    Use local data from weatherstation
    10 Posts 5 Posters 4.6k Views 5 Watching
      Jose1701
      I`m searching for a module which shows my local data from my weatherstation (ecowitt clone), similar to this one, but directly from my local station and not by using any cloud service. mmm- WunderGround-PWS-Observations
      This could be happen by using the FOSHK plugin or weewx.
      I know that there is a module to show soil-moisture from ecowitt stations. That would be a possibility if you can expand it to use all of the other data like temperature, wind, …
      Kind regards
      Florian
      BKeyportB S 2 Replies Last reply
      • BKeyportB
        BKeyport Module Developer @Jose1701
        @Jose1701 what I ended up doing with my Davis weatherstation was use their web display interface with MMM-EmbedURL to just show their full screen weather display on the mirror.
        J 1 Reply Last reply
          Jose1701 @BKeyport
          @BKeyport
          Thats`s a nice idea, too. But I like to have it much more simple like this one mentioned above. (mmm- WunderGround-PWS-Observations)
            Jose1701 @Jose1701
            Found a solution by the help of a member of another forum. Now everything works great and just the way I wanted it.
            If you are interested in, have a look here. Unfortunately it is in German language.
            Use data from local weatherstation
            Kind regards
            Jose
            O 1 Reply Last reply
            • O
              olicat @Jose1701
              Hi!
              There is now also an English-language text Displaying local PWS data with FOSHKplugin on a MagicMirror on this topic and a module MMM-FOSHKplugin-PWS-Observations.
              Oliver
                st3v0rr @Jose1701
                @Jose1701 I have the froggit WH2600 Pro and wrote a module. From what I know this is also a clone from ecowitt. My station includes a wifi gateway and is reachable in the local network via ip.
                https://github.com/st3v0rr/MMM-WH2600
                  Jose1701 @st3v0rr
                  @st3v0rr
                  I`ve seen that. Looks good.
                  Well, I could try if this works, too. I let you know.
                  Regards
                  Jose
                    RonR
                    jose1701; I’m very interested in how you got the FOSKplugin to work. I just purchased a Ecowitt WS90 weather station and their GW3000 gateway. When I started the plugin it ran through a setup script and there were a few items that I had no idea what the answer was. The biggest on was the port the gateway is working on. I have seen nothing on that in the documentation. Do you know where I can find the port number? Some of the other things I can play with but the port number I have no idea.
                    I appreciate you help,
                    Ron R
                    • O
                      olicat @RonR
                      @RonR said in Use local data from weatherstation:
                      Installing FOSHKplugin is actually quite simple and is described in detail here.
                      The port is selected automatically during installation, so you shouldn’t have any problems with that.
                      However, you may have installed the old “stable” version, which is known to cause problems these days. It is better to use the public beta.
                      Regards, Oliver
                        RonR
                        Yes, I attempted installed to install the ‘stable’ version and it did not automatically select the gateway port number. I will attempt to install the ‘beta’ version tonight.
                        Thanks for the help.
                        BTW, I ran Wireshark last night and found the port number, at least for the GW3000, it is 53374. I would never have guessed it.
