    MMM-next-episode
    23 Posts 3 Posters 5.1k Views 3 Watching
      rambomonkey @PierreGode
      @PierreGode Hi thanks for coming back to me. Below is in my config:
      //MMM-Next-Episode
        module: "MMM-next-episode",
        position: "bottom_right",
        header: "Next-Episode",
          hash_key: '',
          username: 'myuser',
          password: 'mypass',
          displaySeasonAndEpisode: true,
          displayShowingOn: true,
          displayEpisodeName: true,
          maxdays: 7,
          ShowThumbnail: true,
          ThumbnailSize: 'small',
          updateInterval: 180
      MM version is v2.32.0
        @PierreGode Hi, thanks for coming back to me. MM version is v2.32.0, and below is what’s in my config.js
        //MMM-Next-Episode
            hash_key: '',
            username: 'myuser',
            password: 'mypass',
            maxdays: 7,
            updateInterval: 180
          sdetweil @rambomonkey
          @rambomonkey in the future, please use the code block wrapper for config entries and any log info
          to do this
          select the text you want to paste
          in the message editor, paste the text, with a blank line before and after
          then select the text you just pasted and press the </> button on the editor menu bar
          this will keep the formatting and make long items (logs) scrollable…
          I fixed the prior entries
            rambomonkey @sdetweil
            @sdetweil Hi sorry about that I did not know.
              rambomonkey @rambomonkey
              This might have something to do with it @PierreGode I see an error on server startup:
              [2025-08-21 19:19:45.691] [WARN] No /root/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js found for module: MMM-next-episode.
              But MMM-next-episode.js is present in the MMM-next-episode DIR
                @rambomonkey said in mmm-next-episode:
                /MMM-next-episode
                magic mirror is case sensitive…
                I think the module name is mmm-next-episode
                  @sdetweil Hi, I have changed the config.js and I still get the same error:
                  [2025-08-21 19:25:57.758] [WARN] No /root/MagicMirror/modules/mmm-next-episode/mmm-next-episode.js found for module: mmm-next-episode.
                    @rambomonkey ok, so if you go to the MagicMirror/modules folder and do
                    ls -laF
                    do you find a folder with the proper name…
                    note the module name, the folder name AND the js file AND the register in the js file names MUST match exactly
                      No /root/
                      also, NEVER run this stuff as root…
                      is that the user you used when you installed the module???
                        @sdetweil to be honest I cannot remember if I used root or not:
                        root@mmnew:~/MagicMirror/MMM-next-episode# ls -laF
                        total 108
                        drwxr-xr-x 6 root root 4096 Aug 21 19:22 ./
                        drwxr-xr-x 15 root root 4096 Aug 19 20:51 …/
                        drwxr-xr-x 8 root root 4096 Aug 19 18:45 .git/
                        drwxr-xr-x 3 root root 4096 Aug 19 18:45 .github/
                        -rwxr-xr-x 1 root root 31 Aug 19 18:45 .gitignore*
                        -rw-r–r-- 1 root root 35149 Aug 19 18:45 LICENSE
                        -rw-r–r-- 1 root root 602 Aug 19 18:45 MMM-next-episode.css
                        -rw-r–r-- 1 root root 5798 Aug 19 18:45 MMM-next-episode.js
                        -rw-r–r-- 1 root root 4613 Aug 19 18:45 README.md
                        drwxr-xr-x 2 root root 4096 Aug 19 18:45 img/
                        -rw-r–r-- 1 root root 2904 Aug 19 18:45 node_helper.js
                        drwxr-xr-x 33 root root 4096 Aug 19 18:45 node_modules/
                        -rw-r–r-- 1 root root 13972 Aug 19 18:45 package-lock.json
                        -rw-r–r-- 1 root root 544 Aug 19 18:45 package.json
                        S PierreGodeP 2 Replies Last reply Reply Quote 0
