    MMM-next-episode
    23 Posts 3 Posters 7.1k Views 3 Watching
    • PierreGodeP
      PierreGode Module Developer @rambomonkey
      @rambomonkey
      Hi! I am the maintainer of MMM-next-episode
      could you verify that you have this in your config.js
        module: "MMM-next-episode",
        position: "bottom_right",
        header: "Next-Episode",
          hash_key: '',
          username:'your-next-episode-username',
          password: 'your-next-episode-password',
          displayShowingOn: true,
          displaySeasonAndEpisode: false,
          maxdays: 5,
          ShowThumbnail: true,
          ThumbnailSize: 'small',
          updateInterval: 180
      I just tested it on main branch and gave me the qr code after a pm2 restart
      then the id and hash might appear as one long string but the first 9 numbers is your id and the rest is the hash.
      verify that magic mirror is latest version.
      R 2 Replies Last reply
        rambomonkey @PierreGode
        @PierreGode Hi thanks for coming back to me. Below is in my config:
        //MMM-Next-Episode
            hash_key: '',
            username: 'myuser',
            password: 'mypass',
            displaySeasonAndEpisode: true,
            displayEpisodeName: true,
            maxdays: 7,
            updateInterval: 180
        MM version is v2.32.0
          @PierreGode Hi, thanks for coming back to me. MM version is v2.32.0, and below is what’s in my config.js
          //MMM-Next-Episode
              hash_key: '',
              username: 'myuser',
              password: 'mypass',
              maxdays: 7,
              updateInterval: 180
          R 1 Reply Last reply
            sdetweil @rambomonkey
            @rambomonkey in the future, please use the code block wrapper for config entries and any log info
            to do this
            select the text you want to paste
            in the message editor, paste the text, with a blank line before and after
            then select the text you just pasted and press the </> button on the editor menu bar
            this will keep the formatting and make long items (logs) scrollable…
            I fixed the prior entries
              rambomonkey @sdetweil
              @sdetweil Hi sorry about that I did not know.
                rambomonkey @rambomonkey
                This might have something to do with it @PierreGode I see an error on server startup:
                [2025-08-21 19:19:45.691] [WARN] No /root/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js found for module: MMM-next-episode.
                But MMM-next-episode.js is present in the MMM-next-episode DIR
                  @rambomonkey said in mmm-next-episode:
                  /MMM-next-episode
                  magic mirror is case sensitive…
                  I think the module name is mmm-next-episode
                    @sdetweil Hi, I have changed the config.js and I still get the same error:
                    [2025-08-21 19:25:57.758] [WARN] No /root/MagicMirror/modules/mmm-next-episode/mmm-next-episode.js found for module: mmm-next-episode.
                    S 2 Replies Last reply
                      @rambomonkey ok, so if you go to the MagicMirror/modules folder and do
                      ls -laF
                      do you find a folder with the proper name…
                      note the module name, the folder name AND the js file AND the register in the js file names MUST match exactly
                        No /root/
                        also, NEVER run this stuff as root…
                        is that the user you used when you installed the module???
                          @sdetweil to be honest I cannot remember if I used root or not:
                          root@mmnew:~/MagicMirror/MMM-next-episode# ls -laF
                          total 108
                          drwxr-xr-x 6 root root 4096 Aug 21 19:22 ./
                          drwxr-xr-x 15 root root 4096 Aug 19 20:51 …/
                          drwxr-xr-x 8 root root 4096 Aug 19 18:45 .git/
                          drwxr-xr-x 3 root root 4096 Aug 19 18:45 .github/
                          -rwxr-xr-x 1 root root 31 Aug 19 18:45 .gitignore*
                          -rw-r–r-- 1 root root 35149 Aug 19 18:45 LICENSE
                          -rw-r–r-- 1 root root 602 Aug 19 18:45 MMM-next-episode.css
                          -rw-r–r-- 1 root root 5798 Aug 19 18:45 MMM-next-episode.js
                          -rw-r–r-- 1 root root 4613 Aug 19 18:45 README.md
                          drwxr-xr-x 2 root root 4096 Aug 19 18:45 img/
                          -rw-r–r-- 1 root root 2904 Aug 19 18:45 node_helper.js
                          drwxr-xr-x 33 root root 4096 Aug 19 18:45 node_modules/
                          -rw-r–r-- 1 root root 13972 Aug 19 18:45 package-lock.json
                          -rw-r–r-- 1 root root 544 Aug 19 18:45 package.json
                          S PierreGodeP 2 Replies Last reply
                            @rambomonkey uou can see root owns the files
                            if you try to run as a normal user, you dont have permission to access them at all
                            thus the not found
                              @sdetweil Thanks for the info, sorry im new to Linux. Would you happen to know how I could give a specific user the permissions?
                                @rambomonkey
                                the permissions are 3 sets of 3 rights
                                user read/write/execute
                                group anyone in this group
                                other anybody not specified above
                                the commands
                                are chmod which can set the individual
                                permissions using flags or a number
                                777 means all for all
                                770 mean user and group users can do anything, everyone else no access
                                the there is chgrp to change the group
                                all commands have help
                                –help
                                and most have a page in the manuals
                                man commandname
                                man chmod
                                man chgrp
                                you
                                eill need root permission to take root
                                permissions away
                                sudo gives root permission for this command
                                • PierreGodeP
                                  @rambomonkey
                                  So this is how you want your Magic mirror setup to look like.
                                  yeah no /root/ that can create a loads of headaches like this.
                                    @PierreGode @sdetweil thanks you two, think I will just re-install as a normal user, you live and learn lol.
                                      @PierreGode Hi, I have now re-installed it under user petek and I’m still seeing the same issue:
                                      petek@MagicMirror-v2:/home/MagicMirror$ ls -la /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                                      -rw-r–r-- 1 petek petek 5798 Aug 26 19:34 /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                                        @rambomonkey I just installed the module
                                        git clone
                                        cd MMM-next-episode
                                        npm install
                                        used the sample config from the readme
                                        (typo missing : after password in the readme)
                                            hash_key: '',
                                            username: '',
                                            password: '',
                                            displayShowingOn: false,
                                            displayEpisodeName: false,
                                            maxdays: 7,
                                            updateInterval: 180
                                        and see the qr code on the screen under the header
                                        R PierreGodeP 2 Replies Last reply
                                          @sdetweil Thank you so much, its now working!
                                            @rambomonkey awesome!! what changed?
