    Home Assistant Sensor
    17 Posts 2 Posters 1.3k Views 2 Watching
      sdetweil @ChrisKelley
      @ChrisKelley did you change the config to .local??
      Can you ping that from the MagicMirror system
      i have grandson duty for 2 hours now
      Then I will install that module
        ChrisKelley @sdetweil
        Yep that works…
        chris@MagicMirror:~ $ ping 10.10.28.134
        PING 10.10.28.134 (10.10.28.134) 56(84) bytes of data.
        64 bytes from 10.10.28.134: icmp_seq=1 ttl=64 time=0.027 ms
        64 bytes from 10.10.28.134: icmp_seq=2 ttl=64 time=0.032 ms
        64 bytes from 10.10.28.134: icmp_seq=3 ttl=64 time=0.029 ms
        64 bytes from 10.10.28.134: icmp_seq=4 ttl=64 time=0.062 ms
        64 bytes from 10.10.28.134: icmp_seq=5 ttl=64 time=0.036 ms
        64 bytes from 10.10.28.134: icmp_seq=6 ttl=64 time=0.035 ms
        64 bytes from 10.10.28.134: icmp_seq=7 ttl=64 time=0.022 ms
        64 bytes from 10.10.28.134: icmp_seq=8 ttl=64 time=0.022 ms
        64 bytes from 10.10.28.134: icmp_seq=9 ttl=64 time=0.025 ms
        64 bytes from 10.10.28.134: icmp_seq=10 ttl=64 time=0.025 ms
        code_text
        S C 2 Replies Last reply Reply Quote 0
          @ChrisKelley ping by name?
            ChrisKelley @ChrisKelley
            Yep sorry that makes more sense
            chris@MagicMirror:~ $ ping homeassistant.local
            PING homeassistant.local (10.10.28.211) 56(84) bytes of data.
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=1 ttl=64 time=2.91 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=2 ttl=64 time=3.81 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=3 ttl=64 time=4.07 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=4 ttl=64 time=3.88 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=5 ttl=64 time=1.18 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=6 ttl=64 time=3.95 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=7 ttl=64 time=4.10 ms
            64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=8 ttl=64 time=1.52 ms
              @ChrisKelley no issue, it’s useful as we know it generates the same address
                @ChrisKelley so I installed, did npm install in the module folder
                here is my config , two sensors from my entities list in HA
                so now all I can think is your token string is bad…
                          module: 'MMM-homeassistant-sensors',
                          position: 'top_left',
                          classes: "page4",
                            host: "homeassistant.local",
                            port: "8123",
                            https: false,
                            token: " my fresh token ",
                            values: [
                                sensor: "binary_sensor.athom_garage_door_status",
                                sensor: "sensor.foo_battery_percentage",
                  Thank you for all the help… I tried deleting the token. I made a new token in HA and used that one still nothing… I deleted the module from MM and I will try again this afternoon. Which fork did you use for your test? There are at least two just want to make sure I use the same one as you did…
                  Chris
                    @ChrisKelley I used this one
                    https://github.com/Snille/MMM-homeassistant-sensors.git
                      SAM!!!
                      Thank You!! It works… I was using a different fork then the one you used… plus I think my sensor strings were malformed. but all good now!
                      Thank You Again!
                        @ChrisKelley woohoo… great news… thanks for the feedback!!
