    MMM-WindyV2 Layer Rotating
    12 Posts 4 Posters 1.0k Views 4 Watching
      MikeTheYeti
      The module does not want to rotate through the weather layers. Below is my config:
            disabled: false,
            module: "MMM-WindyV2",
            position: 'fullscreen_above',          // this must be set to 'fullscreen_above'
                  apiKey: 'XXXXXXX', // insert your free or paid API key here
                  initLoadDelay: 50,               // optional, default is 50 milliseconds
                  latitude: 41.432717,         // example: 69.123
                  longitude: -71.979947,       // example: 17.123
                  zoomLevel: 10,                    // set your preferred zoom level
                  showLayer: 'rain',               // wind, rain, clouds, temp, pressure, currents, waves
                  rotateLayers: true,              // set to true to rotate layers
                  layersToRotate: ['wind','rain'], // layers to rotate
                  delayRotate: 5000,               // delay between rotated layers, in milliseconds
                  wMinZoom: 3,                     // set minimum zoom level for WindyV2
                  wMaxZoom: 17,                    // set maximum zoom level for WindyV2
                  windyMetric: 'kt',               // 'kt', 'bft', 'm/s', 'km/h' and 'mph'
                  updateTimer: 60 * 60 * 1000 * 6, // update per 6 hours
                  retainZoom: true                 // retain zoomlevel between changing overlays
      Any ideas? Thanks.
        MikeTheYeti @MikeTheYeti
        I solved it. If you want more than temp, wind, or pressure for your layers you have to run a paid API. The free Testing API limits the layers.
        I am thinking my MM is not worth $1K per year to have a weather background.
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @MikeTheYeti
          @MikeTheYeti On the module list (https://modules.magicmirror.builders/) is no module named MMM-WindyV2. Where did you get it?
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO
            https://github.com/TheStigh/MMM-WindyV2
              MikeTheYeti @sdetweil
              @sdetweil Thanks!
                sdetweil @MikeTheYeti
                @MikeTheYeti you can find that by going to the module folder and do
                git remote -v
                  MMM-WindyV2 seems not maintained anymore. Did you see there is a newer fork: https://github.com/jhogendorn/MMM-WindyV3/ ?
                    MikeTheYeti @KristjanESPERANTO
                    @KristjanESPERANTO I did, and I have not tried it yet. A cursory look and it may give the same issue. I will give it a go and report back.
                        @MikeTheYeti said in MMM-WindyV2 Layer Rotating:
                        yikes…!
                          Before I pulled the plug on running this module due to API costs, I did install V3, and it ran just fine without any need to tweak.
                          • plainbrokeP Offline
                            plainbroke @MikeTheYeti
                            @MikeTheYeti
                            So V3 works with the free api aka test api?
                              MikeTheYeti @plainbroke
                              @plainbroke It does, but the test API limits one to wind, temperature, and pressure.
                              Sorry it took 7 days to respond, busy life, I suppose.
                              • M MikeTheYeti has marked this topic as solved on
