working. I give up. Just turning off that mirror completely… will find something else to do my calendar on.
                                            • 10
                                            • 11
                                            • 12
                                            • 11 / 12
