    MMM-next-episode
    23 Posts 3 Posters 5.2k Views 3 Watching
      rambomonkey
      Re: MMM-next-episode - Track your TV shows and movies
      Hi All,
      I have followed @PierreGode instructions for installing said module, but when I run the MagicMirror the QR code does not appear on my mirror, any ideas as to why this would be the case?
      Thank you in advance, any help would be much appreciated!
      Regards
      PierreGodeP 1 Reply Last reply Reply Quote 0
      • PierreGodeP Offline
        PierreGode Module Developer @rambomonkey
        @rambomonkey
        Hi! I am the maintainer of MMM-next-episode
        could you verify that you have this in your config.js
          module: "MMM-next-episode",
          position: "bottom_right",
          header: "Next-Episode",
            hash_key: '',
            username:'your-next-episode-username',
            password: 'your-next-episode-password',
            displayShowingOn: true,
            displaySeasonAndEpisode: false,
            maxdays: 5,
            ShowThumbnail: true,
            ThumbnailSize: 'small',
            updateInterval: 180
        I just tested it on main branch and gave me the qr code after a pm2 restart
        then the id and hash might appear as one long string but the first 9 numbers is your id and the rest is the hash.
        verify that magic mirror is latest version.
          rambomonkey @PierreGode
          @PierreGode Hi thanks for coming back to me. Below is in my config:
          //MMM-Next-Episode
              hash_key: '',
              username: 'myuser',
              password: 'mypass',
              displaySeasonAndEpisode: true,
              displayEpisodeName: true,
              maxdays: 7,
              updateInterval: 180
          MM version is v2.32.0
            @PierreGode Hi, thanks for coming back to me. MM version is v2.32.0, and below is what’s in my config.js
            //MMM-Next-Episode
                hash_key: '',
                username: 'myuser',
                password: 'mypass',
                maxdays: 7,
                updateInterval: 180
              sdetweil @rambomonkey
              @rambomonkey in the future, please use the code block wrapper for config entries and any log info
              to do this
              select the text you want to paste
              in the message editor, paste the text, with a blank line before and after
              then select the text you just pasted and press the </> button on the editor menu bar
              this will keep the formatting and make long items (logs) scrollable…
              I fixed the prior entries
                rambomonkey @sdetweil
                @sdetweil Hi sorry about that I did not know.
                  rambomonkey @rambomonkey
                  This might have something to do with it @PierreGode I see an error on server startup:
                  [2025-08-21 19:19:45.691] [WARN] No /root/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js found for module: MMM-next-episode.
                  But MMM-next-episode.js is present in the MMM-next-episode DIR
                    @rambomonkey said in mmm-next-episode:
                    /MMM-next-episode
                    magic mirror is case sensitive…
                    I think the module name is mmm-next-episode
                      @sdetweil Hi, I have changed the config.js and I still get the same error:
                      [2025-08-21 19:25:57.758] [WARN] No /root/MagicMirror/modules/mmm-next-episode/mmm-next-episode.js found for module: mmm-next-episode.
                        @rambomonkey ok, so if you go to the MagicMirror/modules folder and do
                        ls -laF
                        do you find a folder with the proper name…
                        note the module name, the folder name AND the js file AND the register in the js file names MUST match exactly
                          No /root/
                          also, NEVER run this stuff as root…
                          is that the user you used when you installed the module???
                            @sdetweil to be honest I cannot remember if I used root or not:
                            root@mmnew:~/MagicMirror/MMM-next-episode# ls -laF
                            total 108
                            drwxr-xr-x 6 root root 4096 Aug 21 19:22 ./
                            drwxr-xr-x 15 root root 4096 Aug 19 20:51 …/
                            drwxr-xr-x 8 root root 4096 Aug 19 18:45 .git/
                            drwxr-xr-x 3 root root 4096 Aug 19 18:45 .github/
                            -rwxr-xr-x 1 root root 31 Aug 19 18:45 .gitignore*
                            -rw-r–r-- 1 root root 35149 Aug 19 18:45 LICENSE
                            -rw-r–r-- 1 root root 602 Aug 19 18:45 MMM-next-episode.css
                            -rw-r–r-- 1 root root 5798 Aug 19 18:45 MMM-next-episode.js
                            -rw-r–r-- 1 root root 4613 Aug 19 18:45 README.md
                            drwxr-xr-x 2 root root 4096 Aug 19 18:45 img/
                            -rw-r–r-- 1 root root 2904 Aug 19 18:45 node_helper.js
                            drwxr-xr-x 33 root root 4096 Aug 19 18:45 node_modules/
                            -rw-r–r-- 1 root root 13972 Aug 19 18:45 package-lock.json
                            -rw-r–r-- 1 root root 544 Aug 19 18:45 package.json
                            S PierreGodeP 2 Replies Last reply Reply Quote 0
                              @rambomonkey uou can see root owns the files
                              if you try to run as a normal user, you dont have permission to access them at all
                              thus the not found
                                @sdetweil Thanks for the info, sorry im new to Linux. Would you happen to know how I could give a specific user the permissions?
                                  @rambomonkey
                                  the permissions are 3 sets of 3 rights
                                  user read/write/execute
                                  group anyone in this group
                                  other anybody not specified above
                                  the commands
                                  are chmod which can set the individual
                                  permissions using flags or a number
                                  777 means all for all
                                  770 mean user and group users can do anything, everyone else no access
                                  the there is chgrp to change the group
                                  all commands have help
                                  –help
                                  and most have a page in the manuals
                                  man commandname
                                  man chmod
                                  man chgrp
                                  you
                                  eill need root permission to take root
                                  permissions away
                                  sudo gives root permission for this command
                                    @rambomonkey
                                    So this is how you want your Magic mirror setup to look like.
                                    yeah no /root/ that can create a loads of headaches like this.
                                    R 2 Replies Last reply Reply Quote 1
                                      @PierreGode @sdetweil thanks you two, think I will just re-install as a normal user, you live and learn lol.
                                        @PierreGode Hi, I have now re-installed it under user petek and I’m still seeing the same issue:
                                        petek@MagicMirror-v2:/home/MagicMirror$ ls -la /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                                        -rw-r–r-- 1 petek petek 5798 Aug 26 19:34 /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                                          @rambomonkey I just installed the module
                                          git clone
                                          cd MMM-next-episode
                                          npm install
                                          used the sample config from the readme
                                          (typo missing : after password in the readme)
                                              hash_key: '',
                                              username: '',
                                              password: '',
                                              displayShowingOn: false,
                                              displayEpisodeName: false,
                                              maxdays: 7,
                                              updateInterval: 180
                                          and see the qr code on the screen under the header
                                          R PierreGodeP 2 Replies Last reply Reply Quote 0
                                            @sdetweil Thank you so much, its now working!
