    MM2 fails to start after upgrade from 2.29 to 2.33 on windows
    9 Posts 3 Posters 2.0k Views 3 Watching
    • E Offline
      edwardbuck
      I just ran the upgrade script to upgrade my install from 2.29 to 2.33, and now nothing loads at all.
      I ran the script, then rebooted, then tried npm start from MagicMirror folder and this is all it shows:
      magicmirror@2.33.0 start
      node --run start:x11
      node: bad option: --run
      I have since tried doing a git reset --hard and a git pull, but it just says that I am already running 2.33.
      I have MagicMirror running on Windows10.
      I’d appreciate any suggestions to get it running again.
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
      • E Offline
        edwardbuck @sdetweil
        Thanks for your help. I upgraded to the latest node and it is running fine again. Sorry for not reading the error more closely, since it said the same thing you did.
          sdetweil @edwardbuck
          @edwardbuck the script does not work on windows
          You also need to use
          npm run start:windows
          • E Offline
            Ok, so I just tried that (from the MagicMirror folder) but it gives me this now:
            magicmirror@2.33.0 start:windows
            .\node_modules.bin\electron js\electron.js
            The system cannot find the path specified.
            Do I need to reinstall MM2?
              @edwardbuck did you go
              npm install
              In the MagicMirror folder?
              • E Offline
                When I do npm install I get this:
                npm error code EBADENGINE
                npm error engine Unsupported engine
                npm error engine Not compatible with your version of node/npm: magicmirror@2.33.0
                npm error notsup Not compatible with your version of node/npm: magicmirror@2.33.0
                npm error notsup Required: {“node”:“>=22.18.0”}
                npm error notsup Actual: {“npm”:“10.8.2”,“node”:“v20.17.0”}
                npm error A complete log of this run can be found in: C:\Users\Agenda\AppData\Local\npm-cache_logs\2025-10-13T20_42_59_969Z-debug-0.log
                • KristjanESPERANTOK Offline
                  KristjanESPERANTO Module Developer @edwardbuck
                  @edwardbuck said in MM2 fails to start after upgrade from 2.29 to 2.33 on windows:
                  You certainly knew that, but Windows 10 support ends tomorrow. It’s about time to think about an alternative. See https://distrochooser.de/.
                    @edwardbuck yes, the doc says need 22.18.0 or higher
                    https://forum.magicmirror.builders/topic/19896/v2.33.0
                    • E Offline
                      • E Offline
                        edwardbuck @KristjanESPERANTO
                        @KristjanESPERANTO
                        I’m running MM2 on an old Lenovo mini PC I got on ebay for half the price of a Raspberry PI. I considered installing Linux at the beginning, but now I am also running a MS Access database on there that won’t run under Win11, and a Logitech media server to keep my old Squeezebox playing. Regardless of support for Win10, as long as it keeps running, it is fine for me.
